Number Components v1.1.3
Number Components automates numbering components or groups with 3D text. It has various options for the directions in which the numbers increase and options for the number text that is placed. It can also place the numbering text in the instance name of groups and components with the "Number to: Rename Component" option.
Number Components Quick Start Guide
How to use:
Select some groups, components or a mixture of the two types. Set the view to either Top or at least to be looking down on your selected components so you can see the results of this plugin.
Right-click on your selection, then choose "Number Components" from the context menu that pops up.
Choose from the following options:
Font, style, text height, extrusion size (0 for no extrusion), unit (mm/inches), direction, Numbering system, Text Prefix("Text n" only), Number to 3D text or rename component ,First number, Flip alternate rows, Keep window open.
All settings are saved to disk so they should stay at your last used settings even after restarting SketchUp. Note that they have to be used by clicking the "Number Components" before they're saved to disk.
Click 'Number Components'.
Updated youtube demo of Number Components with font support:
Number Components
This extension numbers components and groups with 3D Text or renames component instances.
The 3D text is placed above the centre of each object when viewed from above in top view.
The objects selected do not have to be in a grid pattern or all at the same height above the x-y plane (red-green).
New features in version 1.1.0
- Font support with bold/italic style.
- Extrusion for text that really is 3D.
- Last used settings are automatically saved.
- Window can be left open to try different settings.
Note: On OS X/macOS, updating the list of fonts can take a long time e.g. 10 seconds. This should only happen once when you first open this extension. The font list is saved to avoid further delays, but if you want to update the list when you add new fonts to your system just click the "Update Fonts" button.
How to use:
The extension will then place 3D text on top of each component or group that was selected OR rename each instance.
Font
Choose a font and style. The style might not have any effect on some fonts. Choose height of text in y direction (green axis) and extrusion height in z direction (blue axis).
Direction
The order the objects are numbered in is set by the Direction setting.
The first direction is the major one, followed by the minor one. e.g. "Down, Right" sorts the objects first by descending y-coordinate (green axis), then by ascending x-coordinate (red axis).
Numbering
1..n
Simply places numbers on each object 1,2,3,4,… etc.
A1..Az
Numbers each row A1, A2, A3, etc. Then the next row B1 ,B2, B3, etc. For Directions that start with Up or Down, each row has the same letter. For Directions that start with Left or Right, each column will have the same letter.
Text n
The text that you type in the "Text Prefix" is placed on each component, followed by its number. e.g. Type "Door " in the Text Prefix and the objects will be numbered "Door 1", "Door 2", etc.
Definition n
This option reads the name of the component definition and adds the number. e.g. Select all components with definition name "Window" and they will be numbered "Window 1", "Window 2", etc.
Definition (no numbering)
This is the only option which does not number components. It places the definition name of the component. This could be useful to mark the type of each component on a plan view.
Number to
This sets where the numbers go. They can either be placed above each object as 3D text or used to rename the component or group's instance name. This affects all the above settings. If nothing seems to happen when you click "Number Components" make sure this option is not set. You have to look at each component in the Entity Info window to see its effect. Renaming component instances can be used for the label tool in Layout if you have SketchUp Pro.
First Number
Sets the first number. e.g. "100" would mean the objects are numbered "100", "101", "102", etc.
Flip Alternate Rows
With this option ticked, the numbering direction will reverse every time a new row is started. The direction set e.g. "Down, Right" applies to the first row.
1 2 3
6 5 4
7 8 9
Keep Window Open
Tick this box to leave this extension's window open after clicking the "Number Component" button. This is useful for trying out different numbering options before closing the window. With this unticked, the window will close after clicking the "Number Components" button.
Number Components 1.1.3
Three new Numbering 'from' settings: Text (no numbering) Instance n Instance (no numbering)
"Text (no numbering)" Just uses the text from the Text Prefix box. "Instance n" reads the instance name of each group or component and uses that for the text plus a number. "Instance (no numbering)" is the same, without numbers.
New directions: z-ascending z-descending
The z-ascending or descending directions only look at z-coordinates (blue axis). This could be useful for numbering treads on a stair that is not straight or maybe floors in a building. As it ignores x and y coords, they are left unsorted.
Number Components 1.1.2
Should work better on Windows now.
Number Components 1.1.1
Looking for fonts on Windows should be more robust now. Uses default list of fonts if they can't be read.
Number Components 1.1.0
New features:
Note: on macOS, you may get the spinning beachball the first time you open the extension. Don't panic. Reading the fonts takes a long time (up to approx 10 seconds), but you'll only have to do it once. The fonts are only read once the first time you open the extension. The list of fonts is cached so it doesn't need to search again the next time you open SketchUp. If you add new fonts to your system, click the "Update Fonts" button to make use of them.
