MAJ Beam v2025
"MAJ Beam" plugin helps you create beams in Sketchup. Sketchup's status bar helps you make beams and use the active keys when using this plugin. This version is completely tested on both Windows and Mac operating systems. You can download this version by following the link address: https://sketchucation.com/plugin/2385...
MAJ Plugins List:
Free Plugins: 1- "MAJ Beam". Helps you create beams. 2- "MAJ Column". A must-have to create columns quickly and efficiently. 3- "MAJ Wall". Allows you to create walls with 3 different layers. 4- "MAJ Door". This plugin makes doors in the walls made by "MAJ Wall". 5- "MAJ Window". This plugin makes windows in the walls made by "MAJ Wall". 6- "MAJ FollowMe". Let's create 3D shapes by choosing a face that follows your mouse pointer. 7- "MAJ Rail". This plugin facilitates creating rails in 3 different types. 8- "MAJ Stair". This plugin makes stairs in 4 different thickness types.
Paid Plugins: 1- "MAJ Interior". Knauf, Cornice, Wall Interior, Baseboard, and Floor made with one click. USD25 2- "MAJ Light". Helps you create halogen lamps made on Knauf. USD25 3- "Paid MAJ FollowMe". The paid version allows the creation of an unlimited face list and face rotation. USD25 4- "Paid MAJ Rail". 11 types of rails in the paid version. USD5 5- "Paid MAJ Door". 6 Types of doors in the paid version. USD5 6- "Paid MAJ Window". 6 Types of windows in the paid version. USD5
https://youtu.be/0QA8h3hiisE
This plugin draws square and rectangular beams. In the first window, you can set "Beam Width", "Beam Height", "Rebar Size", "Rebar Number", "Stirrup Size", "Stirrup Distance", "Neck First", and "Neck Second. By "Neck First" you can choose the size of rebars that should be out of the beam in the first point. "Beam Direction" can be "UP / DOWN" and "LEFT / Right". For drawing beam, you just need to select the start point and endpoint. Also, after selecting the first point you can type the size of the beam and press "Enter". The beam will make and on one side of the beam you can find the following information. "Concrete Volume", "Rebars Length", "Rebars Volume", "Stirrups Length", and "Stirrups Volume". These information save is different group (named "Beam Info") also different tag ("Info").
"MAJ Beam" and "MAJ Column" can help Architectures and Constructions Engineers. History 0.0.1:: 2021-01-04 * Original release 1.0.1:: 2021-04-04 * Use "Tab Key" for changing direction * Use "shift key" for up/down * Use component instance for stirrups * Change tags of beam components * Showing active keys on "Sketchup status text" 1.0.5:: 2021-05-21 * Use arrow keys to change the beam directions * Status Bar always help the users * Fully tested in Windows and MAC OS
