BGSketchup_RBZ_maker    v1.0.7
This plugin allow to create a RBZ file from your installed plugin. This is useful for developers (like me) to create the rbz file without making a zip file and rename it.
The plugin list all the rb file in your plugin folder and show also files in the sub-folder that have the same name. Then, with the generate button, you can create the rbz with the same filename than your rb file and with version included.
If you want to encrypt (make rbs file), select on right panel the file and tick 'Yes' after 'Encrypt selected file'. Then the file will be encrypted within your rbz file, using the Sketchup scrambler. On your computer, the file remain not encrypt (it's just encrypted in the rbz) => it will save you a lot of time ! Selected files for encryption are reminded by the plugin : on next launch, the plugin will remain which file to encrypt or not (they are marked in red)
1.0.7 Corrected : BGSketchup Library not found if not in standard plugin folder REQUIRE BGSketchup_Library 2.5.6
1.0.6 : Corrected : issue if tick encryption without file selected This version need BGSketchup_Library v2.5.1
1.0.5: Corrected : Statistics included This version need BGSketchup_Library v2.5.0
1.0.4 : Optimized javascript error report
1.0.3 : Avoid "rbz created" message when used cancel creation
1.0.2 : Increase plugin window size Change text of 'Generate' button Deleted reference to BOM.css
1.0.1 : Remember the files which will be encrypted Change encryption checkbox text
1.0.0 : Initial release
