PomPi 2016 (Pompous Piping)    vRC_2018_0521_1631
Main features:
  • Easy to predefine and load your own dimension’s library by CSV file. (examples included)
  • Two-tree clicks to create and orient simple pipe, bend, reducer, flange, union or T.
  • Aided line tool for define your piping path. NEW!
  • Convert all selected edges to bends and pipes. Similar to Pipe Along Path, but “fillet” the connection points by elbow (bends) Not limited to one path. To align connected end segments, pipe elements will be twisted automatically
  • Convert all selected bends and pipes back to edges. NEW!
  • You can create your own CSV file with your preferred standards (ANSI, ASME, ISO EN, JIS…or) whatever you want and determine the dimensions of pipe and fittings with only a click.
  • Handle millimeter and inch
  • Similar pipe elements will be same existing component but other instance.
  • Easy to define cross section (profile) as circle, triangle, square, pentagon, hexagon .... (up to 96 side polygon or circle). You can rotate it too.
  • Generate report about selected PomPi pipe elements, save it to CSV file and show in HTML window. NEW!
  • “Side effect”: PomPi weld! Joins selected edges into a 'curve'. NEW! It is similar to TIG-weld but using different method. You can select more edges loops and all will be converted until branching point(s).
  • Simple, self-explaining user interface. Scalable/resizable html UI.
  • Free!
Basic documentation is included in the plugin, and on the forum.
Link to Forum !
I hope, the UI is self explaining.
Release Notes for PomPi 2016
RC 201805101833 (First Plugin Store release) - You can more flexible insert and rotate PomPi elements - Slightly changed UI, and naming of componets - Some code cleanup, correction.
RC 201805211631 - Bug: can't create BOM if there were T's, has been eliminated. - Small changes to rotate PomPi elements (and other group/component) - Indication of possible bend if the last point==first point in aided draw - More easy to put PomPi's into Pipe center line (xRay if hover on pipe, green color if on centerline)
