Dezmo Weld vRC1_2020_0729_1756
The #weld method has been integrated into the SU Ruby API (SU 2020.1) The #weld method takes a set of edges and finds all possible chains of edges and connects them with a curve.I thought I'd give it a try. I made a test plugin.
Select edges then use the icons or Extension > Dezmo Weld
There are two options:
Marry the selected edges. All. Unless the curve will not cross another curve. They will split where multiple curves meet.
Similar as above, but polygons, circles and arcs will be ignored. Unless there is exactly one edge (can be part of another curve, and selected) at at least one end. (Well, what a beautiful sentence ...)
....(Completely optional: Only from menu)
One more thing. You must have a SkechUp 2020.1 (20.1.367) or later version. Otherwise you just get a pretty message or not even that!
RC120200729_1756. The first
