FrameModeler v1.7.2
- Download extension from Sketchucation.
- Run as Admin Sketchup.exe
- Install the Rbz file
- If the extension is installed properly, you can see the following text: "FrameModeler Install finish. "
FrameModeler
Supports basic architecture elements. Users can place architectural elements with their fingertips.
- Column
- Beam
- Wall
- Slab
- Grid
FrameModeler
Calculate the area and volume of the material as excluding intersected faces and edges.
Model Information Tools
- Information Export Tool (Export Excel data)
- Select model data from ModelInfo
- Update Model Condition
- Excluding intersected faces and edges, updating grid position.
Etc. Tools
- CutOff Tool (Open window tool)
- Line
The user manual is included in the plugin folder. The manual supports only Korean for now.
Requirement
MS Office Excel
Release 1.1.0
- Update New UI
- Support English tooltips and parameter
- Displays an error on the screen after executing the Trim function.
- Beam, Wall, Slab negative height value available.
- Added CAD select mode
- Continuous placement changed to "Ctrl" toggle key in "shift" release.
Release 1.2.0
- PushPull Tool
- Ramp Tool
Release 1.2.5
- Ruby library load error fix.
Release 1.2.6
- Update Model Condition Tool
- Trim func has been updated. Only selected entities are executed.
- If you do not select anything, all FM model entities will be trimmed when run.
Release 1.3.0
- Sefaira Convert Tool
- Converts walls and slabs specified as groups to face objects.
- PushPull & Ramp UI fix
Release 1.3.1
- Sefaira Convert Tool fix
Release 1.3.3
- Sketchup 2019 Available
Release 1.3.4
- It can be executed in an environment where Excel is not installed.
Release 1.3.6
- You can export model information even if Excel is not installed.
Release 1.3.8
- Fix the plug-in load error below
Error: #
Release 1.3.9
- Information Export Tool Update ** Change the data type of volume, quantity and area from text to value. ** Excel formula available
Release 1.4.0
- Information Export Tool Update ** Line segments created by the line tool are displayed in the Information Export Tool.
Release 1.4.3
- FrameModeler converter fix
- Eng string resoucres update
- Trim Function fix
Release 1.4.4
- Eng worktype include
- Unlocks all inferences before placing the FrameModeler object
Release 1.4.5
- Improved picking entity accuracy of Cut Off Tool
Release 1.4.6
- estimation tool for Asung
- You can now set allowance for the report feature.
Release 1.4.7
- Fix sketchup auto update conflict.
Release 1.5.0
- Fixed an issue where Windows Korean user account names could be used.
- A report selection error has been fixed.
- Report surcharge function has been added.
- The invoice has been added to the report.
Release 1.5.1
- Fixed the problem that the item selection function is not available in the report when there is no instance name of the component.
Release 1.5.4
- Grid Tool updated
Release 1.5.5
- Report Tool fixed
Release 1.5.6
- Troubleshoot report length attribute display
- Trim function troubleshooting
Release 1.5.7
- Fixed beam create position when entering negative height in sketchup 2019
Release 1.5.8
- Modified to be compatible with SketchUp 2022 version
- Changed the trim step executed in the updatecondition function to be performed in the object placement step
- Added Framemodeler-Trimming function to object right-click menu
Release 1.5.9
- Asung calculation function has been excluded.
Release 1.6.0
- Sketchup 2023 version is supported.
Release 1.6.1
- Fixed an issue with objects not being created the last time user created a ramp using the ramp tool.
Release 1.6.2
- Grid tool UI fix.
- Fixed the problem that the grid object Edit function does not work.
Release 1.6.3
- Fixed a part that was recognized as an error when the entire area was cut off when placing an architectural object.
Release 1.6.5
- Add saving and importing of object properties in file format.
- Improved object property update function.
- Slab rectangular selection status changed to default.
- Beams and slabs have been changed to be created with opposite heights.
- Sorting function for object properties such as column, wall, beam, and slab has been added.
- Fixed an issue where secondary material values among wall properties were not saved.
- The end of the face wall has been modified so that no material is applied.
- When displaying multiple group objects in the quantity calculation report, the colors are changed to display differently depending on the group level.
- Hypothesis selection function added to quantity calculation report.
- Added object attribute information search function.
- Add object member property information sorting function.
Release 1.7.0
- In the properties of walls and beams, the length is displayed by subtracting the length value by the trim area.
Release 1.7.1-17.2
- Fixed an issue where the quantity per floor was calculated twice in quantity calculation contents.
