BGSketchup_Library v2.5.6
Library for BGSketchup plugins. Doesn't do anything by itself
2.5.6 (07/06/2015): Optimized : Allow to have translation number not continous.
2.5.5 (23/05/2015): Optimized : Improve debug mode by creating procedure bgSketchupdebugmode
2.5.4 (10/05/2015) : Corrected : return carriage error prevention in bgSketchuptojavaforHTML
2.5.1 (19/04/2015) : Corrected : Preventing errors for statistics on MAC
2.5.0 (12/04/2015) : Added : Translation through excel file system Optimized : Update manager for MAC Optimized : Change update manager menu name
2.4.1 (04/04/2015) : Optimized : Additionnal message with beta tester subscription (due to new email validation procedure)
2.4.0 (31/03/2015): Added : BGSketchup_Library version in stats Corrected : remove wrong prompt after beta tester subscribe
2.3.2 (26/03/2015): Corrected : Issue with jQuery on Comments plugins
2.3.1 (22/03/2015): Corrected : Now show real error message in error window
2.3.0 (21/03/2015): Added : New javascript error report
2.2.1 (19/03/2015) : Corrected : Now statistics work again (change temporary iframe name)
2.2.0 (16/03/2015) : Added : New error message Corrected : Architecture conversion system now use user preferences
2.1.0 (22/02/2015) : (not official) Added : Debug mode
2.0.11 (08/02/2015) : Corrected : change stats iframe name to avoid crash in SU8.
2.0.10 (06/02/2015): Corrected : avoid some errors & warnings in SU<2013
2.0.9 (30/01/2015): Added : Function to show length in fraction of inch Corrected : MAC users should appear again in stats
2.0.8 (07/01/2015) : Added : picture in background of updater Corrected : prevent from error if webdialog is not active Optimized : better javascript report (browser version, line splits) Optimized : better prompt message after activation.
2.0.7 (16/11/2014) : Add prompt after updating (a) plugin(s) to ask to restart. Close updater window after updating one or all plugins. Now download plugin using file + version from website. Updater lists also plugins not installed. Add beta tester request to plugins Add function for real temporary folder
2.0.6 (15/11/2014): Add SU version in javascript errors. Prevent from errors for statistics in BGSketchup_Comments plugin Change jQuery version to 1.11.1
2.0.5 (13/11/2014) : Status bar on updater
2.0.4 (12/11/2014) : Show also plateform in javscript errors
2.0.4 (11/11/2014) : Attempt (2) to catch statistics for MAC users : hide the iframe
2.0.3 (11/11/2014) : Attempt to catch statistics for MAC users
2.0.2 (11/11/2014): Add text to show plugin installation progress Remove 'ok' alert when a javascript bug appear in updater
2.0.1 (11/11/2014) : Change plugin update download to BGSketchup_Library folder
2.0.0 (09/11/2014) : Added : Plugin update manager New icon for debugging Include jscolor javascript plugin (color picker) Optimized : change extension search to upper case
1.5.2 (08/11/2014) : Simplify some code Add activation html window
1.5.1 (31/10/2014) : Try to improve javascript error report
1.5.0 (30/10/2014) : Library is now an extension
