LordOfTheToolbars    v4.0a
Overview of LordOfTheToolbars
REQUIREMENTS:
  • LibFredo6: v16.2a or above
  • Usage: Free for the time being
  • Expiration: 31 Dec 2026
LordOfTheToolbars (LOTT) is an extension helping you to configure your SketchUp workspace, especially when you have a lot of extensions and toolbars..
It includes the following features
  • Vignette Stripe, which is a single toolbar acting as a permanent menu to access any command
  • Master List of all toolbars, extensions and native
  • History of commands, with Fast Navigation
  • Custom toolbars, mixing native and plugin icons
  • Personal Commands (document, folder, menu, ruby script)
  • CleanScreen mode, hiding most visual elements
  • Quick Command Finder, to search among icons and menus
  • Backup, Import and Export of configuration
Installation of LordOfTheToolbars
LordOfTheToolbars is released as a regular RBZ extension file on the Sketchucation Site.
  • Download If your are already logged in.
  • Log in to get it! otherwise, in order to log in or to register to Sketchucation as a new user (this is FREE). Then you will be able to download the RBZ file.
IMPORTANT: Whatever way you choose, you MUST quit and restart Sketchup to get LordOfTheToolbars (and LibFredo6) properly loaded.
  • Language: English
  • Menus: by default, it is installed in Tools > Fredo6 Collection > LordOfTheToolbars...
  • Icon toolbar: LordOfTheToolbars
Credit: all toolbar icons and button images by JClements
Permission to use this software for any purpose, subject to license, is hereby granted
Overview of LOTT
Here is an introduction to main functions of LordOfTheToolbars
Also, a very good presentation by TutorialsUp.
The Vignette Stripe
This video gives details on how to use and configure the Vignette Stripe with the various modes supported.
Command History
This video gives details on how to use the Command History, which is based on: - the History Palette - the History Quick Navigation - the Last Command recall
LordOfTheToolbars v4.0a – 22 Sep 26: Compatibility SU2027
LordOfTheToolbars v3.0c – 03 Jun 26: Tentative bug fixing in relation with D5
LordOfTheToolbars v3.0b – 02 Jun 26: Tentative bug fixing in relation with D5
LordOfTheToolbars v3.0a – 21 Apr 26: Bug fixing and future compatibility
LordOfTheToolbars v2.9c – 20 Dec 24: to address a problem with VRay 7 (mac) and bug in personal scripts
LordOfTheToolbars v2.9a – 13 Dec 24: Tentative fix of an issue preventing VRay 7 to work
LordOfTheToolbars v2.8a – 10 Nov 24: Fix a bug related to the insertion of icons in palettes
LordOfTheToolbars v2.7c – 20 Apr 24: Fix for context menu in palettes
LordOfTheToolbars v2.7b – 07 Apr 24: Fix for shortcuts and cosmetic adjustments for palettes
LordOfTheToolbars v2.7a – 01 Apr 24: For SU2024
LordOfTheToolbars v2.6a – 31 Oct 23: Extension of validity
LordOfTheToolbars v2.5a – 26 Aug 23: For future compatibility
LordOfTheToolbars v2.4a – 29 Nov 22: Bug fixing about the selection contextual menu
LordOfTheToolbars v2.3a – 31 Oct 22: Extension of validity
LordOfTheToolbars v2.2a – 28 Jun 22: Bug fixing
LordOfTheToolbars v2.1a – 14 May 22: Bug fixing and future compatibility
LordOfTheToolbars v2.0a – 24 Feb 22: Adjustments for notification at startup
LordOfTheToolbars v1.8d – 02 Feb 22: Bug fixing related to palette shortcuts
LordOfTheToolbars v1.8a – 31 Jan 22: Bug fixing related to ghosted icons, line breaks and import in SU2022
LordOfTheToolbars v1.7a – 09 Jan 22: Bug fixing related to shortcuts and palette popping up
LordOfTheToolbars v1.6c – 08 Jan 22: Additional option for making or not the Palettes sticky with the Sketchup window and fix for shortcuts
LordOfTheToolbars v1.6b – 06 Jan 22: Option for making or not the Vignette Stripe sticky with the Sketchup window
LordOfTheToolbars v1.6a – 27 Nov 21: Adjustments for future compatibility
LordOfTheToolbars v1.5b – 20 Sep 21: Extend the maximum width of palettes to 5000 pixels
LordOfTheToolbars v1.5a – 17 Sep 21: Rework of the Import, Compact palettes, Synchronization Sketchup instances and bug fixing
LordOfTheToolbars v1.4d – 10 Jul 21: Bug fixing and small adjustments
LordOfTheToolbars v1.4c – 08 Jul 21: Bug fixing and small adjustments
LordOfTheToolbars v1.4b – 07 Jul 21: Fixed a bug where Import dialog would appear when using the menu for options
LordOfTheToolbars v1.4a – 06 Jul 21: More options as well as bug fixing and adjustments
LordOfTheToolbars v1.3e – 04 Jun 21: Other bug fixing and adjustments
LordOfTheToolbars v1.3c – 03 Jun 21: Force palette to drop down within screen horizontally and reset position of vignette stripe
LordOfTheToolbars v1.3a – 02 Jun 21: Initial public release
