Find And Report    v0.702.7
Find And Report is a search and bill of quantities tool that allows you to:
  1. Search and find entities based on attributes or parameter values.
  2. Add custom attributes to identify the entities.
  3. Export entity data to Excel or a csv file.
  4. Import some data from Excel (or a csv file) to SketchUp.
  *>> This extension contains the "Face Orientation Checker , 3D Offset" and Quick Group tools. Activate or deactivate them via the Find And Report menu.
   Button   Install it and press the single "Find And Report" button to access all the features.
Version 0.702.5
  • Find And Report: fix bug with imported date from Excel: Find And Report is no longer blocked and dates are converted into string.
  • Find And Report: correct display of the hide/unhide column button if an attribute column has been removed.
  • Find And Report: the F&R window refreshes if we switch to another model on Mac.
Version 0.702.6
  • Find And Report can be used after February 1, 2025.
Version 0.702.7
Fixes a bug with library loading that can fail. Compatible with SketchUp 2025.
