CIVIL WORKS Fit-Out    v1.0.0
CIVIL WORKS Fit-Out is the ultimate B2B SaaS hybrid plugin designed for cabinet makers, interior designers, and woodworkers.
It bridges the gap between your SketchUp 3D design and your factory floor. With a few clicks, you can generate parametric cabinets and instantly extract the exact data to generate: - PRO PDF Quotes based on real-time prices - PDF Cutlists & Assembly Plans - CNC Machine Exports (.CSV) ready for optimization software
Work faster, eliminate manual data entry errors, and get your projects ready for production in minutes.
Quick Start Guide
1. Installation
Install the .rbz file via the SketchUp Extension Manager.
2. Account Creation & API Token
Create your account on our web platform to generate your secure API Token.
3. Connect
Paste this token into the plugin's login field inside SketchUp to link your workspace and unlock all design and export features.
Main Documentation
1. Selecting and Generating Elements
Browse the visual catalog to choose the type of cabinet or element you need.
Adjust the parameters: specify dimensions (Width, Height, Depth), choose materials for the structure and front, and set the number of doors/shelves. Click Generate to insert it into SketchUp.
2. Modifying an Existing Element
Select any CW Fit-Out element in your model to instantly reload its parameters in the UI. Adjust your values and click update.
3. Automated Costing and Sync
Click "Update quantities" to extract data and sync with the server. The plugin instantly generates a detailed table showing materials, dimensions, exact quantities, and estimated prices.
4. Web Dashboard and Production Exports
Save your project to access your secure web dashboard. This is your hub for managing projects and triggering manufacturing exports.
Download production-ready documents instantly: PDF Assembly Plans, Cutlists, Pro Quotes, and raw CSV files formatted perfectly for CNC cutting optimization software (like OptiCut).
Changelog
Version 1.0.0 (Initial Release) * Added parametric 3D generation for cabinets, shelves, and counters. * Integrated live cloud database for automated material costing and quantity takeoff. * Added 1-click generation of PDF Quotes, PDF Cutlists, and Assembly Plans. * Added direct CSV export optimized for CNC machine software. * Enabled native multi-language UI and document support (9 languages). * Added secure API token login system and external web dashboard syncing.
