FredoScale v3.6a
Overview of FredoScale
- LibFredo6: v14.3b or above
- Free Trial period (full features): 30 days from first usage
- Perpetual license (3 seats): $15
- Fredo6Bundle2022 license (8 plugins): $50
With FredoScale you can orientate the selection box around a set of objects and interactively apply a number of geometric transformations, such as Scaling, Tapering, Stretching, Planar Shear, Twisting, Bending and Rotation. By extension, some transformations can be performed without a selection box.
Installation of FredoScale
FredoScale is released as a regular RBZ extension file on the Sketchucation Site.
IMPORTANT: Whatever way you choose, you MUST quit and restart Sketchup to get FredoScale (and LibFredo6) properly loaded.
- Language: English, French and partial in Spanish, German, Italian, Korean, Chinese, Japanese (thanks to the kind translators)
- Menus: by default, it is installed in Tools > Fredo6 Collection > FredoScale…
- Icon toolbar: NO Toolbar
Generic usage of FredoScale
Here is generic way to use the plugin for all tools:
- Select one or several objects (faces, edges, groups or components)
- Click on the icon of one tool, for instance Scaling
- You can orientate the selection box:
- Arrow Up will align on model axes
- Arrow Left and Arrow Right will cycle through axes of components at highest level
- Arrow Down will restore the initial alignment when selecting
- Gently click and drag on the handles to perform the deformation. Toggle the CTRL key to perform the deformation from the center.
- You can type relevant values in the VCB or via a dialog box (TAB key)
For Twist and Bend, F4 toggles a Slicer on and off
For Stretch, F4 toggles a Divider on and off
It is a good idea to check the contextual menu to see available options, as well as to have a look at the PDF documentation.
Video with the Scale and Taper tools
Video with the other tools
There are also a few video tutorials publicly available
And more specifically on the Box Stretching functionality
Menu for FredoScale
By default, FredoScale menu entry is in Tools > Fredo6 Collection > FredoScale...
The documentation might be a little bit outdated, but gives you an idea of most features of Fredoscale for Free Scaling and Tapering: FredoScale User Manual - English - v2.5 - 01 Sep 13.pdf
FredoScale User Manual - French - v2.5 - 01 Sep 13.pdf
There is also a quite comprehensive tutorial on FredoScale by Tutorials Up
Custom Ruby commands to launch FredoScale
If you have a custom toolbar (or a plugin for that), you can safely launch the FredoScale tools with the following Ruby code:
F6_FredoScale.launch_action(action_code)
where action_code is a Symbol (respect the case), with value:
- :ScaleB --> Scale - Box mode
- :ScaleT --> Scale - Target mode
- :TaperB --> Taper - Box mode
- :TaperT --> Scale - Target mode
- :PlanarShearB --> Planar Shear - Box mode
- :PlanarShearT --> Planar Shear - Target mode
- :PlanarShearA --> Planar Shear - Free mode
- :StretchB --> Stretch - Box mode
- :StretchT --> Stretch - Target mode
- :TwistB --> Twist - Box mode
- :RotateB --> Rotate - Box mode
- :RotateA --> Rotate - Free mode
- :RadialBendA --> Radial Bending - Free mode
- :MakeUniqueU --> Make Unique - Utility
If you need the icons, they are in the subfolder Fredo6_FredoScale/IMAGES_Standard.
FredoScale 3.6a - 01 Apr 24: Future compatibility
FredoScale 3.5a - 31 Jul 22: Bug fixing and removal of validity period
FredoScale 3.4b - 11 Mar 22: Inferences outside context and updated Chinese translation by Arc
FredoScale 3.4a - 15 Feb 22: Fix a big problem for all to-target tools (Invalid Origin)
FredoScale 3.3a - 13 Feb 22: Compatibility with SpaceMouse
FredoScale 3.2a - 30 Jan 22: QuickLauncher and divider by default for the Stretch tool
FredoScale 3.1a - 18 Dec 18: Workaround to a major bug in SU2022 about the modal dimension dialog box (invoked by TAB)
FredoScale 3.0a - 14 Jan 17: Maintenance release correcting problems introduced in v2.9b
FredoScale 2.9b - 02 Jan 17: Maintenance release (re-)fixing bugs in Radial Bend and Twist for SU2017
FredoScale 2.9a - 24 Dec 16: Maintenance release fixing bugs in Radial Bend for SU2017
FredoScale 2.8a - 13 Nov 15: Maintenance release
FredoScale 2.7a - 19 Oct 14: required for support of non-ascii username in SU14.
FredoScale 2.6b - 05 Feb 14: Fixes a bug on rounding improperly scale factors for Box target mode (signaled by JQL).
FredoScale 2.6a - 27 Nov 13: Release for future Sketchup compatibility
FredoScale 2.5b - 15 Sep 13: Small update fixing a problem preventing the language translation files to load. No functional changes Here is the release start post.
FredoScale 2.5a - 30 Aug 13: Technical update with new naming conventions to comply with Sketchup EWH and LibFredo6 5.2. No functional changes Here is the release start post.
FredoScale 2.4a - 22 Aug 13: Technical update with new naming conventions to comply with Sketchup EWH. No functional changes Here is the release start post.
FredoScale 2.2a - 24 Jul 11: small update to manage the display of handles when some dimensions of the box appear small on the screen (based on a request by Cunningham). Also, the Dice option (activated by F4) is active by default. See release note for details.
FredoScale 2.1a - 12 Jan 11: Technical update along with LibFredo6, with two-phase loading. No functional change, but it is advised to upgrade for support.
FredoScale 2.0i - 08 Apr 10: Same as 2.0h, but includes the Chinese translation.
FredoScale 2.0h - 26 Nov 09: Stable version
