Welcome to SketchUcation
Join a growing community and resource center for SketchUp Design Professionals
  • Access over 800 SketchUp Extensions
  • Learn with over 500,000 SketchUp users
  • Browse hundreds of SketchUp Models, Materials and Styles
  • Upgrade your account to access savings and discounts
Let's get better at design together!
  • Speed up your renderings and visualisations
    ViewSelect for SketchUp
    ViewSelect for SketchUp analyses your model and replicates the visible geometries or hides the invisible ones, cutting down rendering time while keeping your scene looking perfect.
    No more wasting resources on geometry you will never see—just faster, cleaner, and smoother results.
    Perfect for pros who want maximum performance with zero hassle!
    Download Trial
    Read more...
  • 25% off PlaceMaker for February
    PlaceMaker 25% off February 2025
    PlaceMaker lets you kick off your 3D projects in SketchUp and Revit by easily adding Google Earth data, high-res aerials from Nearmap and Hexagon, and detailed 3D models.
    PlaceMaker subscriptions and renewals will be 25% OFF during the month of February.
    PlaceMaker gives you everything from terrains to roads and buildings, making it simple to create detailed cityscapes in minutes. Jump into instant 3D modeling and revolutionize your design work.
    Get Discount
    Read more...
  • Lightbeans for SketchUp Released
    Lightbeans.com catalog, North America's largest 3D texture library, is now accessible through a dedicated SketchUp plugin.
    The extensive collection of thousands of free, high-resolution 3D textures, featuring real building materials from top manufacturers across the United States and Canada, is already available on Lightbeans.com.
    Download
    Read more...
  • SketchFx 4.0 for SketchUp Released
    SketchFX 4.0 Released
    SketchFX 4.0 introduces new features and improvements. From the new Style Transfer effect to Improved GUI there's lots to consider.
    Looking to add fast visualization effects and animation to SketchUp?
    10 Day Trial
    Read more...
  • Rayscaper Alpha - A new rendering extension for SketchUp
    Rayscaper Alpha for SketchUp
    We are excited to see the release of Rayscaper for SketchUp into public alpha-testing. If you want to partake just download and install and give it a test.
    Still very earlier in development but already a robust and performative CPU based rendering solution made for SketchUp users. Easily add HDRIs and PBR materials from Polyhaven or load your own PBR materials.
    Download
    Read more...
  • Import and Optimize 3D models in SketchUp with FluidImporter Pro
    FluidImporter Pro is a SketchUp extension that quickly imports many different 3d model file formats into SketchUp.
    Need to import models at blazing fast speeds from Blender into SketchUp? Got a high polygon OBJ file you need to poly-reduce? Or maybe a Rhino file to you need to remesh?
    Read more...
  • 1-Click Renderings with AmbientOcclusion
    Ambient Occlusion base render in SketchUp
    Creating compelling images in SketchUp using the latest AmbientOcclusion extension for SketchUp. One-click rendering or delve deeper for realism.
    If you are new to rendering in SketchUp or need a tool that integrates with SketchUp and is quick and easy then give it a try!
    Download Trial
    Read more...
  • 7 Tips to get started with SketchUp Free
    Whether you’re a hobbyist wanting to use SketchUp for personal projects or a design professional wanting to try SketchUp Free before investing in SketchUp Pro, Go2School created a video to help you get started.
    In the video, they show you how to access the web-based SketchUp Free, the right way to use the drawing, editing & navigation tools, and how to avoid the things that often trip up self-taught SketchUp users.
    Read more...
  • SketchPlus Released
    SketchPlus for SketchUp
    SketchPlus for SketchUp is an extension that adds a large number of easy-to-use tools, many of which are inspired by existing popular free plugins or are commonly found in other 3D modeling applications.
    Read on for all the details of SketchPlus or give it free 15 day trial.
    Free Trial
    Read more...
  • New VR Plugin for SketchUp
    Simlab SketchUp VR Plugin
    SimLab Soft just released the new VR plugin for SketchUp, it allows the creation of interactive VR experiences from inside SketchUp, and to share them with others in one click.
    Read more...
"...I would just like to thank each and every contributor to this forum, be it by Plugin, Texture, Technique, Model or just a kind word of encouragement, you have all made this the true SketchUp forum..." - rspierenburg
Latest Gallery Entries
  • Cafe 1600 Pixero
  • Barrister Bookcase Barry Mills
  • Fire Hall Poster Daniel Scott Cooter
  • Passive Home Window Cotty
