Quick selection    v1.1.0
Selection mode : There are three main options and three other options :
• Start new (default): clears any previous selection and start selecting objects from scratch
• Add to current : adds objects to the current selection
• Remove from current : removes objects from the current selection.
• Invert : inverts the current selection. To use it, just hit the ‘Apply’ button.
• Memorize : saves the current selection internally for further use. A memorized selection is valid for the session or until another selection is memorized.
• Restore : restore a memorized selection, if any.
Buttons : When the ‘Apply’ button is pressed, objects are added/removed to the selection, their count is displayed on top of the dialog. It is also used for inverting, memorizing or restoring a selection When the ‘Done’ button is pressed, the dialog is closed, and the current selection remains.
Please see DBUR_QuickSelectionHelp.pdf in the Resources folder or click on the '?' button of the dialog
New release: Web dialog added for geometrical criteria search French and English versions available More criteria to choose from
