User Rating:  /  (4 / 23)
PoorBest
how to model and texture lo-poly objects in SketchUp
A few months ago someone was looking for tutorials on how to make low polygon models in SketchUp. At the time I was not particularly well versed when it came to low polygon modelling so I decided to learn for myself.
During that time I researched the best methods and techniques needed. I discovered low polygon models can look great with the right texture applied.
In this tutorial you will learn how model and texture low polygon vehicles in SketchUp
example of rendered lo-poly models in SketchUp
Step 1 - Importing UV Grid
First I searched the web for a 10x10 UV grid and imported into SketchUp. Then I divided the texture into 10x10 squares as you can see by the vertices in the image below.
importing UV grid into SketchUp
Step 2 - Choosing polygons for modeling
I removed a section from the grid, as you can see on the left, that I wanted to use to construct my low polygon model. As you can see that section is already UV mapped from the first step.
choosing section to duplicate in SketchUp
Step 3 - Folding the model to maintain UV mapping
I folded the cut-out section to form a box, note that the UVs are still wrapped to the box. I kept the original cut out to view it from above for the next step.
folding the model in SketchUp
Step 4 - Opening texture in an Image Editor
I opened up the texture in GIMP and painted over the squares used to form the UV mapped box.
painting the model in GIMP
Step 5 - Importing paint over into SketchUp
Here you can see the box after the paint over in GIMP.
painted texture in SketchUp
Step 6 - Adding detail to model
Now we have a bus but it needs some work so we can place wheels underneath. I added more vertices so I could create wheel arches in the mesh.
adding geometry for wheel arches in SketchUp
Step 7 - Creating wheel texture
For my next step I needed to create just 1 wheel but use as little of the texture as possible. I used the top left square of the UV grid and made a triangle and a square and painted as needed.
creating wheel texture in SketchUp
Step 8 - Creating wheel texture
Then attach both the triangle and the square like so and arrayed it around all the way around. Then copy the outer wheel to the opposite side to form the wheel into a solid.
creating wheel object in SketchUp
Step 9 - The Final Result
And there you have it a low polygon bus...
lo-poly vehicle in SketchUp
...and it just goes to show sometimes low polygon with a detailed texture can be as effective as a high polygon model.
It doesn't stop there, I only used a small part of the texture, so let me show you how many models you can create just by using 1 texture in SketchUp!
texture atlas in SketchUp
All these models made using 1 texture, I hope you enjoyed this short tutorial and that you learnt from this.
I would also like to see others post low poly models here for us all to see and learn from.
Thanks for taking time to read my tutorial on modeling assets for game development in SketchUp.
Comments
#1 TomPendergrass 2014-09-26 14:17
Thanks for sharing, I find your method of UV mapping in Sketchup very interesting!
Report to administrator
