Welcome to SketchUcation
Join a growing community and resource center for SketchUp Design Professionals
  • Access over 800 SketchUp Extensions
  • Learn with over 500,000 SketchUp users
  • Browse hundreds of SketchUp Models, Materials and Styles
  • Upgrade your account to access savings and discounts
Let's get better at design together!
Ad banner place
  • Speed up your renderings and visualisations
    ViewSelect for SketchUp
    ViewSelect for SketchUp analyses your model and replicates the visible geometries or hides the invisible ones, cutting down rendering time while keeping your scene looking perfect.
    No more wasting resources on geometry you will never see—just faster, cleaner, and smoother results.
    Perfect for pros who want maximum performance with zero hassle!
    Download Trial
    Read more...
  • 25% off PlaceMaker for February
    PlaceMaker 25% off February 2025
    PlaceMaker lets you kick off your 3D projects in SketchUp and Revit by easily adding Google Earth data, high-res aerials from Nearmap and Hexagon, and detailed 3D models.
    PlaceMaker subscriptions and renewals will be 25% OFF during the month of February.
    PlaceMaker gives you everything from terrains to roads and buildings, making it simple to create detailed cityscapes in minutes. Jump into instant 3D modeling and revolutionize your design work.
    Get Discount
    Read more...
  • Lightbeans for SketchUp Released
    Lightbeans.com catalog, North America's largest 3D texture library, is now accessible through a dedicated SketchUp plugin.
    The extensive collection of thousands of free, high-resolution 3D textures, featuring real building materials from top manufacturers across the United States and Canada, is already available on Lightbeans.com.
    Download
    Read more...
  • SketchFx 4.0 for SketchUp Released
    SketchFX 4.0 Released
    SketchFX 4.0 introduces new features and improvements. From the new Style Transfer effect to Improved GUI there's lots to consider.
    Looking to add fast visualization effects and animation to SketchUp?
    10 Day Trial
    Read more...
  • Rayscaper Alpha - A new rendering extension for SketchUp
    Rayscaper Alpha for SketchUp
    We are excited to see the release of Rayscaper for SketchUp into public alpha-testing. If you want to partake just download and install and give it a test.
    Still very earlier in development but already a robust and performative CPU based rendering solution made for SketchUp users. Easily add HDRIs and PBR materials from Polyhaven or load your own PBR materials.
    Download
    Read more...
  • Import and Optimize 3D models in SketchUp with FluidImporter Pro
    FluidImporter Pro is a SketchUp extension that quickly imports many different 3d model file formats into SketchUp.
    Need to import models at blazing fast speeds from Blender into SketchUp? Got a high polygon OBJ file you need to poly-reduce? Or maybe a Rhino file to you need to remesh?
    Read more...
  • 1-Click Renderings with AmbientOcclusion
    Ambient Occlusion base render in SketchUp
    Creating compelling images in SketchUp using the latest AmbientOcclusion extension for SketchUp. One-click rendering or delve deeper for realism.
    If you are new to rendering in SketchUp or need a tool that integrates with SketchUp and is quick and easy then give it a try!
    Download Trial
    Read more...
  • 7 Tips to get started with SketchUp Free
    Whether you’re a hobbyist wanting to use SketchUp for personal projects or a design professional wanting to try SketchUp Free before investing in SketchUp Pro, Go2School created a video to help you get started.
    In the video, they show you how to access the web-based SketchUp Free, the right way to use the drawing, editing & navigation tools, and how to avoid the things that often trip up self-taught SketchUp users.
    Read more...
  • SketchPlus Released
    SketchPlus for SketchUp
    SketchPlus for SketchUp is an extension that adds a large number of easy-to-use tools, many of which are inspired by existing popular free plugins or are commonly found in other 3D modeling applications.
    Read on for all the details of SketchPlus or give it free 15 day trial.
    Free Trial
    Read more...
  • New VR Plugin for SketchUp
    Simlab SketchUp VR Plugin
    SimLab Soft just released the new VR plugin for SketchUp, it allows the creation of interactive VR experiences from inside SketchUp, and to share them with others in one click.
    Read more...
Subdividing the face(s)
UV-bending0
Our first step is to draw a single face or a rectangular prism that we want to "bend" as an arch later. We "subdivide" this face/prism simply by copying the bottom (or top) edge(s) in a linear array along the dace/prism, distributing the copies evenly. The reason we need to do this is that UV Toolkit need to have exactly the same amount of faces to copy - and then to paste - the UV informtion later so we have to have these faces prepared already before bending.
At this stage, we can already soften these dividing edges (like in the picture where you can see them dotted selected) but it can also be done at the end.
Remembering UV's
UV-bending1
Now select all the face(t)s, go to the Plugins menui > UV Toolkit > Remember UV menu item. This will make sure that adter the bending (and restoring the UV co-ordinates), the texture will "stick" to where it is now.
Bending the Arch
UV-bending2
Now use FredoScale Radial bending to bend the arch. Make sure that "Slicing" is off (right click with the tool and see the menu item there - or use the TAB key to launch the dialog). This is extremely important because if slicing is on, FredoScale will further subdivide the shape and we will end up with a different number of faces than what we began with and the UV Restore function will not work.
It is enough to bend 90 degrees as we can mirror the half arch later.
Restoring UV's
UV-bending3
At this point, our texturing does not show too much. We need to restore those UV co-ordinates that we "remembered" in Step 2. Select all the faces again, go to the Plugins menu > UV Toolkit > Restore UV. If everything goes well, you should end up with something like this:
UV-bending4
If you missed to subdivide the shape before applying the UV Toolkit plugin but have slicing turned off in FredoScale, your resulting shape and its texuring will look something like this:
UV-bending6
If you want to UV map some more complex shape like a tube, also make sure to even triangulate the faces after the initial subdivision as it is almost sure that some additional faces will be created during bending. There are several plugins to do this, like this one or this one for instance. Here is an example of a cylinder bent:
UV-bending7
Another example with a bent and twisted shape perfectly maintaining its UV mapping after restoring (triangulation is also needed here):
UV-bending8
Finally an example of a candy cane model in the 3D Warehouse (I think the stripes are a bit dense there but you get the idea).
Most rendering engines do not handle materials distorted in SketchUp and/or the exporters often "explode" these distorted materials into zillions of small pieces which makes it imposible to tweak them in 3rd party applications. If you are planning to render your model or export it as dae, fbx and such, make sure to always triangulate from the very beginning because this will export the materials in one, manageable piece.Twilight Render and Thea Render handles these distorted materaisl without any unnecessary triangulation however.
Latest Gallery Entries
  • Cafe 1600 Pixero
  • Barrister Bookcase Barry Mills
  • Fire Hall Poster Daniel Scott Cooter
  • Passive Home Window Cotty
