Welcome to SketchUcation
Join a growing community and resource center for SketchUp Design Professionals
  • Access over 800 SketchUp Extensions
  • Learn with over 500,000 SketchUp users
  • Browse hundreds of SketchUp Models, Materials and Styles
  • Upgrade your account to access savings and discounts
Let's get better at design together!
Ad banner place
  • Speed up your renderings and visualisations
    ViewSelect for SketchUp
    ViewSelect for SketchUp analyses your model and replicates the visible geometries or hides the invisible ones, cutting down rendering time while keeping your scene looking perfect.
    No more wasting resources on geometry you will never see—just faster, cleaner, and smoother results.
    Perfect for pros who want maximum performance with zero hassle!
    Download Trial
    Read more...
  • 25% off PlaceMaker for February
    PlaceMaker 25% off February 2025
    PlaceMaker lets you kick off your 3D projects in SketchUp and Revit by easily adding Google Earth data, high-res aerials from Nearmap and Hexagon, and detailed 3D models.
    PlaceMaker subscriptions and renewals will be 25% OFF during the month of February.
    PlaceMaker gives you everything from terrains to roads and buildings, making it simple to create detailed cityscapes in minutes. Jump into instant 3D modeling and revolutionize your design work.
    Get Discount
    Read more...
  • Lightbeans for SketchUp Released
    Lightbeans.com catalog, North America's largest 3D texture library, is now accessible through a dedicated SketchUp plugin.
    The extensive collection of thousands of free, high-resolution 3D textures, featuring real building materials from top manufacturers across the United States and Canada, is already available on Lightbeans.com.
    Download
    Read more...
  • SketchFx 4.0 for SketchUp Released
    SketchFX 4.0 Released
    SketchFX 4.0 introduces new features and improvements. From the new Style Transfer effect to Improved GUI there's lots to consider.
    Looking to add fast visualization effects and animation to SketchUp?
    10 Day Trial
    Read more...
  • Rayscaper Alpha - A new rendering extension for SketchUp
    Rayscaper Alpha for SketchUp
    We are excited to see the release of Rayscaper for SketchUp into public alpha-testing. If you want to partake just download and install and give it a test.
    Still very earlier in development but already a robust and performative CPU based rendering solution made for SketchUp users. Easily add HDRIs and PBR materials from Polyhaven or load your own PBR materials.
    Download
    Read more...
  • Import and Optimize 3D models in SketchUp with FluidImporter Pro
    FluidImporter Pro is a SketchUp extension that quickly imports many different 3d model file formats into SketchUp.
    Need to import models at blazing fast speeds from Blender into SketchUp? Got a high polygon OBJ file you need to poly-reduce? Or maybe a Rhino file to you need to remesh?
    Read more...
  • 1-Click Renderings with AmbientOcclusion
    Ambient Occlusion base render in SketchUp
    Creating compelling images in SketchUp using the latest AmbientOcclusion extension for SketchUp. One-click rendering or delve deeper for realism.
    If you are new to rendering in SketchUp or need a tool that integrates with SketchUp and is quick and easy then give it a try!
    Download Trial
    Read more...
  • 7 Tips to get started with SketchUp Free
    Whether you’re a hobbyist wanting to use SketchUp for personal projects or a design professional wanting to try SketchUp Free before investing in SketchUp Pro, Go2School created a video to help you get started.
    In the video, they show you how to access the web-based SketchUp Free, the right way to use the drawing, editing & navigation tools, and how to avoid the things that often trip up self-taught SketchUp users.
    Read more...
  • SketchPlus Released
    SketchPlus for SketchUp
    SketchPlus for SketchUp is an extension that adds a large number of easy-to-use tools, many of which are inspired by existing popular free plugins or are commonly found in other 3D modeling applications.
    Read on for all the details of SketchPlus or give it free 15 day trial.
    Free Trial
    Read more...
  • New VR Plugin for SketchUp
    Simlab SketchUp VR Plugin
    SimLab Soft just released the new VR plugin for SketchUp, it allows the creation of interactive VR experiences from inside SketchUp, and to share them with others in one click.
    Read more...
The "Align view" method
Although it only provides the basic options, often the fastest and easiest way to align the tools is to orbit into a viewing angle where it auto-aligns itself to any of the major planes. Below you can see that when we are in top view and looking down to the red/green plane, the Rotate tool will display in blue (as it's now perpendicular to the blue axis).
top-view
Likewise, it is red when we are in front (or back) view and green when we are in either of the side views.
front-view
side-view
If we are "tricky" enough, we can even find an angle where all three (or at least two) "views" come in automatically and when hovering over empty space in different parts of the model window, we can get any of the alignments with the Rotate or Protractor tools.
all-views
Unfortunately, this method is often hard to use though as there is often some geometry in the way and the tools can easily be "distracted" and infer to the geometry instead of the SketchUp space though once you get the proper alignment anywhere, you can press the Shift key to lock the tool (Shift is a general tool for locking inferences) and now you can move it elsewhere - it will keep its alignment.
This "align vew" method can be used with the Circle, Polygon and Rectangle tools as well.
The "Align to object" method
What is a "drawback in the above method, can be utilized in this one however. Once the Rotate tool is hovering over any geometry (face), it tries to "align itself" to that face. This way, we can not only align to the major planes as above but to slanting faces, too. When a face is aligned to these planes, we shall still see the coloured protractor of the tool but on other faces, it will turn black.
align-object
Of course, you can also use the Shift key inference locking now - so get the alignment from any geometry, press the Shift key and only then click with the Rotate tool to start the rotation.
This "align to object" method can also be used with the Circle and Polygon tools though not with the Rectangle tool.
The "Click-drag" method
Seemingly a bit convoluted method but with a little bit of practising, anyone can easily align the Rotate tool in any arbitrary directions even if there is not geometry to infer with (say you draw a face on the ground plane and want to rotate it into a vertical position). The method goes this way:
  1. Preselect the geometry you want to rotate (this is more important with this method than with any of the above).
  2. Select the Rotate (or Protractor) tool and click on a point that is on the desired axis of rotation. Do not release the left mouse button!
  3. Now while still holding the left mouse button, start dragging the cursor in any direction you want. It can be an opposite endpoint (you can snap to), an edge on the geometry, a guide line - anything.
  4. You will notice that the protractor aligns itself perpendicular to the direction you are dragging the cursor. Now release the left mouse button; the tool is "stuck" in the position you forced it to.
  5. Start rotating as normally.
Some screenshots of different orientations of the Rotate tool - and different inference methods (edges, guide) used.
click-drag-1
click-drag-2
click-drag-3
Now there is certainly no need to lock the tool with the Shift key any more as it is auto-locked already.
This "Click-drag" method cannot be used with any of the Circle, Polygon or Rectangle tools.
Latest Gallery Entries
  • Cafe 1600 Pixero
  • Barrister Bookcase Barry Mills
  • Fire Hall Poster Daniel Scott Cooter
  • Passive Home Window Cotty
