MAJ Rail v2026
In the following document, we will explain the MAJ Rail extension. MAJ Rail can make rails in three different types and selected heights. Rails can be used for fences stair rails or combinations. In the starting window, you select rail height and rail type. For making rail you define pole position by clicking. If you want to have numbers of poles between two points you can press a number plus "x" or "X" then "Enter" and continue selecting pole positions. If you want to have numbers of poles between two points, make rail press number plus "e" or "E". Rail poles can have different z positions. Rails poles can have run and perpendicular offset based on the position you click. The direction of the offset can be controlled by arrow keys.
https://youtu.be/1UHah2rJ5bs
The "MAJ Rail" plugin helps you to create 3 types of rails. Sketchup's status bar helps you make rails and use the active keys when using this plugin. This version is completely tested on both Windows and Mac operating systems.
MAJ Plugins List:
Free Plugins: 1- "MAJ Beam". Helps you create beams. 2- "MAJ Column". A must-have to create columns quickly and efficiently. 3- "MAJ Wall". Allows you to create walls with 3 different layers. 4- "MAJ Door". This plugin makes doors in the walls made by "MAJ Wall". 5- "MAJ Window". This plugin makes windows in the walls made by "MAJ Wall". 6- "MAJ FollowMe". Let's create 3D shapes by choosing a face that follows your mouse pointer. 7- "MAJ Rail". This plugin facilitates creating rails in 3 different types. 8- "MAJ Stair". This plugin makes stairs in 4 different thickness types.
Paid Plugins: 1- "MAJ Interior". Knauf, Cornice, Wall Interior, Baseboard, and Floor made with one click. 2- "MAJ Light". Helps you create halogen lamps made on Knauf. 3- "MAJ FollowMe". The paid version allows the creation of an unlimited face list and face rotation. 4- "MAJ Rail". 6 types of rails in the paid version.
History 0.0.1:: 2021-02-04 * Original release. I'm expecting some bugs and feedback. 0.0.2:: 2021-03-02 * Solving Feet Unit problem, * Adding offsets * Adding type C * Solving type B handrail problem 1.0.5 * Status Bar is always active * Problems solved in MAC OS. * Arrow Keys used
