[Plugin] FredoTools::SolidVolume - v1.5a - 13 Nov 23
Postby fredo6 » Mon Apr 27, 2015 12:57 am
SolidVolume is a standalone script which is part of FredoTools.
It computes the volume and the total faces area of the true solids (groups and component instances) in the selection.
SolidVolume gives the correct value regardless of the orientation of faces and the position in the model.
It is now based on a persistent web dialog box, allowing you to change the selection or use the outliner.
This follows an interesting discussion in this thread.
Select the solids and invoke SolidVolume
  • in the contextual menu FredoTools > SolidVolume
  • in the menu Tools > FredoTools > SolidVolume
  • by clicking on the icon of SolidVolume (barrel)
In this second version, the volume and faces area is displayed in a persistent dialog box. As long as it is open, any change of selection will show the volume and area dynamically. You can choose your preferred units and number of decimals.
SolidVolume is installed as part of FredoTools 3.2c and above.
See the main post for this plugin for Installation of FredoTools
no documentation yet
  • SU Versions: SU2017 and above
  • Platforms: Windows and Mac
  • Languages: English
  • Menus: by default, SolidVolume is installed in Tools > FredoTools. There is also an entry in the Contextual menu.
  • Icon toolbar: Fredo6 Tools. There is only a single icon. By default, it is not shown. You need to go to the Default Parameters… dialog of FredoTools to enable the icon.
  • The plugin is free, for private and commercial usage.
Just launch SolidVolume on a selection containing solids to compute their aggregate volume and the total area of their faces.
The dialog box is persistent so that you can change the selection, manually or via the outliner.
SolidVolume 1.2b – 12 Mar 18: Fix a bug in the calculation of volume (for certain solids where the center is outside the solid)
SolidVolume 1.2a – 09 Jul 15: Solid with holes are considered Solid and you can calculate its volume. Area of faces takes the holes into account
SolidVolume 1.1d – 29 Apr 15: fixes bug for the height of the dialog box
SolidVolume 1.1c – 28 Apr 15: fixes bugs in the calculation of volumes signaled by srx and ken
SolidVolume 1.1b – 27 Apr 15: fixes a small bug in the decimals for area
SolidVolume 1.1a – 27 Apr 15: Second public release in FredoTools 2.7b, with web dialog box and calcuation of faces area
SolidVolume 1.0a – 26 Apr 15: Initial public release in FredoTools 2.7a
fredo6
Premium Member
Premium Member
Re: [Plugin] FredoTools::SolidVolume - v1.0a - 26 Apr 15
Postby pilou » Mon Apr 27, 2015 1:26 am
Cool! :fro:
And about the M2 surfaces faces?
No possibility to add this inside this one?
Top SketchUcator
Postby srx » Mon Apr 27, 2015 10:15 am
Thank you Fredo! You are my hero! :D This should be incorporated in Sketchup 2016 to prevent people for making mistakes in volume calculations..In the meantime we have Fredo Sketchup.
www.saurus.rs
srx
Postby srx » Mon Apr 27, 2015 12:11 pm
I am sorry, but plugin has some kind of problem with the geometry you can see in the example. I didn't know the volume calculation problem was so complex.
www.saurus.rs
srx
Postby fredo6 » Mon Apr 27, 2015 4:58 pm
@srx
That's just a bug which I will fix. As long as the shape is a true solid, there is an exact solution.
Fredo
fredo6
Premium Member
Premium Member
Postby pilou » Mon Apr 27, 2015 6:21 pm
And the model must be made in the rules of art! ;)
Top SketchUcator
Re: [Plugin] FredoTools::SolidVolume - v1.1c - 28 Apr 15
Postby fredo6 » Mon Apr 27, 2015 11:14 pm
NEW RELEASE: FredoTools::SolidVolume v1.1c - 28 Apr 15
SolidVolume 1.1a is a release with a few enhancements:
  • It now computes the faces area of solids in the selection.
  • The volume and areas are shown in a persistent dialog box, allowing you to change the selection and use the outliner.
  • You can choose your preferred unit and number of decimals for display of values
See main post of this thread for more information.
Fredo
fredo6
Premium Member
Premium Member
Re: [Plugin] FredoTools::SolidVolume - v1.1d - 29 Apr 15
Postby fredo6 » Wed Apr 29, 2015 9:20 pm
NEW RELEASE: FredoTools::SolidVolume v1.1d - 29 Apr 15
SolidVolume 1.1d is a release fixing a problem of display of the main dialog box.
Fredo
fredo6
Premium Member
Premium Member
Re: [Plugin] FredoTools::SolidVolume - v1.2a - 09 Jul 15
Postby fredo6 » Thu Jul 09, 2015 3:31 pm
NEW RELEASE: FredoTools::SolidVolume v1.2a - 09 Jul 15
SolidVolume 1.2a is a minor release allowing holes for a shape to be considered as a solid. The Volume is computed as if there was no hole, but the area of faces takes the holes into account.
Fredo
fredo6
Premium Member
Premium Member
Postby Alex37550 » Mon Jul 10, 2017 4:47 pm
Hi Fredo
I was so happy to find this plug in volumes, but it seems there is a problem with the volumes. i had a complex solid an found a volume that seemed very big. So i try with a small cube with an hole (20 cm for each side) and there is definitively a bug. see image
I downloaded the latest versions of LibFredo, FredoTools (09 Jul 17) and that is the same
anyway, thanks a lot Fredo for all your super plugins !
have a good week !
Alexandre
Alex37550
Postby fredo6 » Tue Jul 11, 2017 3:59 pm
Alex37550 wrote:Hi Fredo
You are right. There is definitely a bug and this is annoying.
I fixed it, and will re-release (as soon as the certification on EWH works again).
Fredo
fredo6
Premium Member
Premium Member
Postby Alex37550 » Tue Jul 11, 2017 4:04 pm
thanks for your reactivity !
will you publish a reply when it will be downloadable?
Alex
Alex37550
Postby fredo6 » Tue Jul 11, 2017 10:22 pm
Alex37550 wrote:thanks for your reactivity !
Alex
Just republish, now that EWH certification seems to work again.
Please advise if this fixes your problems.
Fredo
fredo6
Premium Member
Premium Member
Postby Alex37550 » Mon Sep 18, 2017 9:57 am
Alex
Fredo
I have not seen your post.
Thank you Fredo.
I downloaded all new versions of you plug in and solid volumes works now.
Alex
Alex37550
Postby DGR » Thu Mar 08, 2018 3:31 pm
Hi Fredo6
It seems that the bug in solid volume is back
Regards
Dirk
DGR
Re: [Plugin] FredoTools::SolidVolume - v1.2b - 12 Mar 18
Postby fredo6 » Mon Mar 12, 2018 8:51 am
Thanks for signaling. A major bug actually.
Fixed in FredoTools 3.2c.
Fredo
fredo6
Premium Member
Premium Member
Re: [Plugin] FredoTools::SolidVolume - v1.4a - 10 Feb 20
Postby fredo6 » Mon Feb 10, 2020 10:03 am
NEW RELEASE: FredoTools::SolidVolume v1.4a - 10 Feb 20
SolidVolume 1.4a is a major release fixing issues in some situations where faces where not properly oriented.
Fredo
3
fredo6
Premium Member
Premium Member
Postby jure » Sat Nov 11, 2023 2:42 pm
Hi!
Calculation of volume is wrong in certain cases. See attached file.
jure
Postby fredo6 » Sun Nov 12, 2023 11:42 pm
jure wrote:Calculation of volume is wrong in certain cases.
Got it and fixed it. Need some repackaging and will publish soon.
By the way, the main interest of SolidVolume is that it is supposed to work on pseudo solids too, as shown in the video.
fredo6
Premium Member
Premium Member
Postby fredo6 » Mon Nov 13, 2023 1:45 pm
NEW RELEASE: FredoTools::SolidVolume v1.5a - 13 Nov 23
SolidVolume 1.5a is a major release fixing issues in the calculation of volumes in some situations where the solid is scaled. It also adds the capability to compute the volumes of pseudo-solids: objects with multiple solids inside, objects with holes in faces or some mssing faces.
Fredo
fredo6
Premium Member
Premium Member
Return to Plugins
Users browsing this forum: suehanfrank and 19 guests
