Guides Proxy    v1.1
TIG (c) 2015
All rights reserved.
TIG-GuidesProxy.rb
Installation:
The RB file goes in the Plugins folder [restart Sketchup].
Or much easier, no restart required !
Use the Preferences > Extensions > Install button... on the RBZ archive.
Purpose:
A Toolset to backup your Guides, safe from Deletion...
Usage:
With a suitable Selection its tools become available through the Context-menu:
Guides to Proxy
If there are Guide-Lines or Guide-Points in the Selection, then they are made
into a "Proxy".
This is a new Group named "Guides_Proxy", on Layer "Layer0".
Its contents are either Guide-Points, each with a tiny piece of Line to
remember that Point"s location should Delete Guides be used subsequently;
or sub-groups, each containing one Line representing the original Guide-Line -
attributes are used to remember the original Guide-Line"s type -
i.e. infinite, infinite in one direction, fixed length.
Any "infinite" lines will extend to the limits of the Model"s bounds.
The Proxy's contents are put on a Layer named "Guides_Proxies".
The "Guides_Proxy" Group is locked in place.
The operation is one step undo-able.
Guides from Proxy
If there is one or more "Guides_Proxy" Groups in the Selection, then it is
used to recreate its remembered Guide-Points and Guide-Lines.
The Proxy Group is deleted on completion.
Delete Guides_Proxy
If there is one or more "Guides_Proxy" Groups in the Selection, then the Proxy
Group is unlocked and deleted.
1.0 20150505 First issue.
1.1 20150507 Layer is only made if the tool is used.
