TT Library v2.15.1
Overview
TT Library is NOT a standalone extension but uses methods that are required by other extensions.
It is advised that you install this extension to allow other tools I distribute to fully function
Remove older TT_Lib² versions if you already have TT_Lib² installed
For more detailed documentation use the following TT Library 2 Documentation
-Verion 2.9.1_
- Future proofing and integrating Selection Toys
Version 2.6.0
- LibFredo Update Checker support.
- Lots of new features and fixes.
- Important - QuadFace Tools users need to update to this version!
Version 2.5.8
- Fixed some regression bugs in Inpubox
Version 2.5.7
- Fixes the fix for the OSX fix that broke WebDialogs for some Windows users.
_Version 2.5.6-
- Fixes what appear to be a regression from 2.5.4 to 2.5.5 for some Windows users.
Version 2.5.5 - Update for OSX users with Safari 5.0.6 or higher.
- Not needed for Windows users.
- Highly recommended for OSX users as Safari 5.0.6 will break some plugins with webdialogs.
-Version 2.5.4 - This update requires that you also update:_
- Edge Tools ( 2.0.3 )
- Plan Tools ( 1.2.2 )
- CleanUp ( 3.1.4 )
Version 2.5.3
- Important bugfix - Fixed again repair broken edges.
Version 2.5.2
- Important bugfix - Fixed bug in the method that repair broken edges.
Version 2.5.1
- Fixes Webdialog issues with IE7
Version 2.4.0
- Added module: TT::Binary
- Added class: TT::JSON
- Added module: TT::GUI
- Added class: TT::Window
- Added class: TT::Inputbox
- Added module: TT::System
- Added module: TT::Locale
- Added module: TT::Cursor
Version 2.3.0
- Added method: TT::Geom3d.spiral_sphere
- Fixed: TT::Ray.test
Version 2.2.0
- Added module: TT::Bounds
Version 2.1.1
- Fixed bug: Ray.test (Workaround for SU8.0 bug)
Version 2.1.0
- Added module: TT::UVQ
- Added class: TT::UV_Plane
- Added method: TT::Entities.bounds
- Added class: TT::Gizmo::Manipulator
- Added module: TT::Selection
- Fixed: Ray.test
