IthilRenderTools v2.0.1
This plugin was called to help you with this routine work.
Most of simple materials are now create with just one click. Moreover, all similar materials having different color can be grouped and tagged and you can work with them using just one button.
For example: all plastic toys in kids room , all books, pencils on the desk, all magazines and etc. Imagine if you have to set up each of these materials?
Now, with this plugin you can automatically set them up without any problems!
This plugin also has a block of scnene materials analyzis and you can also search incorrect materials with wrong textures.
Plugin can rewrite paths to texures and proxies if you need to change your PC. Creates a report about lost materials and helps to find them and get back!:D
And finally a cherry on top of the cake - copying and drag&drop method of all maps in scene.
If you know what the procedural map is, this plugin will simplify your life!
Watch the explaining video and read manual below!
I hope my new extension will save you a lot of time!
