MAJ Stair v2025
The "MAJ Stair" plugin helps you to create any type of stair in 4 different thicknesses. Sketchup's status bar helps you make stairs and use the active keys when using this plugin. This version is completely tested on both Windows and Mac operating systems.
MAJ Plugins List:
Free Plugins: 1- "MAJ Beam". Helps you create beams. 2- "MAJ Column". A must-have to create columns quickly and efficiently. 3- "MAJ Wall". Allows you to create walls with 3 different layers. 4- "MAJ Door". This plugin makes doors in the walls made by "MAJ Wall". 5- "MAJ Window". This plugin makes windows in the walls made by "MAJ Wall". 6- "MAJ FollowMe". Let's create 3D shapes by choosing a face that follows your mouse pointer. 7- "MAJ Rail". This plugin facilitates creating rails in 3 different types. 8- "MAJ Stair". This plugin makes stairs in 4 different thickness types.
Paid Plugins: 1- "MAJ Interior". Knauf, Cornice, Wall Interior, Baseboard, and Floor made with one click. 2- "MAJ Light". Helps you create halogen lamps made on Knauf. 3- "MAJ FollowMe". The paid version allows the creation of an unlimited face list and face rotation. 4- "MAJ Rail". 6 types of rails in the paid version.
https://youtu.be/wN66DlCQveY
This extension can make any kind of stairs. You can select stair thickness types, riser, total height, stairs number, and stair nose. in the start window. At first, you can choose two corner points of the first step. If your step is a normal one just double click on the last point of the last step. If your steps are not the normal ones, click on each step's last point i]on one side. After you click on the last step point, you should click on the endpoint of stairs on the other side. Whenever you need a breakpoint in any steps presses the "x" key. You can add length by using "Number" + "Enter" and you can repeat the step in size and direction by using "Number" + "s" + "Enter". You can control the direction of steps by using the "LEFT / RIGHT" key. Also, you can select to watch steps in view or not by using the "UP / DOWN" keys.
Following extensions can help you to make a building simple and fast with many details. 1- MAJ Stair: Make any kind of steps in 4 different thickness types. 2- MAJ Rail: Make any rail fast and simple. 3 rail types are available now. To have more types contact with me. 3- MAJ Wall: Make Walls in 3 layers. 4- MAJ Door: Can cut "MAJ Wall" and make a door on it. 5- MAJ Window: Can cut "MAJ Wall" and make a window on it. 6- MAJ Column: Make columns with their components. 7- MAJ Beam: Make beams with their components. 8- MAJ FollowMe. You can select a face from the list and it will follow your mouse pointer. You can select a face from the model and add it to the list. 9- MAJ Interior Make, Interior wall, floor, Knauf, cornice, and baseboard with one click. To have this extension contact me.
Email address: partban@gmail.com
