TECLAsoftware Import DWG v1.0.2xx
A simple DWG importer. It requires Teigha File Converter
TECLAsoftware Import DWG TECLAsoftware ImportDWG is intened to enable MAKE users to import DWG files. It is based on Jim Foltz FreeDXF plugin.
It requires the Teigha File Converter (a Free converter). If TECLAsoftware ImportDWG can't locate the converter then it will ask the user to locate or to install it. To download it click on the following links:
Teigha File Converter for Windows Teigha File Converter for Mac OS X
The plugin works under Windows & MacOSX version; it was tested with SketchUp 2017, 2016, 2015 and 2014.
See the embeded Documentation
Release Note for TECLA Import DWG v1.0.2
Minor bugs fixed v1.0.2x == RBZ format fixed, loader.rb timer fixed and signed etc [TIG]
