MAJ Wall     v2026
MAJ_Wall is a SketchUp plugin that lets you create walls quickly and accurately. You can define wall thickness, height, and layer structure, then draw walls simply by clicking points in your model. It works seamlessly with other tools in the MAJ Architect suite.
Quick-Start Guide
Choose Wall Settings
Set the wall thickness, height, and other parameters in the plugin panel.
Start Drawing the Wall
Click in the model to set the first point of the wall.
Draw Wall Path
Click additional points to define wall directions and shapes.
Press DoubleClick to finish.
Quick-Start Guide
Open the Plugin Go to the MAJ_Wall tab and open the wall creation panel.
Set Wall Parameters Enter the Wall Height, Wall Thickness, and any layer settings you need.
Start Drawing Click in the model to set the first point of the wall.
Continue the Wall Path Click more points to define the direction and shape of your wall.
Finish the Wall Double-click to complete the wall.
https://youtu.be/tWbC7NOFegE
MAJ_Wall – Plugin Documentation
Version: 2026 Author: Majid Mahmoudi
Overview
MAJ_Wall is a SketchUp plugin designed to create architectural walls quickly and accurately. It allows full control over wall height, thickness, and layer structure, making it suitable for both interior and exterior design. The plugin works standalone or as part of the MAJ Architect suite, where it integrates seamlessly with MAJ Door, MAJ Window, and other tools.
Features
Custom Wall Thickness and Height Specify dimensions before drawing to ensure accuracy.
Multiple Layer Support Create walls with plaster, insulation, structure, or any custom material layers.
Clean Drawing Workflow Draw walls by clicking points directly in your model.
Snap and Alignment Support Automatically aligns with SketchUp inference system for smooth modeling.
Editable After Creation Select the wall anytime to modify thickness, height, or layer structure.
Parameters Setting Description Wall Height The vertical height of the wall. Wall Thickness Total thickness of the solid wall or main layer. Layer Structure Optional extra layers such as plaster or insulation. Offset Options Controls whether the wall grows to one side or centered. Material Assignment Choose materials for each layer. How to Use
Open MAJWall Go to the MAJWall tab and open the control panel.
Set Wall Options Enter your wall height, thickness, and layer choices.
Start Drawing Click anywhere in your model to place the first point.
Continue Drawing the Wall Click additional points to form corners and direction changes.
Working with Other MAJ Plugins
MAJDoor and MAJWindow automatically align to walls created by MAJ_Wall.
The wall becomes temporarily transparent during door and window placement, allowing you to follow 2D plans easily.
Cutting openings is fully automated.
Notes
Walls are grouped automatically to keep your model organized.
Supports both metric and imperial units.
Works in any SketchUp template.
Release Notes – MAJ Wall
New Features
Faster and smoother wall drawing workflow.
Support for multi-layer walls (finish, insulation, core, etc.).
Automatic detection of wall inside/outside direction.
Walls now automatically update their cut openings when using MAJ Door or MAJ Window.
Improvements
More accurate and clean wall geometry.
Improved corner joining and connection handling.
Enhanced snapping and axis detection during drawing.
Better alignment compatibility with MAJ Beam and MAJ Column.
Bug Fixes
Fixed rare corner mismatch in multi-step wall paths.
Corrected texture mapping on long or angled walls.
Reduced lag when working with large models.
