45 Degree Shadows for Elevation v1.4
Copyright 2006-2014, TIG
Permission to use, copy, modify, and distribute this software for any purpose and without fee is hereby granted, provided the above copyright notice appear in all copies.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
Name: 45 Degree Shadows for Elevation
Description: Adds 45 degree top-left/right shadows to elevations
Menu Item: View > Elevation 45 Shadows > Left || Right
Usage:
- Set up your plan or elevation-view scenes(s).
- Works best with perspective OFF.
Tip:
Select an elevation face and right-click and pick Align View to get a non-orthogonal elevation [i.e. non-F/B/L/R]. Then select View > Elevation 45 Shadows > Left || Right
45 Degree Shadows for Elevation will automatically work out a location, time of day etc, and in conjunction with the view's camera direction, add shadows as if the sun is from the top-left or top-right of the view, at 45 degrees, in elevation or in plan views.
Note:
- Aligning views to 3D sloping faces will have unexpected affects.
- Shadow setting changes are NOT Undo-able automatically. Because it changes the geo-location, North etc, only use it on a copy of the model's SKP.
It will realign North in each processed view, but all recent versions of SketchUp allow only one North at a time, so you'll need to copy the model's SKP for each shadowed view and use the scene-tabs to get proper shadows.
1.4 20140304 Improved format, typo fixed, now in TIG module etc.
Now two versions Left & Right chosen from sub-menu.
