MAJ Column v2025
Plugin first asks you some information about column as, " "Column Length ", " Column Width", "Column Height", "Column to Zero", "Rebar Size", "Ribar Number", "Stirrup Size", "Stirrup Distance", "Neck Top", and "Neck Bottom. This information is saved and any time you use this plugin you can find the last column information. After you confirmed you should select the first and second points for the column. After you select the first point you can see the column body in view. Column, rebars, and stirrups will make in "Foundation Tag". Also column information like "Concrete Volume", "Rebars Length", "Rebars Volume", "Stirrups Length", and Stirrups Volume" will be in "Info Tag". If you don't need rebars or stirrups, just select their size as zero.
https://youtu.be/wt4-tWk4tao
"MAJ Column" and "MAJ Beam" are two useful extensions that can help Architectures and Construction Engineering. History 0.0.1:: 2020-12-12 * Original release. 0.0.2:: 2021-01-06 * Adding column information on side of the column. Saving column data as default. * Solving Width and length ratio. Showing column material information. * Adding column view. 1.0.1:: 2021-04-03 * Use component instance for stirrups * Change tags of column components 1.0.5 :: 2021-05-22 * Status Bar always help users to draw column * Fully tested in MAC and Windows OS
