VisuHole    v1.5a
Overview of VisuHole
REQUIREMENTS:
  • LibFredo6: v14.3b or above
  • Sketchucation ExtensionStore: v4.4.0 or above
  • Usage: Paid, Licensed under Sketchucation SCFLicense
    • Free Trial period (full features): 30 days from first usage
    • Perpetual license (3 seats): $15
    • Fredo6Bundle2022 license (8 plugins): $50
    • Information on licensing extensions at Sketchucation: this post
To purchase a license of VisuHole or the Bundle of 8 plugins, go to this page
VisuHole is a suite of interactive tools dedicated to holes and extrusions on planar and curved surfaces. In the current version, VisuHole supports the following tools:
VisuHole can drill through one or several surfaces, including when embedded in groups or components. The scope of the selection can be specified implicitly or by pre-selection. A few additional options are available:
  • Material assignment: you can choose or pick a material in the model for painting the extrusions, tubes and stamped shapes
  • Grouping, with 2 modes: GROUP IN for putting extrusions in groups in the selection context, GROUP OUT for putting all extrusions and tubes in a master group, without altering the original selection
  • Follow Surface for Carve and Emboss on curved surfaces, allowing to respect the shapes relative dimensions (versus Projection mode, where they would be distorted)
Installation of VisuHole
IMPORTANT: Make sure that you have first installed LibFredo6 v14.3 or above.
VisuHole is released as a regular RBZ extension file on the Sketchucation Site.
  • Download If your are already logged in.
  • Log in to get it! otherwise, in order to log in or to register to Sketchucation as a new user (this is FREE). Then you will be able to download the RBZ file.
IMPORTANT: Whatever way you choose, you MUST quit and restart Sketchup to get VisuHole (and LibFredo6) properly loaded.
  • Sketchup versions: SU2017 and above
  • Language: English, French (thanks to the kind translators)
  • Menus: by default, it is installed in Tools > Fredo6 Collection > VisuHole...
  • Icon toolbar: VisuHole
Permission to use this software for any purpose and without fee is hereby granted
STENCILS
The object used for drilling or extruding is called a STENCIL. This is actually a set of 2D shapes, with or without holes.
In the current version, Stencils must be picked in the model. To enter the Pick Stencil mode, click on the button in the palette or press TAB. The main buttons palette will disappear. When you move the mouse on faces and components, a small axis system is displayed. The blue axis shows the direction for 2D projection (on faces it is simply the face normal).
  • Click on a Face or on a group / component to pick the stencil.
  • Click and Drag to pick and orientate the X axis
INFLUENCE OF SELECTION
If the picked face is at top-level (i.e. not embedded in a group or component), then the selection is taken as all connected faces. Note that by pressing CTRL, you can restrict the selection to the picked face or picked surface.
If the picked face belongs to a group or component, then the selection depends on the options selected in the button palette:
TOOLS and GENERAL PROCEDURE
The VisuHole tool can be selected in the button palette, along with their options:
Setting the direction of projection: by default it is the normal to the picked face. You can however impose a direction, either an axis or a custom normal (as in MoveAlong or DrawAlong). For custom direction, mouse over a face and either type ENTER or LONG-CLICK. Once the Z-axis is set, the other axes in X and Y are computed by default.
You may also set the Material options and Group options (see details later in this chapter).
Then, to execute the operation,
  • Either double click on a face
  • Or Click–Release–Move–Click–Release or Click-Drag-Release to set a different orientation of the X and Y axis.
Once the operation is executed, you can either proceed with another operation or modify the settings for the current operation. If you change any parameter in the buttons palette, the button “APPLY CHANGE” will be enabled. When pressing this button, VisuHole will undo the operation and redo it again with the new settings.
DRILLING
You can drill holes with or without tubes, and with edges or Guide lines
STAMPING
You can Stamp, Punch or Mark. The shapes are printed on the front faces.
CARVING / EMBOSSING
Carving and Embossing are controlled by an offset and a few options related to the direction of extrusion and flattening it.
By combining these options, you can create platforms in terrains
VisuHole 1.5a – 01 APr 24: Future compatibility
VisuHole 1.4b – 12 Oct 17: preserve the preselection across operations, certification SU 2017, support of hi-res screen, compatibility OSX High Sierra. There was still a bug in v1.4a
VisuHole 1.4a – 12 Oct 17: preserve the preselection across operations, certification SU 2017, support of hi-res screen, compatibility OSX High Sierra
VisuHole 1.3a – 13 Nov 15: maintenance release
VisuHole 1.2a – 04 Feb 15: fixes a major bug preventing to drill when Guide lines, Guide Points or Edge are over the target face.
VisuHole 1.1a – 19 Oct 14: release for support of non-ascii usernames in SU14
VisuHole 1.0a – 21 Sep 14: initial public release
