A-Visual tools v1.0.2
Isolate Globally: Select one or more objects. Click this button to hide everything else in the model, leaving only your selection and its parent elements visible.
Stop Isolation: Click to cancel the global isolation and unhide all objects that were hidden by the previous command.
Multi-Selection Isolate: Enter different groups/components and use the Ctrl key to select desired objects at various levels. Click this button to keep only them and their parent containers visible.
Isolate Selection: Works like a standard isolation tool, hiding objects only within the current active context. Show All in Current Context: Cancels isolation in the current context, similar to SketchUp's built-in Edit > Unhide > All function.
Unhide All Recursively: If nothing is selected, the command will unhide absolutely all hidden objects in the model. If one or more groups/components are selected, the command will unhide all hidden objects only within them.
1.0.2 Redesigned the menu. Add new function - Multi-Selection Isolate: Enter different groups/components and use the Ctrl key to select desired objects at various levels. Click this button to keep only them and their parent containers visible.
