JS Random Move v1.1.1
Moves selected entities randomly within range in one, two or three axis. Select which Axis you want to use. World is the original SketchUp axis. Current is the axis if you use the Axes tool to move the axes. Local is the local axis inside each component/Group.
You should also take a look at my plugin Chaos that can move, scale and rotate randomly.
Select which Axis you want to use.. World is the original SketchUp axis. Current is the axis if you use the Axes tool to move the axes. Local is the local axis inside each component/Group.
1.1 Added support for SketchUp >=7. Added World, Current and Local axis. 1.1.1 Fixed so that it remembers last used values.
