Medeek Foundation v2.1.4
The Medeek Foundation extension is a SketchUp Extension that provides a simple interface for creating accurate 3D foundation and footing geometry within SketchUp. This extension utilizes the SketchUp Ruby API programming interface and is compatible with the latest SketchUp releases (SketchUp Make 2017 64-bit and SketchUp Pro 2026 64-bit) as well as previous versions (2017, 2018, 2019, 2020, 2021, 2022, 2023, 2024, 2025).
Currently, the extension allows the creation of the following foundation types (Metric and US/Imperial):
- Slab on Grade (Rectangle, Polygon) [with garage curb, reinforcement, anchor bolts and internal footing options]
- Stemwall (Rectangle, Polygon) [with brick ledge, reinforcement, anchor bolts and internal footing/floor beam/stud wall options]
- Slab (Rectangle, Polygon) [with reinforcement and internal footings]
All foundation types are drawn/designed utilizing industry standard practices. Additional foundation types and footings are in the process of being added. Custom layers can be enabled in the global settings which allow concrete, rebar and wood framing to be placed on specific layers. Rebar/mesh and anchor bolts are now an option. FPSF are also an option for SOG and stemwall foundations. All foundation types are now fully parametric. Unlimited interior footings and slab depressions are available for slab on grade foundations. Brick ledges are also now available for slab-on-grade foundations.
For a quick primer on how the plugin works please view the following tutorial videos:
Tutorial 1 - Extension Overview (14:39 min.) Tutorial 2 - Editing Slab-on-Grade Foundations (10:26 min.) Tutorial 3 - Interior Footings for Slab-on-Grade Foundations (16:33 min.) Tutorial 4 - Slab Depressions for Slab-on-Grade Foundations (9:35 min.) Tutorial 5 - Brick Ledges for Slab-on-Grade Foundations (14:11 min.) Tutorial 6 - Polyline Stemwalls, Steps and Interior Bearings (13:27 min.) {https://youtu.be/QjvxhGXW0}
More tutorials available on the website.
Tutorial 1 - Extension Overview (14:39 min.) Tutorial 2 - Editing Slab-on-Grade Foundations (10:26 min.) Tutorial 3 - Interior Footings for Slab-on-Grade Foundations (16:33 min.) Tutorial 4 - Slab Depressions for Slab-on-Grade Foundations (9:35 min.) Tutorial 5 - Brick Ledges for Slab-on-Grade Foundations (14:11 min.) Tutorial 6 - Polyline Stemwalls, Steps and Interior Bearings (13:27 min.) Tutorial 7 - Blockouts in Polyline Stemwalls (8:35 min.) Tutorial 8 - Windows and Doors in Polyline Stemwalls (8:31 min.) Tutorial 9 - Moving Stemwall Segments (10:20 min.) Tutorial 10 - Subtractive Geometry (15:45 min.) Tutorial 11 - Windows and Doors (13:00 min.) Tutorial 12 - Grade Beams (9:38 min.) Tutorial 13 - Framing Basement Walls (15:17 min.) Tutorial 14 - Managing Anchor Bolts (12:13 min.) Tutorial 15 - Multi-Step Foundations (8:24 min.)
A comprehensive manual is currently being written for this plugin. Estimate completion date is Nov. 2027.
Version 2.1.4 - 04.13.2026
Version 2.1.3 - 03.16.2026
Version 2.0.8 - 03.01.2026, , sub rev. b - 03.02.2026
Version 2.0.6 - 12.24.2025
Version 2.0.3 - 03.23.2025
Version 2.0.2 - 08.07.2024
Version 2.0.1 - 08.01.2024
Version 2.0.0 - 06.27.2024
Version 1.9.9 - 06.06.2024
Version 1.9.6 - 04.20.2024
Version 1.9.5 - 02.13.2024
Version 1.9.4 - 01.07.2024
Version 1.9.3 - 12.16.2023
Version 1.9.2 - 11.30.2023
Version 1.9.1 - 09.26.2023
Version 1.9.0 - 07.11.2023
Version 1.8.9 - 01.11.2023
Version 1.8.8 - 07.31.2022
Version 1.8.7 - 07.31.2022
Version 1.8.5 - 03.20.2022
Version 1.8.4 - 03.16.2022
Version 1.8.3 - 03.10.2022
Version 1.8.2 - 03.03.2022
Version 1.8.1 - 03.02.2022
Version 1.8.0 - 02.13.2022
Version 1.7.9 - 12.24.2021
Version 1.7.8 - 11.11.2021
Version 1.7.7 - 09.18.2021
Version 1.7.6 - 09.14.2021
Version 1.7.5 - 08.04.2021
Version 1.7.4 - 07.10.2021
Version 1.7.3 - 06.12.2021
Version 1.7.2 - 06.03.2021
Version 1.7.1 - 05.20.2021
Version 1.7.0 - 05.09.2021, sub rev. b - 05.09.2021
Version 1.6.9 - 03.25.2021, sub rev. b - 03.26.2021
Version 1.6.8 - 03.14.2021
Version 1.6.7 - 03.07.2021
Version 1.6.6 - 02.12.2021
Version 1.6.5 - 02.09.2021
Version 1.6.4 - 01.11.2021, sub rev. b - 01.14.2021
Version 1.6.3 - 10.22.2020
Version 1.6.2 - 10.09.2020
Version 1.6.1 - 08.31.2020
Version 1.6.0 - 05.28.2020
Version 1.5.9 - 05.15.2020
Version 1.5.8 - 04.27.2020
Version 1.5.7 - 03.04.2020, sub rev. b - 03.05.2020, sub rev. c - 03.05.2020
Version 1.5.6 - 02.11.2020, sub rev. b - 02.16.2020
Version 1.5.5 - 02.06.2020
To view all of the updates to the plugin please visit the Medeek Foundation Changelog:
http://design.medeek.com/resources/foundationpluginchangelog.html
