3skeng 2025 Steelwork (SU2025/2024/2023 PC/MAC)    v2025.3.063.002
Put "3skeng Steelwork" to the test within a free 14 days trial period of the full version!
3skeng is an extension for the design and documentation of MEP and 3D steel structures. It is part of the 3skeng engineering package that also contains 3skeng Pipe, 3skeng Mount and 3skeng Channel!
3skeng Steelwork 2019 comes with the brand new features of quality control within 3skeng List (static considerations of centerlines and nodes) and IFC Export (IFC Structural Analysis View) that allows you to perform structural analysis of your 3skeng Steelwork designs in programs like Dlubal RFEM!
But let's just tell you guys some more about the tools and features of 3skeng:
3skeng Steelwork
All you need to draw steelwork elements is integrated in this powerful toolset. Work with structural steel elements in C-, I-, and U-shape with dimensions based British, American, European, Chinese and Russian standard elements. Generate chamfered bracing elements with a few clicks. Snap points and tools support the generation and alignment process.
By the way, we added an improved handling of IFC-properties for 3skeng elements during edit and connect copy!
3skeng Edit
Edit and re-arrange your Steelwork arrangements. The edit tool is so intuitive that it nearly follows alone your ideas. Use magnetic points or the input of numeric values in a way you know this from SketchUp.
3skeng Connect
Move or copy segments of a design to a new location. Magnetic points and lines will help you to connect the elements. With the new feature "Multicopy", all selected elements stay glued to the mouse until you press “Escape”!
3skeng Label
This tool enables you to add multi-text and labels to 3skeng elements. Various adjustable parameters allow individual adaptations to the particular label task at hand. During the automated alignment you determine the position and distance of the labels.
3skeng List
Select parts of your model or the entire model and generate a list with detailed part information. You can easily transfer the list content via the clipboard to your own calculation sheets or bill of materials.
3skeng Client
Use your 3skeng client to purchase, install and manage 3skeng Tools and Pipe libraries.
Install 3skeng
Learn how to download, install, troubleshoot, activate and purchase 3skeng by checking out the “3skeng-Starting-Guide.pdf” available on the download and faq page of http://www.3skeng.com.
Privacy Policy
Follow the link to learn more about the Privacy Policy of SHK and 3skeng: http://www.3skeng.com/en/privacypolicy.htm!
Install 3skeng
Learn how to download, install, troubleshoot, activate and purchase 3skeng by checking out the “3skeng-Starting-Guide.pdf” available on the download and faq page of www.3skeng.com.
First Steps
Click on a tool icon in the 3skeng toolbar.
The "3skeng Client" window will open and the appropriate tool will enter its work mode.
From now on, you can follow the context-sensitive tutors in the bottom tab of the "3skeng Client" that will help you through each step.
Context-sensitive tutors are embedded in the 3skeng client.
Learn to use 3skeng Steelwork with learning material in SketchUp file Format!
Download SketchUp files that guides you through the basic handling of the Steelwork tool (available on 3D Warehouse and 3skeng Homepage).
(Requires "Steelwork " (as demo or full license) for demonstration.)
Version 2025.3.063.002 runs with SketchUp 2025/2024/2023 on PC & MAC.
Version 2024.3.062.008 runs with SketchUp 2024/2023/2022/2021/2020 on PC & MAC.
Version 2023.3.060.012 runs with SketchUp 2023/2022/2021/2020 on PC & MAC.
Version 2022.3.056.012 runs with SketchUp 2022/2021/2020/2019 on PC & MAC (also M1).
Version 2022.3.056.011 runs with SketchUp 2022/2021/2020/2019 on PC & MAC.
Version 2021.3.053.009 - Bugfix
Version 2021.3.053.008 runs with SketchUp 2021/2020/2019/2018 on PC & MAC.
Version 2020.3.050.012 - Bugfix Channel Tool
Version 2020.3.050.011 - Bugfix Flex Tool
Version 2020.3.050.010 - Bugfix List and Sort Order
Version 2020.3.050.009 - Bugfix
Version 2020.3.050.006 runs with SketchUp 2020/2019/2018 on PC & MAC.
Version 2019.3.047.010 - Bugfix
Version 2019.3.047.009 - Bugfix
Version 2019.3.047.008 - Bugfix
Version 2019.3.047.007 - Bugfix
Version 2019.3.047.006 - Bugfix
Version 2019.3.046.009 runs with SketchUp 2019/2018/2017 on PC & MAC.
Version 2018.3.041.006 - Bugfix
Version 2018.3.041.005 - Support of MAC OS X Mojave
Version 2018.3.041.003 - Bugfix
Version 2018.3.041.002 - Bugfix
Version 2018.3.041.001 - Bugfix
Version 2018.3.040.017 - Bugfix
Version 2018.3.040.016 - Bugfix
Version 2018.3.040.015 - Bugfix
Version 2018.3.040.014 - Bugfix
Version 2018.3.040.013 runs with SketchUp 2018/2017/2016 on PC & MAC.
Version 2017.3.038.019 - Bugfix
Version 2017.3.038.018 runs with SketchUp 2017/2016/2015 on PC & MAC 32&64 bit. Introduction of the List tool!
Version 2017.3.036.021 - Bugfix for Edit tool.
Version 2017.3.036.020 - Bugfix for List & Label tool.
Version 2017.3.036.019 - Bugfix for List tool.
Version 2017.3.036.018 runs with SketchUp 2017/2016/2015/2014 on PC & MAC 32&64 bit.
Version 2016.3.026.006 runs with SketchUp 2016/2015/2014 on PC & MAC 32&64 bit.
Bugfix for usernames with special characters.
Version 2016.3.026.005 runs with SketchUp 2016/2015/2014 on MAC and PC 32&64 bit.
Version 2014.3.022.007 runs with SketchUp 2015/2014 on PC and MAC.
Version 2014.3.020.008 runs with SketchUp 2014 on PC and MAC.
Version 2.6.012 runs with SketchUp 2013 on PC. The installers are available on www.3skeng.com.
Version 2.6.012 runs with SketchUp 8 on PC. The installers are available on www.3skeng.com.
