Visualizer_Scene_Exporter v1.3e2
VisualizerSceneExporter provides the ability to save Visualizer renders of sketchup files with multiple scenes. This plugin will save a set images for all scenes in a sketchup file. This extension requires that the Visualizer for Sketchup rendering plugin is already installed. You can specify the render time to be used in hours, minutes and seconds. The initial path and format of the images must first be defined in the Visualizer interface. VisualizerSceneExporter figures out where Visualizer saves its images and renames the saved images with the scene titles. A user has reported that you have to edit the Visualizer save prefix name at least once to avoid an error.
