3skeng 2025 List (SU2025/2024/2023 PC/MAC)    v2025.3.063.002
Put "3skeng Channel" to the test within a free 14 days trial period of the full version!
Work more efficiently with 3skeng List
Powerful and interactive filtering, sorting and editing features help you to work most efficiently even in very large models. 3skeng List is not only helpful for editing element properties but also for making both complex and large selections that might be impossible to make otherwise. The spreadsheet view is always in sync with the 3D model. Changing data within 3skeng List (e.g. coordinates or name properties) results in immediate changes in the SketchUp model and vice versa! Sub-Selections are highlighted interactively in the 3D view.
3skeng List keeps your model clean
3skeng List was designed to support professionals in their everyday work. It is packed with features that help to keep the model clean or find and solve errors. You can find duplicate entities, convert multiple groups to components or replace multiple components with another component of the selection. Round coordinates to the precision you prefer. Having a clean model is the foundation for high quality results.
3skeng List exports your meta data
Of course, all spreadsheet views can be exported nicely formatted to Excel (.xlsx file format), or copied as plain text directly to the clipboard. You can use the definition, instance, layer and material names to add custom data columns to your components (by using the character "^" as separator in the names). Save your filter and column settings in customized list views to reuse them for repeating work. Tip: Referencing exported Excel spreadsheets in prepared Excel templates or in Trimble Layout gives you a fluent workflow for fast and reliable report generation!
Install 3skeng
Learn how to download, install, troubleshoot, activate and purchase 3skeng by checking out the “3skeng-Starting-Guide.pdf” available on the download and faq page of http://www.3skeng.com.
Privacy Policy
Follow the link to learn more about the Privacy Policy of SHK and 3skeng: http://www.3skeng.com/en/privacypolicy.htm!
Install 3skeng
Learn how to download, install, troubleshoot, activate and purchase 3skeng by checking out the “3skeng-Starting-Guide.pdf” available on the download and faq page of www.3skeng.com.
First Steps
Click on a tool icon in the 3skeng toolbar.
The "3skeng Client" window will open and the appropriate tool will enter its work mode.
From now on, you can follow the context-sensitive tutors in the bottom tab of the "3skeng Client" that will help you through each step.
Version 2025.3.063.002 runs with SketchUp 2025/2024/2023 on PC & MAC.
Version 2024.3.062.008 runs with SketchUp 2024/2023/2022/2021/2020 on PC & MAC.
Version 2023.3.060.012 runs with SketchUp 2023/2022/2021/2020 on PC & MAC.
Version 2022.3.056.012 runs with SketchUp 2022/2021/2020/2019 on PC & MAC (also M1).
Version 2022.3.056.011 runs with SketchUp 2022/2021/2020/2019 on PC & MAC.
Version 2021.3.053.009 - Bugfix
Version 2021.3.053.008 runs with SketchUp 2021/2020/2019/2018 on PC & MAC.
Version 2020.3.050.012 - Bugfix Channel Tool
Version 2020.3.050.011 - Bugfix Flex Tool
Version 2020.3.050.010 - Bugfix List and Sort Order
Version 2020.3.050.009 - Bugfix
Version 2020.3.050.006 runs with SketchUp 2020/2019/2018 on PC & MAC.
Version 2019.3.047.010 - Bugfix
Version 2019.3.047.009 - Bugfix
Version 2019.3.047.008 - Bugfix
Version 2019.3.047.007 - Bugfix
Version 2019.3.047.006 - Bugfix
Version 2019.3.046.009 runs with SketchUp 2019/2018/2017 on PC & MAC.
Version 2018.3.041.006 - Bugfix
Version 2018.3.041.005 - Support of MAC OS X Mojave
Version 2018.3.041.003 - Bugfix
Version 2018.3.041.002 - Bugfix
Version 2018.3.041.001 - Bugfix
Version 2018.3.040.017 - Bugfix
Version 2018.3.040.016 - Bugfix
Version 2018.3.040.015 - Bugfix
Version 2018.3.040.014 - Bugfix
Version 2018.3.040.013 runs with SketchUp 2018/2017/2016 on PC & MAC.
Version 2017.3.038.019 - Bugfix
Version 2017.3.038.018 runs with SketchUp 2017/2016/2015 on PC & MAC 32&64 bit. Introduction of the List tool!
