layer_material_tools    v1.0
Plugins > TIG-layer_material_tools > Options...
Make Materials from Layer Names:
Makes new Materials, named after the Layer names.
If >v2013 the Layers' colors are used for the Materials,
on older versions random-colors are used.
The default-layer name 'Layer0' is not included in the new Material names.
Make Layers from Material Names:
Makes Layers, named after the Material names.
If >v2013 the Materials' colors are used for the Layers.
If a Material is named 'Layer0' it is not included in the new Layer names.
Set Materials from Layer Names:
All Faces and Groups/Components are assigned a Material based on their Layer name.
Nested Faces and Groups/Components are processed.
You should have made Layers based on Material names before using this.
Faces and Groups/Components on the default-layer 'Layer0' are assigned
the default-material.
All backfaces are assigned the defaultmaterial.
Set Layers from Material Names:
All Faces and Groups/Components are assigned a Layer based on their Material name.
You should have made Materials based on Layer names before using this.
Faces and Groups/Components with the default-material are assigned
the default-layer 'Layer0'.
Help:
Opens help dialog [this].
1.0 20141205 First issue.
