InfinitePanOrbit v1.0.2
Releases the Pan and Orbit tools from the screen boundaries. When using these tools, if the cursor reaches the screen edge, it is teleported to the other side. So you can pan and orbit indefinitly.
You can toggle the plugin in "View > InfinitePanOrbit"
OSX support by John "Driven" Boundy
Known issues:
- The view flashes sometimes. The "flash" can be really long (sometimes up to 1 sec) and annoying in complex models. In that case, you should disable it.
1.0.2
- OSX support
1.0.1
- The plugin now works with models created or opened after SU startup
- It should now trigger correctly on all screen borders
1.0.0
- First version
