FredoTools    v4.5c
Overview of FredoTools
REQUIREMENTS:
  • LibFredo6: v14.3b or above
  • Usage: Free
FredoTools groups a number of my standalone plugins. By delivering them as a single package, it reduces the footprint on Sketchup and avoids individual installation of each plugin:
The main characteristics of FredoTools are:
  • Single folder in the Plugins directory (Fredo6_FredoTools)
  • Single menu entry (by default in Tools > Fredo Tools > ….)
  • Single contextual menu
  • Single toolbar, with control of the icons displayed
  • Quick Launcher
  • Also, only a small part of the plugins is loaded at Sketchup startup (only the menus). The rest of the code is loaded the first time you launch the plugin
Plugins included in FredoTools
DrawAlong Similar to the Sketchup Draw Line tool, but with additional functions
MoveAlong Similar to the Sketchup Move tool, but with additional functions
ThruPaint Paint Faces and/or Edges across the boundaries of groups and components - Interactive painting by click and drag - Several UV modes to apply textures - Interactive positioning and orientation of textures
ReverseOrientFaces Interactively revert and orientate faces - Works across the boundaries of groups and components - Interactive reversal by click and drag - - Manage correctly reversing of textures
EdgeInspector Inspects, and then fixes, some Edge defects in the model, usually coming after DXF imports and Intersections. It currently supports 7 edge defects
ColorBySlope Create a color mapping of a terrain mesh based on the slopes of its faces. You can optionally add a legend and a 2D color map
ColorByAltitude Create a continuous color mapping of a terrain mesh based on the altitude of its faces, based on a single textured material. You can optionally add a set of isocontours, a legend and a 2D color map (for SU2018+)
ColorPaint Configurable Color Selector with Favorites, independent from models and persisted across Sketchup sessions
ColorFlatMode Switch to Flat colors with no shading and colors shown as close as their RGB specifications
AngleInspector Inspect Angles between elements of the model in one click, even if elements are far away. Elements are Faces (normal), Edges, Guide lines, axes (model and local) and axes of polygon / arc.
ReportLabelArea [Report] Build a report of areas by material used in model or selection -Support multiple units and decimal precision
ReportLabelArea [Label] Interactively show and sum the areas of selected elements - Label elements with areas - Support multiple units and decimal precision
ElementStats Provides statistics and information on groups, components and any entity in the model. Statistics are given on the active model (and active context, if within a group or component), the selection (initial, set by the Outliner or interactive selection), entities under the cursor. Information is displayed in a floating palette
DivideEdges Divide and/or Mark Edges and curves from pre-selection or by simple click. Marking is done with Guide Points
AutoReverseFaces Automatically perform the alignment of face orientations as well as their proper orientation on shapes that looks like a solid, that is, where visually you could tell where is the inside and where is the outside.
Convexify Performs the decomposition of 3D shapes into Convex shapes - Can be useful for Physics animation and games
SolidVolume Compute the volume and the total faces area of the true solids (groups and component instances) in the selection - SolidVolume gives the correct value regardless of the orientation of faces and the position in the model.
RevertCurve Revert the direction of selected curves
CurviShear Create ramps by shearing curves
ConstructFaceNormal Put a Guide point at the barycentre of selected faces and a small Guide Line along their normal
MarkVertices Put a Guide point at the vertices of selected faces and edges - Useful to visualize vertices of curves and edge sequences
CountFacesBySides Count the number of faces by number of sides
RemoveLonelyVertices Remove the lonely vertices bordered by 2 colinear edges - These vertices are actually useless in most cases
FaceTriangulator Face Triangulation - based on Delaunay with possibility to add / edit custom triangulation points
Installation of FredoTools
FredoTools is released as a regular RBZ extension file on the Sketchucation Site.
  • Download  If your are already logged in.
  • Log in to get it!  otherwise, in order to log in or to register to Sketchucation as a new user (this is FREE). Then you will be able to download the RBZ file.
IMPORTANT: Whatever way you choose, you MUST quit and restart Sketchup to get FredoTools (and LibFredo6) properly loaded.
  • Sketchup versions: SU2017 and above
  • Language: English, French, Spanish Spain (by Oxer), Spanish Latin America (by Defisto), Chinese (by guanjin)
  • Menus: by default, it is installed in Tools > Fredo Tools…
  • Icon toolbar: Fredo6 Tools
Permission to use this software for any purpose and without fee is hereby granted
FredoTools Quick Launcher
FredoTools Quick Launcher allows to launch any of the FredoTools plugins from the list of plugins, as well as to access their documentation online. The Quick Launcher can be invoked from the toolbar or from menu entry Tools > Fredo Tools > FredoTools Launcher.
The Quick Launcher shows the list of Plugins available. Just click on the plugin name in the list to launch it.
To access the homepage of each plugin on Sketchucation, just click on the documentation button
For convenience the Quick Launcher Window can be pinned and remain visible on the Desktop if you activate the option. Otherwise the Quick launcher window will close when you launch the selected plugin
The Wrench icon gives access to the Default Parameters dialog box, which contains default options for FredoTools as well as a section for each standalone plugin.
Controlling visibility of plugin buttons in the FredoTools toolbar
By default, the icon(s) of individual plugins are not shown in the FredoTools toolbar, in order to save real-estate on the Sketchup window. So, you have to enable manually the visibility of plugin icons. This can be achieved by setting the visibility of icons in the last section of the Default Parameters dialog box. Note that a similar setup applies to the visibility of menu entries of each plugin in the Selection Contextual menu of Sketchup.
Default Parameters for plugins
Some plugins may have Default Parameters, available in the common Default Parameters dialog box of FredoTools. You can invoke the Default Parameters by
  • Menu Tools > Fredo Tools > Default Parameters...
  • Wrench' button in the Quick Launcher window of FredoTools
  • Left-most button in the button palette of some plugins
There is NO documentation for FredoTools at the moment.
However, each individual plugin may have its own documentation available at its home page. With FredoTools quick launcher, you can access the page for each individual plugin by clicking on the small 'book'icon on the right.
There is also a quite comprehensive tutorial on most plugins of FredoTools by Tutorials Up
FredoTools 4.5c – 24 Jun 24: Fix for wrong calculation of volume in SolidVolume
FredoTools 4.5a – 02 Apr 24: Future compatibility
FredoTools 4.4a – 13 Nov 22: Update for SolidVolume (bug and evolutions)
FredoTools 4.3a – 06 Mar 22: Compatibility with a future plugin (ThruPaint)
FredoTools 4.2a – 17 Sep 21: Fixes for Autosmooth in MoveAlong
FredoTools 4.1c – 13 Jul 21: Republishing of version v4.1b
FredoTools 4.1d – 13 Sep 21: Fixes a bug in MoveAlong whereby AutoSmooth was always activated
FredoTools 4.1b – 10 Jul 21: Fixes for major bugs in ColorByAltitude
FredoTools 4.1a – 24 Apr 21: Performance of contextual selection menu
FredoTools 4.0b – 06 Dec 20: For ReportLabelArea auto-refresh option
FredoTools 4.0a – 17 May 20: For ReportLabelArea and first version for SU2017+ only
FredoTools 3.8c – 10 Feb 20: For Solid Volume (sensitivity to face orientation)
FredoTools 3.8b – 05 Feb 20: For ReportLabelArea (count material painted from objects, not just faces)
FredoTools 3.8a – 18 Nov 19: Introduction of ColorFlatMode and bug fixing
FredoTools 3.7a – 02 Nov 19: Evolutions in ColorPaint, ColorByAltitude and ReportLabelArea
FredoTools 3.6a – 16 Oct 19: Introduction of ColorPaint, ColorByAltitude and Outliner view in ReportLabelArea
FredoTools 3.5a – 12 Sep 19: Introduction of ColorBySlope
FredoTools 3.4a – 12 Apr 19: performance when Outliner is open (start_operation)
FredoTools 3.3c – 24 Mar 19: bug fixing for Edge Inspector in SU2019
FredoTools 3.3b – 14 Mar 19: bug fixing for ReportLabelArea in CSV export
FredoTools 3.3a – 21 Oct 18: bug fixing for ReportLabelArea
FredoTools 3.2d – 09 Apr 18: bug fixing for EdgeInspector (Disolve_Edge)
FredoTools 3.2c – 12 Mar 18: bug fixing for SolidVolume
FredoTools 3.2a – 24 Feb 18: bug fixing and FaceTriangulator
FredoTools 3.1e – 01 Oct 17: fix for OSX High Sierra
FredoTools 3.1d – 28 Sep 17: fix for potential bugsplat in ThruPaint
FredoTools 3.1c – 18 Aug 17: fix for non-ascii usernames, DivideEdges pseudo Arc curves and bug fixing
FredoTools 3.1b – 11 Jul 17: fix in SolidVolume
FredoTools 3.1a – 09 Jul 17: introduction of DividedEdges, and bug fixing
FredoTools 3.0c – 13 Feb 17: fix for web dialog sizing
FredoTools 3.0b – 31 Oct 16: Major fix of a bug preventing FredoTools to run for SU versions < 2014
FredoTools 3.0a – 20 Oct 16: Small Evolutions in ThruPaint (Purge)
FredoTools 2.9a – 13 Nov 15: maintenance release
FredoTools 2.8a – 09 Jul 15: release for Solid Volume v1.2a and ReportLabelArea 2.1
FredoTools 2.7e – 29 Apr 15: release for Solid Volume v1.1d
FredoTools 2.7d – 28 Apr 15: release for Solid Volume v1.1c
FredoTools 2.7c – 27 Apr 15: release for Solid Volume v1.1b
FredoTools 2.7a – 26 Apr 15: release for Solid Volume
FredoTools 2.6a – 25 Feb 15: release for AutoReverseFaces and Convexify
FredoTools 2.5c – 19 Jan 15: fix for SU8 (Dimension and syntax)
FredoTools 2.5b – 18 Jan 15: small upgrade to the Release for ElementStats 1.0, and update of translation to Spanish by Oxer
FredoTools 2.5a – 10 Jan 15: Release for ElementStats 1.0
FredoTools 2.4a – 17 Nov 14: Release for AngleInspector
FredoTools 2.2a – 19 Oct 14: Release for support of non-ascii username
FredoTools 2.1a – 12 Oct 14: Release for EdgeInspector 1.2 and fixes in DrawAlong 1.2 about Construction points
FredoTools 2.0b – 07 Jul 14: Release fixing a bug signaled by dedmin in MoveAlong 1.2b
FredoTools 2.0a – 18 Jun 14: Release for DrawAlong 1.1a and MoveAlong 1.2a with fixes and functional evolutions
FredoTools 1.9b – 17 May 14: Release for DrawAlong 1.0b and MoveAlong 1.1b with fix for VCB inputs in architectural units
FredoTools 1.9a – 15 May 14: Release for DrawAlong 1.0 and MoveAlong 1.1
FredoTools 1.8e – 20 Apr 14: Fix problem when selected entities are huge (signaled by rv1974) for MoveAlong 1.0d
FredoTools 1.8c – 17 Apr 14: Release for MoveAlong 1.0
FredoTools 1.7a – 15 Feb 14: Release for EdgeInspector 1.1
FredoTools 1.6g – 24 Jan 14: Release for EdgeInspector
FredoTools 1.5a – 27 Nov 13: Release for future Sketchup Compatibility
FredoTools 1.4a – 30 Oct 13: Release implementing new naming conventions and some bug fixing.
FredoTools 1.2a – 08 May 12: Update for ThruPaint 1.2a (Paint components and groups and bug fixing). See this post
FredoTools 1.1n – 21 Apr 12: Small update for ThruPaint 1.0n (keep track of scaling and rotation factors by material and support of initial selection)
FredoTools 1.1m – 14 Apr 12: Small update for ThruPaint 1.0m fixes and to integrate the Translation in Spanish (Oxer, Defisto) and Chinese (guanjin)
FredoTools 1.1j – 11 Apr 12: Release for ThruPaint and ReverseOrientFaces
FredoTools 1.0b – 20 Dec 11: Contextual Menu entries can be individually removed (via the Default Parameter dialog box)
FredoTools 1.0a – 19 Dec 11: Initial Release
