PDF Importer for SketchUp    v1.0_Windows
Download the trial version (1-day to test it out to make sure it works for you!)
Go to Extensions > Import PDF File > choose the file > choose page # if multiple > after import, edit group and set scale using the tape measure to pick two known points > enter desired dimension.
PDF Importer for SketchUp VERSION 1.0 for WINDOWS
PDF Importer is SketchUp extension allowing users to import vector PDF drawings directly into SketchUp, without the need for converting to DWG or DXF (CAD) first. CAD files do not bring text in upon import, where PDF Importer will bring in your text!
The current version is WINDOWS only but our MAC version is coming soon!
Say goodbye to Inkscape and Adobe Illustrator (0), PDF Importer brings in even large PDF drawings. Bear in mind that images, bitmaps, etc. will NOT come in because they are not vectors. Also, the PDF must have been created using some sort of CAD system, a scanned image will NOT be vectors and will not import. Just as when using Inkscape or Illustrator, only one page at a time can be imported using PDF Importer.
NOTE: Some PDFs can be quite large and SketchUp file sizes can get bloated quickly with unnecessary text, etc., so a good practice is to delete unneeded text, title blocks, etc. and purge any unused.
To use PDF Importer, download PDF Importer from estimatorforsketchup.com and use Extension Warehouse to install the downloaded .rbz file. Go to
Extensions > Import PDF File > Choose File > Choose Page (if multiple pages) > DONE!
PDF will import the drawing as a group and will be centered on the X,Y,Z axis (origin). The next step is to set the scale for the drawing. To do this, double- click on the group to edit, choose two points where the dimension is known. Using T for Tape Measure, simply click from one known point to the next point, then type in the desired dimension (measurement box) and hit Enter. Verify scale using a few other dimensions to make sure the dimensions drawn were not altered.
It is as simple as that!
License is yearly subscription /year with introductory discount of 20% or for the first year until after 3D Basecamp in Palm Springs, CA, September 24-28, using discount code basecamp. Expires October 1, 2018.
Happy Modeling from the team at BrockWorks Technologies, Inc., makers of Estimator for SketchUp, Framer for SketchUp and Issue
Version 1.0 for Windows
