MAJ Window Free Edition    v2025
The "MAJ Window" plugin helps you to cut 3 layers of Walls created by "MAJ Wall" and make a window on them. Sketchup's status bar helps you make windows and use the active keys when using this plugin. This version is completely tested on both Windows and Mac operating systems. You can download this version by following the link address:
MAJ Plugins List:
Free Plugins: 1- "MAJ Beam". Helps you create beams. 2- "MAJ Column". A must-have to create columns quickly and efficiently. 3- "MAJ Wall". Allows you to create walls with 3 different layers. 4- "MAJ Door". This plugin makes doors in the walls made by "MAJ Wall". 5- "MAJ Window". This plugin makes windows in the walls made by "MAJ Wall". 6- "MAJ FollowMe". Let's create 3D shapes by choosing a face that follows your mouse pointer. 7- "MAJ Rail". This plugin facilitates creating rails in 3 different types. 8- "MAJ Stair". This plugin makes stairs in 4 different thickness types.
Paid Plugins: 1- "MAJ Interior". Knauf, Cornice, Wall Interior, Baseboard, and Floor made with one click. 2- "MAJ Light". Helps you create halogen lamps made on Knauf. 3- "MAJ FollowMe". The paid version allows the creation of an unlimited face list and face rotation. 4- "MAJ Rail". 6 types of rails in the paid version.
https://youtu.be/7aMVLXp0Faw
Walls should be made by "MAJ Wall Maker" extension and original layers name. In the first Sketchup window select "Window Height", "Window to WZ" and "Window Type". "Window to WZ" is the distance between the bottom of the wall to the bottom of the window. First, click on the wall cause "Finishing Layer (Tag)" and "Interior Layer" hide. You can quit this step by clicking on "Wall" directly. Second click cause "Wall Layer" will be transparent. In this way, you can see the 2D plan or other elements covered by the wall. You can select the first side of the window with a third click. The fourth click will select another side of the window. After the fourth click, 3 wall layers cut and window match to the wall will make. After 3rd click, you can type the length of the window then press "Enter". A window will make of that size. If you change wall width, windows will be matched to wall width. If you select "None" for the type of window, the extension just cuts three layers of the wall. If you enjoyed using this extension, and you wish to see more "Window Types" you can buy me a coffee here: https://www.buymeacoffee.com/mahmoudi Email me (partban@gmail.com) a receipt of your donations to get the latest features of the extension by receiving the next version. If you wish to have a special window type please send me an e-mail (partban@gmail.com).
If you enjoyed using this extension, and you wish to see more "Window Types" you can buy me a coffee here: https://www.buymeacoffee.com/mahmoudi Email me (partban@gmail.com) a receipt of your donations to get the latest features of the extension by receiving the next version. If you wish to have a special window type please send me an e-mail (partban@gmail.com). Whenever my received total donation achieved USD 100, a new type will add to this extension for free. History 0.0.1:: 2021-03-14 * Original release. I'm expecting some bugs and feedback. 1.0.5:: 2021-05-23 * Pick point improved. * Status Bar always helps users. * Problem solved in MAC OS. =end
