LibFredo6 v16.2b
Overview of LibFredo6
- Usage: Free
LibFredo6 is a shared plugin library used by most of my extensions. LibFredo6 takes care, among others, of enriching my extensions with a few capabilities such as default parameters, language translation, Check Plugins for Update, Trace logging, etc.
It is NOT a standalone plugin. It must be installed once for all my extensions and updated as needed when new versions are published.
Since v10.0, LibFredo6 is released for SU2017+ only.
Extensions currently using LibFredo6 are:
LordOfTheToolbars
FredoCorner
FredoBend
Thrupaint
Pic2Shape
FredoSection
FredoSketch
LayOps
FredoBatch
FredoConnect
FredoScale
FredoSpline
RoundCorner
JointPushPull Interactive
Layport
MoveAlignMe
Please2D
MatSim
MrHide
FredoGhost
FredoPortrait
FredoGuides
Curviloft
Tools On Surface
FredoTools
TopoShaper
Curvizard
VisuHole
Souvenir
Animator
SUClock
GhostComp
HoverSelect
- Language: English, French, Spanish (Spain and Latin America), Chinese, + partial Italian, Japanese, Korean, German (thanks to all kind translators). Thanks to Christophe Plassais for the French user manual. Thanks to guanjin for the Chinese user manual.
- Menus: by default, it is installed in Window > LibFredo6 Settings…
- Icon toolbar: NO Toolbar
Installation of LibFredo6
LibFredo6 is released as a regular RBZ extension file on the Sketchucation Site.
Method 1: Download RBZ file and install via the Sketchup Extension Manager
- Log in to get it! otherwise, in order to log in or to register to Sketchucation as a new member (this is FREE). You will then be able to download the RBZ file.
The installation of the RBZ file is done from within Sketchup via the Sketchup Extension Manager
- for Sketchup versions <= 2016 - menu Windows > Preferences > Extensions
- for Sketchup 2017 and above - menu Windows > Extension Manager.
If you are not familiar with the installation of Sketchup extensions and Sketchucation, it is advised to watch the video LibFredo6 installation at the top of this page.
Method 2: Auto-install in ONE CLICK via the Sketchucation ExtensionStore
IMPORTANT: Whatever way you choose, you MUST quit and restart Sketchup to get LibFredo6 properly loaded.
After the installation, you should have the following footprint in the Sketchup Plugins directory, that is, one folder and one .rb file
NEVER rename files or move them out of their folders.
LibFredo6 can be installed in an alternate plugins directory, not just the Sketchup standard directory. Always make sure that my other plugins (like Fredo_RoundCorner) are located in the SAME folder as LibFredo6.
Page under construction
Menu for LibFredo6
LibFredo6 does not have a Toolbar but installs a submenu LibFredo6 Settings… in the Window menu of Sketchup. It contains a command to specify the language preferences, as well as several utilities for plugin information and maintenance. You can also set a few default parameters (inference colors) and access the documentation (as a PDF).
Support of High-resolution screens
With high resolutions screens (double dpi), the button palette used in some of my plugins displays in very small fonts. There is no native support yet from Sketchup for high resolution screens.
As of LibFredo6 v7.7a (9 Jul 17), there is a first attempt to support high-resolution screens. Basically, the button palettes, progressions bars, the text font, the line thickness and the dimension of some visual marks are grown by the factor of resolution.
- Sketchup < 2016: Font size cannot be changed and characters may thus still appear small
- Sketchup 2016: you have to set up manually the scale factor (usually 2), because it cannot be detected by the API.
- Sketchup >= 2017: the configuration is automatic. Still you can disable the option.
The settings are in the LibFredo6 Default Parameters:
This support should apply to all my plugins using LibFredo6 (except HoverSelect). For Animator, you MUST upgrade to Animator 1.7 or above. However, there may be changes required in each individual plugin, which will be rolled out progressively.
Please report all issues and suggestions in the following thread on the Sketchucation forum
This feature allows to check the version of my plugins installed on your device.
The documentation is a little bit outdated, but gives you an idea of some of the features of LibFredo6.
LibFredo6 User Manual - English - v5.2.pdf
Note: If you drop the PDF doc files into the Plugins directory, you can access them from within Sketchup via the menu Windows > LibFredo6 Settings... > Documentation...
LibFredo6 16.2b – 22 Sep 26: Adjustments for compatibility SU2027
LibFredo6 16.2a – 22 Sep 26: Adjustments for compatibility SU2027
LibFredo6 16.1g – 11 Sep 26: Bug fixing on Mac for some configurations
LibFredo6 16.1a – 31 Aug 26: Future compatibility and bug fixing
LibFredo6 16.0b – 19 Aug 26: Fix for dialogs when V-Ray present
LibFredo6 16.0a – 08 Aug 26: Fix for ThruPaint (palette visibility)
LibFredo6 15.9d – 09 Jul 26: Fix for Input dialog box. For FredoScale
LibFredo6 15.9c – 01 May 26: Tentative fix for Eastern characters UTF16
LibFredo6 15.9b – 21 Apr 26: Bug fixing and future compatibility
LibFredo6 15.9a – 25 Mar 26: Bug fixing and FredoBend v1.2a
LibFredo6 15.8e – 15 Feb 26: Bug fixing and future compatibility
LibFredo6 15.8d – 01 Feb 26: Bug fixing for Animator (WebList)
LibFredo6 15.8c – 28 Jan 26: Bug fixing for ColorScale
LibFredo6 15.8b – 12 Jan 26: Bug fixing for picking and for Axyz
LibFredo6 15.8a – 09 Jan 26: Bug fixing for Animator and for FredoSection v1.4a
LibFredo6 15.7b – 02 Jan 26: Technical adjustments (Axyz)
LibFredo6 15.7a – 26 Dec 25: For FredoSection v1.3a
LibFredo6 15.6c – 10 Dec 25: Full compatibility SU2026.1 and bug fixing
LibFredo6 15.6b – 02 Dec 25: Full compatibility SU2026 and future (FredoSection)
LibFredo6 15.6a – 26 Nov 25: Full compatibility SU2026 and future
LibFredo6 15.5a – 08 Oct 25: Full compatibility SU2026
LibFredo6 15.4e – 25 Aug 25: Bug in loading sequence (match line in .plugin file)
LibFredo6 15.4d – 14 Aug 25: For future compatibility
LibFredo6 15.4c – 01 Aug 25: For ToolsOnSurface (bug in image texture)
LibFredo6 15.4b – 21 Jul 25: For Animator (bug in renaming positioners)
LibFredo6 15.4a – 13 May 25: For LayOps v1.1
LibFredo6 15.3f – 12 May 25: For LayOps and technical adjustments (bug fixing in WebInput)
LibFredo6 15.3e – 12 May 25: For LayOps and technical adjustments
LibFredo6 15.3d – 11 May 25: For LayDitor and technical adjustments
LibFredo6 15.3c – 17 Apr 25: For Axyz
LibFredo6 15.3a – 02 Apr 25: For JointPushPull v4.9a
LibFredo6 15.2a – 12 Mar 25: For bug fixing (random menu failure) and Animator v4.3a
LibFredo6 15.1c – 08 Mar 25: For bug fixing in ThruPaint (second attempt)
LibFredo6 15.1b – 08 Mar 25: For bug fixing in ThruPaint
LibFredo6 15.1a – 28 Feb 25: For Animator v4.2a
LibFredo6 15.0a – 31 Dec 24: For FredoBatch v1.3a
LibFredo6 14.9a – 06 Dec 24: For FredoBatch v1.2a
LibFredo6 14.8a – 26 Nov 24: For FredoBatch v1.1a
LibFredo6 14.7a – 09 Nov 24: For ThruPaint v2.8a, future comptibility, new plugins and bug fixing
LibFredo6 14.6a – 18 Sep 24: For ThruPaint v2.5a and other plugins
LibFredo6 14.5f – 07 Aug 24: Various bug fixing and adjustments for dialogs
LibFredo6 14.5c – 03 Jul 24: Various bug fixing and adjustments
LibFredo6 14.5b – 24 May 24: For Fredo Layport v1.1a and small adjustment
LibFredo6 14.5a – 23 May 24: For Fredo Layport v1.1a
LibFredo6 14.4d – 20 May 24: Fix of a bad side-effect on JointPushPull introduced in v14.4c
LibFredo6 14.4c – 18 May 24: Fix for FredoCorner (for SU2023-SU2024)
LibFredo6 14.4a – 10 May 24: Fix for Curviloft Laong Path and for Fredo Layport v1.1
LibFredo6 14.3d – 21 Apr 24: Bug for LordOfTheToolbars and various
LibFredo6 14.3b – 31 Mar 24: For future compatibility and Check Plugins for Update
LibFredo6 14.3a – 30 Mar 24: For future compatibility
LibFredo6 14.2a – 26 Aug 23: For future compatibility
LibFredo6 14.1a – 10 Jul 23: For JointPushPull v4.7a (group unique and preservation of curves)
LibFredo6 14.0a – 03 Jul 23: For MatSim v1.1 (new extension for Material simulation)
LibFredo6 13.9a – 20 Feb 23: Compatibility SU2023 (startup sequence and detection main window)
LibFredo6 13.8a – 04 Feb 23: Fix of a bug related to licensing of ThruPaint
LibFredo6 13.7b – 20 Jan 23: Fix of a bug in FredoScale Radial Bend (protractor base direction)
LibFredo6 13.7a – 18 Jan 23: For FredoSketch v1.1 and bug fixing for future compatibility
LibFredo6 13.6a – 29 Nov 22: Bug fixing for context menu and future compatibility
LibFredo6 13.5a – 10 Nov 22: Bug fixing at startup and future compatibility
LibFredo6 13.4a – 30 Sep 22: For ThruPaint v2.1a
LibFredo6 13.3a – 27 Sep 22: Bug fixing in LibFredo6 (preventing CheckForUpdate) and for FredoSpline (tracing over images)
LibFredo6 13.2a – 16 Sep 22: Bug fixing and for future plugins (works on M1)
LibFredo6 12.9a – 15 Sep 22: Rollback due to problems with Mac M1
LibFredo6 13.1a – 12 Sep 22: Bug fixing and evolutions for new plugins to come
LibFredo6 12.9a – 13 May 22: Bug fixing and for LOTT v2.1a
LibFredo6 12.8a – 17 Mar 22: Potential issues related to the loading of my plugins (bug concerning menus)
LibFredo6 12.7a – 11 Mar 22: Fixes issues in v12.6, affecting JointPushPull and other plugins
LibFredo6 12.6b – 11 Mar 22: Bug fixing for alternate icon directories and traces for menu issue at startup (correction on v12.6a)
LibFredo6 12.6a – 11 Mar 22: Bug fixing for alternate icon directories and traces for menu issue at startup
LibFredo6 12.5b – 07 Mar 22: Updated translation to Chinese by arc
LibFredo6 12.5a – 21 Feb 22: Bug fixing, technical adjustments and support for future plugins
LibFredo6 12.4a – 09 Jan 22: For LOTT v1.7a
LibFredo6 12.3a – 27 Dec 21: For LOTT v1.6a and technical adjustments for future compatibility
LibFredo6 12.2a – 01 Nov 21: For FredoSpline v2.3a and technical adjustments
LibFredo6 12.1a – 23 Oct 21: Mainly for plugin MoveAlignMe
LibFredo6 12.0b – 30 Sep 21: Fix calculation of volumes for several plugins and other fixes
LibFredo6 12.0a – 17 Sep 21: For LordOfTheToolbars v1.5a and FredoTools v4.2a and bug fixing
LibFredo6 11.9c – 10 Jul 21: For LordOfTheToolbars v1.4d and bug fixing
LibFredo6 11.9b – 08 Jul 21: For LordOfTheToolbars v1.4c and bug fixing
LibFredo6 11.9a – 06 Jul 21: For LordOfTheToolbars v1.4a and bug fixing
LibFredo6 11.8a – 02 Jun 21: For LordOfTheToolbars v1.3a
LibFredo6 11.7c – 16 May 21: Bug fixing and technical adjustments for Mac
LibFredo6 11.7a – 12 May 21: Bug fixing and technical adjustments for Windows and Mac
LibFredo6 11.6a – 23 Jan 21: Bug fixing and technical adjustments
LibFredo6 11.5b – 18 Jan 21: Fixes a conflict with Profile Builder 3
LibFredo6 11.5a – 15 Jan 21: Evolution for Animator (Movement along path) and various bug fixing
LibFredo6 11.4f – 02 Dec 20: Fixed a bug in core library (Group explode) affecting MoveAlong and other plugins, as well as handling non-ascii Windows username
LibFredo6 11.5a – 15 Jan 21: Various bug fixing and adjustments. Also integrates changes for Animator (Move Along Path with upright orientation)
LibFredo6 11.4d – 27 Nov 20: Fixes for Animator (VRay5 and sections, variable rotation speed)
LibFredo6 11.4a – 23 Nov 20: Fix for VRay 4.2 and Animator
LibFredo6 11.3b – 21 Nov 20: Additional adjustments
LibFredo6 11.3a – 19 Nov 20: Bug fixing and support of VRay 5 in Animator
LibFredo6 11.2c – 11 Oct 20: Fixed a bug in Animator video generation
LibFredo6 11.2b – 09 Oct 20: Technical adjustments for video generation used by Animator
LibFredo6 11.2a – 27 Sep 20: Technical adjustments to some dialogs (HtmlDialog)
LibFredo6 11.1c – 08 Sep 20: Various bug fixing
LibFredo6 11.1a – 26 Aug 20: Fix the issue of the 'shadow' extension top_LibFredo6 appearing in the Extension Manager
LibFredo6 11.0b – 24 Aug 20: Fix for JointPushPull (Ctrl Toggle)
LibFredo6 11.0a – 19 Aug 20: Various bug fixing and technical evolutions (HtmlDialog)
LibFredo6 10.9a – 02 Jul 20: Fix for Vray rendering with Animator
LibFredo6 10.8a – 20 Jun 20: Bug fixing (crash in Check Plugins for Update on Mac SU2017)
LibFredo6 10.7a – 12 Jun 20: Bug fixing , adjustments for Mac (Html Dialogs) and imperial units in VCB
LibFredo6 10.6a – 01 Jun 20: Bug fixing , adjustments for Mac (keyboard) and FredoSpline v1.4a
LibFredo6 10.5a – 25 May 20: Bug fixing and cosmetic adjustments (most for Mac)
LibFredo6 10.4c – 19 May 20: Bug fixing for FredoTools::DrawAlong (VCB)
LibFredo6 10.4b – 17 May 20: Additional bug fixing and cosmetic adjustments (some for Mac) + FredoTools::ReportLabelArea
LibFredo6 10.4a – 16 May 20: Bug fixing and Cosmetic adjustments (some for Mac)
LibFredo6 10.3b – 30 Apr 20: Cosmetic adjustments
LibFredo6 10.3a – 29 Apr 20: Fixes issues affecting Curviloft and Curvizard
LibFredo6 10.2a – 29 Apr 20: Fixes issues with FredoSpline and generic modules
LibFredo6 10.1a – 27 Apr 20: Fixes issues with Animator cameras (in Parallel projection) and Eye icon for Quick Launchers
LibFredo6 10.0a – 20 Apr 20: First release for SU2016+
LibFredo6 9.5k – 14 Mar 20: Fix a problem related to some configurations of MacOS Catalina (case sensitivity)
LibFredo6 9.5j – 25 Feb 20: bug fixing (model with no attributes, additional)
LibFredo6 9.5i – 25 Feb 20: bug fixing (model with no attributes)
LibFredo6 9.5h – 13 Feb 20: For Animator (Bezier)
LibFredo6 9.5g – 09 Feb 20: For Animator and MoveAlong (OriginTargetPicker)
LibFredo6 9.5f – 08 Feb 20: For VisuHole (axis for capturing stencils from container)
LibFredo6 9.5e – 05 Feb 20: For FredoTools:ReportLabelArea (object material) and openURL on Mac
LibFredo6 9.5d – 03 Feb 20: Major bug fixing affecting Curvizard (some tools did not generate Sketchup curves)
LibFredo6 9.5c – 10 Jan 20: Major bug fixing affecting Curvizard
LibFredo6 9.5b – 08 Jan 20: Bug fixing and adjustments (AppData)
LibFredo6 9.5a – 23 Dec 19: For FredoGuides v1.1a and bug fixing
LibFredo6 9.4b – 25 Nov 19: For FredoPortrait v2.0b (Screenshot) and FredoTools::ColorPaint
LibFredo6 9.4a – 18 Nov 19: For FredoPortrait v2.0a (Screenshot) and FredoTools v3.8a
LibFredo6 9.3a – 02 Nov 19: For FredoTools v3.7a for changes in ReportLabelArea, ColorPaint and ColorByAltitude
LibFredo6 9.2a – 16 Oct 19: For FredoTools v3.6a with introduction of ColorPaint and ColorByAltitude
LibFredo6 9.1b – 28 Jul 19: For Souvenir 1.8d (custom directory for SU Tasks) and Animator (timeout VRAY)
LibFredo6 9.1a – 20 Jul 19: For FredoPortrait v1.2a and bug fixing
LibFredo6 9.0a – 23 Jun 19: For FredoPortrait v1.1a and bug fixing
LibFredo6 8.9b – 06 Jun 19: Fixes a potential bug in the Registry
LibFredo6 8.9a – 06 Jun 19: Fixes various bugs and needed for FredoGhost 1.2a
LibFredo6 8.8a – 24 Feb 19: Fixes various bugs and needed for Curvizard v2.4a
LibFredo6 8.7m – 15 Feb 19: Fixes various bugs and aligns reference of release
LibFredo6 8.7j – 14 Jan 19: Fix various bugs and accuracy of hand cursor in button palettes
LibFredo6 8.7f – 10 Jan 19: Fix of a bug preventing new versions of FFmpeg to work with Animator
LibFredo6 8.7e – 01 Jan 19: Fix of a bug preventing some dialog boxes to display
LibFredo6 8.7d – 20 Dec 18: Fix of a major bug preventing dialog boxes to display on MAC
LibFredo6 8.7a – 18 Dec 18: Adjustments for various plugins
LibFredo6 8.6p – 05 Dec 18: Fixes a bug in Animator (Path manager)
LibFredo6 8.6n – 05 Dec 18: Fixes problems in Orbiting (Zoom Void)
LibFredo6 8.6m – 18 Nov 18: For Animator 2.3c (transparent background) and size of toolbar icons for hi-res screens
LibFredo6 8.6k – 03 Nov 18: New doc for FFmpeg installation on Mac
LibFredo6 8.6j – 30 Oct 18: Bug fixing and small GUI adjustments (toolbar icon size in high DPI)
LibFredo6 8.6i – 21 Oct 18: Release for FredoTools 3.3a (Bug Fixing)
LibFredo6 8.6h – 15 Oct 18: Release for FredoCorner 1.2b (Radius mode)
LibFredo6 8.6g – 27 Sep 18: Release for bug fixing and full Chinese translation (guanjin)
LibFredo6 8.6f – 23 Sep 18: Release for FredoCorner 1.1e (variator and bug fixing)
LibFredo6 8.6e – 19 Sep 18: Release for FredoCorner 1.1d (zoom) - Full Spanish translation by Oxer
LibFredo6 8.6d – 11 Sep 18: Release for FredoCorner 1.1c - Full French translation + partial Chinese
LibFredo6 8.6c – 08 Sep 18: Release for FredoCorner 1.1b - Orbiting on Mac (clean)
LibFredo6 8.6b – 07 Sep 18: Release for FredoCorner 1.1a - Orbiting on Mac
LibFredo6 8.6a – 06 Sep 18: Release for FredoCorner 1.1a
LibFredo6 8.5h – 27 Aug 18: Compatibility SU8 and SU2013
LibFredo6 8.5f – 14 Aug 18: Longer time out for Vray rendering
LibFredo6 8.5c – 31 Jul 18: Fix for non-ascii Windows username
LibFredo6 8.5b – 14 Jul 18: For Animator 2.2b (full screen) and bug fixing
LibFredo6 8.5a – 13 Jul 18: For Animator 2.2 and bug fixing
LibFredo6 8.4g – 10 Jun 18: Fix a bug in Animator video generation (ffmpeg location)
LibFredo6 8.4f – 29 May 18: Fix a bug in Animator video generation (ffmpeg)
LibFredo6 8.4e – 28 May 18: Fix in text selection for some web dialogs
LibFredo6 8.4d – 21 May 18: Fix in Check for Update popup (UpgradeWarning)
LibFredo6 8.4c – 21 May 18: Correction over v8.4b
LibFredo6 8.4b – 21 May 18: Update release for Animator 2.1 (Apparition with boundary planes)
LibFredo6 8.4a – 20 May 18: Major release for Animator 2.1
LibFredo6 8.3a – 07 May 18: Major release for Animator 2.0
LibFredo6 8.1h – 06 Apr 18: Scaling for flat faces in Animator (Quad boxes in G6)
LibFredo6 8.1g – 01 Apr 18: Non-ascii Windows username (encode to force_encoding)
LibFredo6 8.1f – 19 Mar 18: Adjustments for Animator (scaling) and TopoShaper (large models)
LibFredo6 8.1e – 13 Mar 18: Bug fixing for non-ascii username (encode and force_encoding)
LibFredo6 8.1d – 04 Mar 18: Bug fixing - bugsplats in Curviloft
LibFredo6 8.1c – 27 Feb 18: Bug fixing for Curviloft, JointPushPull and FredoTools
LibFredo6 8.1b – 25 Feb 18: Fix for vector icons on Mac
LibFredo6 8.1a – 23 Feb 18: maintenance release
LibFredo6 8.0c – 10 Dec 17: release for integration of VRay 3.6 in Animator
LibFredo6 8.0b – 19 Nov 17: release for Animator 1.8b (camera circular interpolation)
LibFredo6 8.0a – 12 Nov 17: release for JointPushPull 4.2a (shading) and Souvenir 1.5a (Favorites)
LibFredo6 7.9a – 02 Nov 17: release for Animator 1.8a (performance improvement)
LibFredo6 7.8d – 01 Nov 17: Fxes for 'hang on exit' issues on MacOS (due to Web dialogs)
LibFredo6 7.8a – 04 Oct 17: release for JointPushPull 4.0
LibFredo6 7.7g – 04 Oct 17: fix problems of loading for OSX High Sierra
LibFredo6 7.7f – 01 Oct 17: fix problems of loading for OSX High Sierra
LibFredo6 7.7e – 19 Sep 17: bug fixing over 7.7d which introduced a bug affecting TopoShaper
LibFredo6 7.7d – 13 Sep 17: bug fixing (in Cross draw) that may affect Animator and some FredoTools plugins
LibFredo6 7.7c – 16 Aug 17: Minor release for support of Hi-resolution screens and implementation of VRay in Animator
LibFredo6 7.7a – 09 Jul 17: Major release for support of Hi-resolution screens, for FredoTools 3.1 and for Animator 1.7
LibFredo6 7.6a – 25 May 17: Major release for Animator 1.6
LibFredo6 7.5b – 13 Feb 17: Fixes in Quick Launchers
LibFredo6 7.5a – 12 Feb 17: Release for Animator 1.5a + cosmetic changes and bug fixing
LibFredo6 7.4c – 16 Jan 17: corrections and support SUClock
LibFredo6 7.4a – 14 Jan 17: Bug fixes and small evolutions
LibFredo6 7.3b – 02 Jan 17: Release re-fixing major bugs in FredoScale for SU2017
LibFredo6 7.3a – 24 Dec 16: Release fixing major bugs in FredoScale for SU2017
LibFredo6 7.2h – 24 Nov 16: Release fixing major bugs in Animator
LibFredo6 7.2g – 20 Nov 16: Release fixing major bugs in Animator (Orbiting and Screw)
LibFredo6 7.2e – 15 Nov 16: Release fixing some issues signalled, impacting Curvizard and Curviloft (due to a bug in G6)
LibFredo6 7.2d – 31 Oct 16: Release fixing major issues preventing proper load of LibFredo6 for SU versions < 2014
LibFredo6 7.2a – 20 Oct 16: Release for Animator
LibFredo6 6.9b – 13 Nov 15: Maintenance release
LibFredo6 6.8c – 16 Jul 15: Fix a blocking bug in FredoTools::Convexify
LibFredo6 6.8b – 09 Jul 15: Major release for RoundCorner 3.0 and FredoTools 2.8 (ReportLabelArea and SolidVoume)
LibFredo6 6.7c – 23 Mar 15: remove noisy traces at startup of Sketchup (second trial)
LibFredo6 6.7b – 22 Mar 15: remove noisy traces at startup of Sketchup
LibFredo6 6.7a – 25 Feb 15: major release for FredoTools::AutoReverseFaces and FredoTools::Convexify in FredoTools 2.6
LibFredo6 6.6b – 18 Jan 15: Some bug fixing in some FredoTools plugins
LibFredo6 6.6a – 10 Jan 15: Release for FredoTools::ElementStats 1.0a (Statistics about entities in the model)
LibFredo6 6.5a – 30 Dec 14: Release for TopoShaper 2.0 (Terrain from Cloud of Points)
LibFredo6 6.4a – 17 Nov 14: Release for AngleInspector, part of FredoTools v2.4
LibFredo6 6.3a – 19 Oct 14: Release for support of non-ascci usernames in SU14
LibFredo6 6.2a – 12 Oct 14: Release for EdgeInspector 1.2 and various fixes, including installation with non-ascii usernames
LibFredo6 6.1b – 22 Sep 14: Republishing due to a possible issue with encoding of main rb file
LibFredo6 6.1a – 21 Sep 14: Release for VisuHole 1.0
LibFredo6 6.0b – 16 Jul 14: Release for the support of Section Planes in MoveAlong 1.2 and DrawAlong 1.1.
LibFredo6 6.0a – 18 Jun 14: Release for FredoTools 2.0a with MoveAlong 1.2 and DrawAlong 1.1, with fixes and new functions
LibFredo6 5.9b – 17 May 14: Release for FredoTools 1.9a with MoveAlong 1.1 and DrawAlong 1.0, with a fix for input of architectural units in VCB
LibFredo6 5.9a – 15 May 14: Release for FredoTools 1.9a with MoveAlong 1.1 and DrawAlong 1.0.
LibFredo6 5.8c – 17 Apr 14: Release for FredoTools 1.8c and MoveAlong 1.0c.
LibFredo6 5.7a – 15 Feb 14: Release for FredoTools 1.7 and EdgeInspector 1.1a.
LibFredo6 5.6a – 03 Feb 14: Release Curvizard 1.6 and other bug fixing.
LibFredo6 5.5g – 24 Jan 14: Release mainly for EdgeInspector 1.0 .
LibFredo6 5.4b – 08 Nov 13: Release mainly for TopoShaper 1.1 (for Altitude Editor) and future Sketchup compatibility - with some bug fixing.
LibFredo6 5.3h – 29 Oct 13: Release mainly for JointPushPull 3.0 - Interactive Edition and future Sketchup compatibility - with some bug fixing.
LibFredo6 5.3g – 27 Oct 13: Release mainly for JointPushPull 3.0 - Interactive Edition and future Sketchup compatibility
LibFredo6 5.2a – 30 Aug 13: Same as 5.1 but implements a change of name for the top file (Fredo6_!LibFredo6.rb instead of LibFredo6.rb).
LibFredo6 5.1c – 22 Aug 13: Same as 5.1a but fixes a wrong publishing of 5.1b
LibFredo6 5.1b – 22 Aug 13: Same as 5.1a but fixes a bug preventing Check For Update to display
LibFredo6 5.1a – 22 Aug 13: Release introducing a new naming convention for files and folders (again), to comply with the Extension Warehouse.
LibFredo6 5.0c – 06 Jul 13: Major release introducing a new naming convention for files and folders.
LibFredo6 4.9c – 20 May 13: Technical release still related to issues on Mac platforms.
LibFredo6 4.9b – 19 May 13: Technical release related to issues on Mac platforms.
LibFredo6 4.9a – 18 May 13: Release for Curvizard 1.2 with various fixes.
LibFredo6 4.8a – 25 Apr 13: Release for TopoShaper.
LibFredo6 4.7c – 09 Apr 13: Minor update related to a bug in Sketchup versioning.
LibFredo6 4.7a – 03 Oct 12: Release for Curvizard 1.1
LibFredo6 4.6e – 03 Oct 12: Minor release to fix a problem in Check for Updates, due to change of URL scheme of the new Sketchucation web site. Version 4.6d had a problem.
LibFredo6 4.6d – 03 Oct 12: Minor release to fix a problem in Check for Updates, due to change of URL scheme of the new Sketchucation web site.
LibFredo6 4.6c – 11 Jul 12: Major release for Curvizard
LibFredo6 4.5a – 08 May 12:
• Update for ThruPaint 1.2 to support some evolutions.
• Additional features for the Free Rotate tool of FredoScale
LibFredo6 4.4m – 14 Apr 12: Small update for ThruPaint adjustments. Integration of the Chinese (thanks to guanjin) and two Spanish translations (thanks to Defisto and Oxer)
LibFredo6 4.4j – 11 Apr 12: Release for ThruPaint
LibFredo6 4.3c – 31 Jan 12: fixed a small issue with environment variables not properly set on some Mac configuration.
LibFredo6 4.3b – 22 Dec 11: fixed a bug in the display of numeric buttons in Palettes (invisible in Curviloft) and added the updated Spanish translation (many thanks to Defisto).
LibFredo6 4.3a – 19 Dec 11: This release is necessary for FredoTools 1.0.
LibFredo6 4.2a – 16 Sep 11: This release finally addresses the issues of security with Webdialogs on Safari 5.0.6 and higher, as well as a few other bug fixing.
LibFredo6 4.1a – 11 Sep 11: This release was supposed to solve the issues with Webdialogs on Safari 5.0.6 and higher, but did not really.
LibFredo6 4.0a – 23 Aug 11: major technical release. LibFredo6 is responsible for the loading of my plugins (no more use of ZLoader__xx.rb files). This should minimize errors at installation. Version 4.0 also includes some utilities for plugin maintenance (Purge obsolete files, performance at load time, trace logging)
LibFredo6 3.7c – 07 Jun 11: minor maintenance release (issues in Check for Update). It also includes an update to Italian translation by COSEDIMARCO and Spanish translation by Defisto
LibFredo6 3.7b – 22 Apr 11: This includes a small fix to avoid double loading of LibFredo6 in all situations
LibFredo6 3.7a – 17 Apr 11: This release includes the Check Plugins for Update feature, as well as some fixes in the Web dialogs. It is also required for SUClock 1.1
LibFredo6 3.6b – 13 Jan 11: This release is mainly to support Curviloft 1.1 and fix a few issues with SU8. It also includes the support of a two-phase loading mechanism for some of my scripts. Note: if you downloaded 3.6a, please upgrade to 3.6b or higher because there was a small bug in the Skinning for Curviloft.
LibFredo6 3.4c – 06 May 10: Stable version
