3skeng 2025 Pipe (SU2025/2024/2023 PC/MAC) v2025.3.063.002
Put "3skeng Pipe" to the test within a free 14 days trial period of the full version!
3skeng Pipe is an extension for the design and documentation of MEP and 3D piping and rectangular ductwork. It is part of the 3skeng engineering package that also contains 3skeng Mount, 3skeng Steelwork and 3skeng Channel.
But let's just tell you guys some more about the tools and features of 3skeng:
3skeng Pipe (conceptual mode)
All you need to model conceptual pipelines is integrated in this tool.
Pipes, T-pieces, Y-pieces, reducers as well as elbows are generated and connected together in a smooth workflow with only few mouse-clicks.
You have access to the most common standards (ANSI, ASME, ISO EN and JIS) and determine the dimensions of fittings with only a few clicks. Magnetic points and a memory function are powerful parts of the tool and assist you in the process.
3skeng Pipe (detail mode)
With just one switch you can convert 3skeng pipe to a tool working in the same intuitive way with detail library elements. 3skeng edit, connect, list and label can be used in the same way as in conceptual mode. Even a combination of detail and conceptual pipeline elements is possible.
The embedded auto-pipe function helps you to connect 3skeng components and allows you to select one of the possible configurations. Auto-Pipe is available for both conceptual and detail mode.
By the way, we added an improved handling of IFC-properties for 3skeng elements during edit and connect copy!
Libraries for 3skeng Pipe (detail mode)
Libraries with several ten thousand parts in metric and imperial sizes are available in the in-app store. Library parts are based on standards or on popular pipe & tube systems and are grouped by material. Manage your libraries within the 3skeng client.
Available libraries for 3skeng Pipe
Plastic
- Imperial CPVC
- Imperial PVC DWV Piping (Drain-Waste-Ventilation)
- Imperial Fiberglass
- Metric PE80/PE100
- Metric PE-HD
- Metric PP
- Metric PVC-C
- Metric PVC-U
- Metric PVDF/PVDF-HP
Ductile Iron
- Imperial Ductile Iron with grooved connection (AWWA)
- Imperial Ductile Iron with mechanical joint & flanged connection (AWWA)
Steel
- Imperial Steel B36.10M
- Metric Steel Piping
- Metric Steel Piping Pressing Socket
Steel (Grooved Connection)
- Met-Imp Steel Grooved Piping 2-12in
- Met-Imp Steel Grooved Piping 14-60in
- Imperial/Metric Steel Sprinkler with grooved connection
Stainless Steel
- Imperial Stainless Steel B36.19M
- Metric Stainless Steel Piping
- Metric Stainless Steel Piping, DIN EN 10357
- Metric Stainless Steel Pressing Socket
Stainless Steel (Pure Use)
- Imperial Stainless Steel Tubing for pure use
Ventilation and Exhaust Duct
- Imperial Stainless Steel Ductwork
- Imperial Galvanized Steel Ductwork (Plug Joint)
- Metric Stainless Steel Ductwork (Flanged)
- Metric Galvanized Steel Ductwork (Plug Joint)
- Metric Galvanized Steel Ductwork (Flanged)
High Vacuum
- Stainless Steel Vacuum CF/UHV
- Stainless Steel Vacuum ISO-F
- Stainless Steel Vacuum ISO-K
- Stainless Steel Vacuum ISO-KF
Copper
- Metric Copper Pressing Socket
3skeng Edit & Rotate
Edit and re-arrange your pipe, fitting and component arrangement. The edit tool is so intuitive that it nearly follows alone your ideas. Use magnetic points or the input of numeric values in a way you know this from SketchUp.
3skeng Connect
Move or copy segments of a pipe arrangement to a new location. Magnetic points will help you to connect the elements exact aligned to the pipe center. All elements will be aligned in the pipe direction, which helps you to generate and change models very fast.
With the new feature "Multicopy", all selected elements stay glued to the mouse until you press “Escape”!
3skeng Label
This tool enables you to add multi-text and labels to 3skeng elements. Various adjustable parameters allow individual adaptations to the particular label task at hand. During the automated alignment you determine the position and distance of the labels.
3skeng List
Select parts of your model or the entire model and generate a list with detailed part information. You can easily transfer the list content via the clipboard to your own calculation sheets or bill of materials.
3skeng Client
Use your 3skeng client to purchase, install and manage 3skeng Tools and Pipe libraries.
Install 3skeng
Learn how to download, install, troubleshoot, activate and purchase 3skeng by checking out the “3skeng-Starting-Guide.pdf” available on the download and faq page of http://www.3skeng.com.
Privacy Policy
Follow the link to learn more about the Privacy Policy of SHK and 3skeng: http://www.3skeng.com/en/privacypolicy.htm!
Install 3skeng
Learn how to download, install, troubleshoot, activate and purchase 3skeng by checking out the “3skeng-Starting-Guide.pdf” available on the download and faq page of www.3skeng.com.
First Steps
Click on a tool icon in the 3skeng toolbar.
The "3skeng Client" window will open and the appropriate tool will enter its work mode.
From now on, you can follow the context-sensitive tutors in the bottom tab of the "3skeng Client" that will help you through each step.
Context-sensitive tutors are embedded in the 3skeng client.
Learn to use 3skeng Pipe with learning material in SketchUp file Format!
Download SketchUp files that guides you through the basic handling of the Pipe tool (available on 3D Warehouse and 3skeng Homepage).
(Requires "Pipe" (as demo or full license) for demonstration.)
Version 2025.3.063.002 runs with SketchUp 2025/2024/2023 on PC & MAC.
Version 2024.3.062.008 runs with SketchUp 2024/2023/2022/2021/2020 on PC & MAC.
Version 2023.3.060.012 runs with SketchUp 2023/2022/2021/2020 on PC & MAC.
Version 2022.3.056.012 runs with SketchUp 2022/2021/2020/2019 on PC & MAC (also M1).
Version 2022.3.056.011 runs with SketchUp 2022/2021/2020/2019 on PC & MAC.
Version 2021.3.053.009 - Bugfix
Version 2021.3.053.008 runs with SketchUp 2021/2020/2019/2018 on PC & MAC.
Version 2020.3.050.012 - Bugfix Channel Tool
Version 2020.3.050.011 - Bugfix Flex Tool
Version 2020.3.050.010 - Bugfix List and Sort Order
Version 2020.3.050.009 - Bugfix
Version 2020.3.050.006 runs with SketchUp 2020/2019/2018 on PC & MAC.
Version 2019.3.047.010 - Bugfix
Version 2019.3.047.009 - Bugfix
Version 2019.3.047.008 - Bugfix
Version 2019.3.047.007 - Bugfix
Version 2019.3.047.006 - Bugfix
Version 2019.3.046.009 runs with SketchUp 2019/2018/2017 on PC & MAC.
Version 2018.3.041.006 - Bugfix
Version 2018.3.041.005 - Support of MAC OS X Mojave
Version 2018.3.041.003 - Bugfix
Version 2018.3.041.002 - Bugfix
Version 2018.3.041.001 - Bugfix
Version 2018.3.040.017 - Bugfix
Version 2018.3.040.016 - Bugfix
Version 2018.3.040.015 - Bugfix
Version 2018.3.040.014 - Bugfix
Version 2018.3.040.013 runs with SketchUp 2018/2017/2016 on PC & MAC.
Version 2017.3.038.019 - Bugfix
Version 2017.3.038.018 runs with SketchUp 2017/2016/2015 on PC & MAC 32&64 bit. Introduction of the List tool!
Version 2017.3.036.021 - Bugfix for Edit tool.
Version 2017.3.036.020 - Bugfix for List & Label tool.
Version 2017.3.036.019 - Bugfix for List tool.
Version 2017.3.036.018 runs with SketchUp 2017/2016/2015/2014 on PC & MAC 32&64 bit.
Version 2016.3.026.006 runs with SketchUp 2016/2015/2014 on PC & MAC 32&64 bit.
Bugfix for usernames with special characters.
Version 2016.3.026.005 runs with SketchUp 2016/2015/2014 on MAC and PC 32&64 bit.
Version 2014.3.022.007 runs with SketchUp 2015/2014 on PC and MAC.
Version 2014.3.020.008 runs with SketchUp 2014 on PC and MAC.
Version 2.6.012 runs with SketchUp 2013 on PC. The installers are available on www.3skeng.com.
Version 2.6.012 runs with SketchUp 8 on PC. The installers are available on www.3skeng.com.
