Urasik    v1.0
Manual: Five tools in one toolbar or in Extensions - Urasik menu.
Merge by Material Full reconstruction for model to export to Unreal Engine, or Rhino and 3ds Max to increase speed in these programs. It merge all RAW geometry by material and put them in individual groups ready to export. It work inside those space where you are now. If you are start it in main space - it takes all model content. Progress is showing in progress bar. Big models can take a lot of time (for example 10 high buildings with detailed facades take 15 minutes on modern computer) .
Ultra Material Change An advanced synthesis of two already existing great plugins Global Material Changer and Material Tools, plus a few of my ideas. Here are functions: 1 - Filtering by lists of replacement and new material 2 - The ability to select materials with a pipette 3 - Work globally or only on selected objects 4 - The ability to isolate the selected by making it unique. At the same time, the connection between the copies of the components inside the selection remains 5 - Rubber web dialog 6 - When selecting the "Unique" mode, the object isolation operation is displayed withe a progress bar Many thanks to authors of GMC and MT.
Height Marker Architectural height marker with an ability to update a position if marked objects are moved and settings of selected marks. Use toolbar button or context menu. Settings of text are in standard SU Model Info > Text, Settings of arrow (user zero, height, width and text gap) are call by Tab button (see status bar bellow viewport). It can be used in 2d projections.
Background Switcher Ability to fast change background color, for example to find holes in a big model like detailed master plans and not to go to Style settings. First set your color in Extension - Urasik - Background Switch - Set Custom Color. It saves in current SU file and toggle by a toolbar button or your hotkey.
Fix Material Name Just transliterates cyrillic characters to Latin
Tested only in SU 2026 on Windows 10/ 11
Initial release
1.0.0
