SUClock v3.1a
Overview of SUClock
- LibFredo6: v14.3b or above
- Usage: Free
SUClock helps you to track the effective time spent in Sketchup. The concept of effective time is based on the activity recorded within a certain duration, called idle time, which is a kind of ‘time to think’ (or the time to have a coffee).
Time is tracked in a Project, which can group several .skp models. A Project is simply materialized by a file with extension .suclock to which you attach your models.
SUClock optionally displays a small clock showing the effective time spent in the project which your models are attached to.
It also includes some statistics about where the time was spent (by models, by tools, by dates) which can be printed or exported in CSV.
You can also set alarms when the time spent on the project reaches a certain ratio of a target duration.
Installation of SUClock
SUClock is released as a regular RBZ extension file on the Sketchucation Site.
IMPORTANT: Whatever way you choose, you MUST quit and restart Sketchup to get SUClock (and LibFredo6) properly loaded.
- Language: English, French, Spanish, Italian (thanks to the kind translators)
- Menus: by default, it is installed in Tools > Fredo6 Collection > SUClock…
- Icon toolbar: Usually grouped with FredoTools toolbar with a single icon
Generic usage of SUClock
To Track time in a model, just click the small watch icon.
A dialog box will appear where you can attach the model to a newly created project or to an existing project.
for a New tracking project, you indicate the name and location of a .suclock file
for an Existing tracking project, you just select an existing .suclock file or one of the recent projects
Once your model is attached to a Project, you will see the Clock displayed
You can further access the parameters of the Tracking project by clicking on the small wrench icon of the visual clock, or on the SUClock toolbar icon.
From the dialog box which is displayed, you can change the idle time value, in minutes and you can access the statistics. You can also move the model to another project, reset the clock for the project. See documentation for details.
Here is the documentation, in English, updated for version 1.5.
SUClock - User Manual - English - v1.5 - 27 Nov 2013.pdf
Note: If you drop the PDF doc files into the Plugins directory, you can access them from within Sketchup via the menu Windows > Tools > Fredo6 Collection... > SUClock > Documentation...
SUClock 3.1a – 02 Apr 24: Future compatibility
SUClock 3.0a – 19 May 20: Bug fixing for appearance of the clock window and first version for SU2017+
SUClock 2.0a – 31 Oct 18: Bug fixing in dialogs
SUClock 1.9c – 12 Nov 17: Fixed bug in CSV export for non English languages. Added TSV export.
SUClock 1.9b – 30 Jan 17: Fixed bug on Mac
SUClock 1.9a – 16 Jan 17: Small refresh for cosmetic of dialog boxes
SUClock 1.8a – 13 Nov 15: Maintenance release
SUClock 1.7a – 20 Oct 14: Fix a major bug in display of clock introduced by LibFredo6 6.1.
SUClock 1.6a – 20 Oct 14: Release for non-ascii usernames
SUClock 1.5a – 27 Nov 13: Release for future Sketchup compatibility
SUClock 1.3a – 08 Oct 11: Technical release for compliance with OSX Lion and Safari 5.1
SUClock 1.2a – 03 Jun 11: several small functional enhancements
- alarm to target
- configuration of height of clock window (to avoid cropping)
- possibility to configure for network sharing
- Reset and import from other projects
- More export format
SUClock 1.1b – 19 May 11: added an extra column with Excel formatted date for the CSV export of view by Day/Month.
SUClock 1.1a – 17 Apr 11: initial public release.
