MAJ FollowMe v2025
The "MAJ FollowMe" Sketchup plugin is a powerful tool that allows users to create 3D objects with ease. This plugin enables users to select and save one or multiple profiles and add them to a list. The profiles in the list can then be used to create a 3D subject simply by following the mouse pointer. The "MAJ FollowMe" plugin is incredibly versatile and can be used to create a variety of objects, including columns, rails, walls, and much more. This plugin provides users with a fast and easy way to create complex shapes, which can save time and improve the overall design process.
The "MAJ FollowMe" plugin is user-friendly and easy to use, making it accessible to users of all skill levels. The interface is intuitive, and the plugin can be used in a variety of different ways to create complex shapes and structures. The plugin is also highly customizable, allowing users to adjust the settings to suit their specific needs. Additionally, the "MAJ FollowMe" plugin is compatible with other MAJ plugins, which can enhance the functionality and overall performance of the tool.
In conclusion, the "MAJ FollowMe" Sketchup plugin is an indispensable tool for architects, designers, and other professionals. It provides users with a fast and easy way to create 3D objects, and it offers a high level of versatility and customization. This plugin is sure to save time, improve accuracy, and enhance the overall design process.
https://youtu.be/qISQtRf7PzI
MAJ Follow plugin has 4 icons as below. 1- Draw By pressing this icon, a window will appear and you can choose the following items. 1-1 FollowMe Type: FollowMy Type has 3 types. In the "Normal" type result will be the same as Sketchup FollowMe. The "Directional" always will keep the direction of the shape. The "Rorate" type will rotate your selected face and with every click, you add one more. This option active for the paid plugin. 1-2 Length Scale: You can type the length of the shape scale. 1 means the length will be the same as the original shape. It can be more or less than 1. 1-3 Height Scale: You can type the height of the shape scale. 1 means the Height will be the same as the original shape. It can be more or less than 1. 1-4 Shape Name: You can see the list of shapes. 5 first shapes cannot change or delete. You can add, rename, or delete other shapes. You can add 5 more shapes. If you need more shapes, the extension will inform you how can you do it. After this step, you can select the first point of 3D by clicking on it. 3D will follow your mouse pointer. Every single click will assign a fixpoint of 3D and a double click will make 3D. The "Tab" key will change the direction of the shape. "UP" and "DOWN" keys can upside down the shape. 2 - Pick Shape When you press this icon, the extension waits for you to pick a face. Face can be in a group, in a component, or a single face. After you select a face, You can see a yellow line around it. Then you should select a point in the shape environment. This point will be a reference point of the shape. Then you should select another point in the shape environment. The line between 2 pints will show in red color. These 2 points will assign the direction of the shape. Added shapes will save in HD and will be available whenever you use Sketchup. 3 - Rename Shape By pressing this icon a window will appear. You can select the shape from the list and rename it. 5 first shapes will not appear in the list. 4 - Delete Shape By pressing this icon a window will appear. You can select the shape from the list and delete it. 5 first shapes will not appear in the list.
To have 10 more shape space: 1- Send USD5 (1 Coffee) to the following address https://www.buymeacoffee.com/mahmoudi 2- Email bill to following email address partban@gmail.com 3- You will receive the plugin within 3 days by e-mail
To have unlimited shape space and also Rotation Mode: 1- Send USD25 (5 Coffee) to the following address https://www.buymeacoffee.com/mahmoudi 2- Email bill to following email address partban@gmail.com 3- You will receive the plugin within 3 days by email
History 1.0.1:: 2021-04-09 * Original release. I'm expecting some bugs and feedback. 1.0.2:: 2021=05-09 * Improving view and selecting points 1.0.5:: * Status Bar always helps users * Problems solved for MAC OS * Arrow keys active * X Key defined to select and add points
