Double Line    v6x
This extension is intended to draw double lines (walls footprints), like the famous “dline.lsp” Autolisp routine in Autocad, in 2D or 3D. It have all the same features, extrude them in one go, and also quickly draw openings.
  • Settings: click on the icon, a dialog box is displayed, and lets you choose the parameters.
  • Click on the icon, click a first point, then as much points as needed. Inference is available hitting the Shift key. Colinear segments are not supported.
  • You can enter a length in the VCB, from last point picked, in the direction of the cursor.
  • Hit Escape at any time to cancel.
  • Hit Return at any time to stop and draw the wall. You are then ready to click a new series of points.
  • Double click at any time to close the shape (of course at least two wall segments are needed to do this).
  • Select another tool or hit Escape when done.
It's also possible to select a serie of connected edges and extrude them in one go.
Help file 'Double Line.pdf' can be found in the Resources folder of the plugin (DBUR_Dline).
