Sketch-Cuisine v25-06-01
See Infos button on dialogs and Toolbar.
See Infos button on dialogs ans Toolbar.
First 30 days are free trial. Then subscription is required: 85$ for 570 days. See Infos button on dialogs and Toolbar.
- 25.06.01 Tall 1rst section single door width corrected.
- 25.05.28 Tall shelve & side correction, Tall dialog reduced height. Omit back when thickness = 0.
- 25.03-01 For snap release
- 25.02.16 Correction to door opening of upper corner 2 pcx.
- 25.02.08 One more shelve in upper cabs
- 24.12.18 New corner. New side plinths to all. Added 'box' color and tidy up. Added a shelf to sec.2 of Talls. Vertical braces for sink cabinet.
- 24.12.03 Added Select All to colors
- 24.09.07 New scheme.
- 24.08.22-3 Ajustments to Styles dialog
- 24.08.21 Added bottom inset for upper cabinets.
- 24.05.21 Added material for OpenCutList, plinth adjust.
- 24.04.28 Correction for wide cabinet dialog.
- 24.02.16 Corrections to german
- 24.02.14 Added some love.
- 24.02.07 Added Ledge-V handle
- 24.01.24 Trial bug correction
- 24.01.08 Minor HTML tweaks.
- 24.01.06 Correction to Multi-Edit.
- 24.01.01 Retrait du dos au mur, ajouté.
- 23-12-26 Correction to std cabinets dialog lang.
- 23-12-12 Better corners - Handle-on-left is back for std cabinets.
- 23-11-30 Correction to Shaker-45 doors.
- 23-06-26 Correction to refrigerator.
- 23-02-02 Added horizontal handle positioning. Removed handleleft. Edit:left-right => hinge-opening. corr. Drawer style was not retained in Styles dialog. 23-01-03 Added German lang. 22-11-22 Corr. to Infos & sink dwr anim. 22.11-09 Correction to Talls multi edit w drawers. 22.10-30 Correction to SketchUcation check. 22.10-29 Correctiion to version mumber. 22.10-28 Correction for multi edit. 22.10.26 Check if SketchUcation is present 22.10.10 Added Back Panel thickness, and "defo m dot" folder 22.09.15 version number corrected. 22.09.14 Name for license corrected. 22.09.11 Added - allow newer - 22.08.13 Missing images of drawers with double handles added. 22.08.11 Name for license corrected. !! missed, see 22.09.14 22.08.01 Shaker-45 variable width, intermediate rail thicknesses adjusted, added wide items, better talls user values read-write. Lots of under the hood improvements. 22.07.24 Correction for License 22.07.20 Correction for Edit width html not appearing. Prevented to edit std cabinets. 22.07.14 => Sketchucation 22.06.06 Added Ledge-wide handle and corrected grooved doors for dashes. 22.04.04 Handles 2017 format & linestyles V > 2019 22.03.24 Added inverted dashes. for Australia. 22.03.17 Added Spanish. Corrected Animate & Infos dialog size. 22.03.03 Style to all, added corners and handles. Double handle alignment when centered on drawer. Instructions in menu & toolbar. # Better in metric. Corrected some 'undos' were not one step. Removed wrong use of select_tool. 22.02.07 Talls: images now completed and svg.
