FredoCorner v2.7a
Overview of FredoCorner
- LibFredo6: v14.3b or above
- Free Trial period (full features): 15 days from activation
- Perpetual license (3 seats): $30 (~28€)
- Rush license (3 seats, valid 21 days from purchase date): $8 (~7€)
FredoCorner performs the rounding of the edges and corners of 3D shapes along a 2D profile, in 4 modes: Round, Bevel, Subdivision Mesh and Chop Corner. FredoCorner also includes a Repair tool to undo any generated shape rounding.
FredoCorner does not replace my previous plugin RoundCorner, which will remain supported separately. FredoCorner will become a paid plugin is a few months. It is Free for the time being.
Compared with RoundCorner, FredoCorner is based on a different algorithm and includes additional features, in particular:
- Handle more complex shapes, with triangulation at vertices
- Subdivision mesh
- Repair / Undo / redo
- Preview mode
- Asymmetrical offset
- Variable offset along borders
- Round or bevel corners only
- Works across boundaries of groups and Components
- Corners are symmetrical
- Editable corner profiles with Squircles and Bezier
- Two Offset modes: Offset (measured along faces) and Radius (tangent circle)
- More types of corner geometries are supported
Here is a video by Aaron, member of the Sketchup team, introducing the main features.
There are also two good introduction videos by TheSketchupEssentials (Justin Geis)
Installation of FredoCorner
FredoCorner is released as a regular RBZ extension file on the Sketchucation Site.
IMPORTANT: Whatever way you choose, you MUST quit and restart Sketchup to get FredoCorner (and LibFredo6) properly loaded.
- Language: English, French, Spanish partial (byOxer) , Chinese partial (by Arc) - thanks to all kind translators
- Menus: by default, it is installed in Tools > Fredo6 Collection > FredoCorner...
- Icon toolbar: FredoCorner
Overview of the User Interface
Here is an introduction to the User Interface of FredoCorner, in particular:
- the Button Palette
- the Selection of edges
- the Preview mode
- the Generation of the final geometry
Some element of the user interface (Profile editor, Repair, Variable offset) will be documented in separate videos.
Working across the boundary of Components and Groups
FredoCorner works across the boundaries of Groups and Components at any level. The offset is however always specified in top-level model coordinates. So, this imposes to take a few precautions when you have several instances of components.
Chop Corner
This tool, introduced with FredoCorner 1.3, performs the rounding or beveling of corners only.
there is also a short video by TutorialsUp
Offset Mode
As of FredoCorner 1.2, two offset modes are supported:
1) OFFSET: offset is measured on border faces, perpendicularly. This gives a global uniform rounding of shapes
2) RADIUS: offset is computed based on a circle of specified radius which is tangent to the border faces. The offset is therefore dependent on the angle at each individual edges. If the angle is lower than 90 degrees, the rounding will appear larger in width, or smaller if the angle is greater than 90 degrees. Visually, the rounding of a shape may end up with non uniform rounding.
Variable Offsets
FredoCorner supports 2 modes for variable offsets, that is the capability to assign to borders different offsets
- Border offset: change of the offset along a border, creating asymmetrical rounding
- Corner offset: change of the offset at a corner, creating non uniform rounding along a border
Variable offsets can be edited interactively in Selection mode and in Preview mode
NO documentation at the moment. This will come!
FredoCorner 2.7a - 31 Mar 24: Future compatibility
FredoCorner 2.6a - 25 Dec 22: Suppression of date of validity
FredoCorner 2.5a - 16 Jan 22: Technical adjutsments and extension of validity
FredoCorner 2.4a - 28 May 21: Technical adjutsments and extension of validity
FredoCorner 2.3a - 27 Jan 21: Move to license scheme
FredoCorner 2.2a - 06 Jan 21: Extension of validity
FredoCorner 2.1b - 02 Dec 20: Prevents to set the number of segments to 0
FredoCorner 2.1a - 19 Nov 20: Fixed bugs in Orbit/Pan (Windows) and extension of validity
FredoCorner 2.0a - 19 Aug 20: Improvement to Orbit/Pan (Windows) and extension of validity
FredoCorner 1.9a - 19 Jun 20: Fix bug in Repair::Edit and single click for Exit
FredoCorner 1.8b - 28 May 20: Cosmetic adjustments (edge debugging colors)
FredoCorner 1.8a - 26 Apr 20: Correction for bevel and single mode
FredoCorner 1.7d - 18 Feb 20: extension of validity
FredoCorner 1.7c - 21 Dec 19: extension of validity
FredoCorner 1.7b - 02 Nov 19: bug fixing
FredoCorner 1.7a - 20 Jun 19: Extends validity + etm
FredoCorner 1.6c - 20 Jun 19: Extends validity
FredoCorner 1.6b - 18 Apr 19: Fix bugs and extend validity
FredoCorner 1.6a - 20 Feb 19: Fix debugging limitations in Catena computations
FredoCorner 1.5c - 14 Feb 19: Fix a bug when pre-selecting multiple groups, among which some are freshly copied
FredoCorner 1.5b - 10 Jan 19: Bug fixing and Extension of validity
FredoCorner 1.5a - 18 Dec 18: Extension of validity
FredoCorner 1.4c - 31 Oct 18: Various bug fixing
FredoCorner 1.4b - 31 Oct 18: Bug fixing for Variable Offset editors over 1.4a
FredoCorner 1.4a - 30 Oct 18: Evolution for Variable Offset editors
FredoCorner 1.3b - 24 Oct 18: Bug fixing and adjustments for Chop Corner tool (auto-limit)
FredoCorner 1.3a - 22 Oct 18: Introduces Chop Corner tool + bug fixing
FredoCorner 1.2b - 15 Oct 18: Fixes for Radius offset mode and circle
FredoCorner 1.2a - 14 Oct 18: Introduction of Offset modes
FredoCorner 1.1f - 10 Oct 18: Various bug fixing and GUI adjustments
FredoCorner 1.1e - 23 Sep 18: Bug fixing (variator)
FredoCorner 1.1d - 19 Sep 18: Bug fixing + Full Spanish translation (by Oxer) + Full Chinese (by Arc)
FredoCorner 1.1c - 11 Sep 18: Bug fixing + Full French translation + Partial Chinese (by Arc)
FredoCorner 1.1b - 08 Sep 18: Fix for Orbit Mac, Spanish translation, and Default for Repair Double-click
FredoCorner 1.1a - 06 Sep 18: First public release
