SketchUcation Premium Membership
[Plugin] RoundCorner - v2.3a - 26 May 11
Postby Fredo6 » Thu Jul 09, 2009 10:41 pm
IMPORTANT:Please make sure that you have full Read / Write permissions in the folder where you install RoundCorner
RoundCorner performs the rounding of the edges and corners of 3D shapes along a 2D profile, in 3 modes: Round corners, Sharp corners and Bevel. RoundCorner also supports concave corners (always rendered as Round) and non-orthogonal edge faces. Corners can have 2, 3, or more edges.
Quickcard RoundCorner - English - v2.1.pdf
Quickcard RoundCorner - French - v2.1.pdf
  • Language: English, French, Spanish, Chinese, German (thanks to all kind translators). Thanks to Christophe Plassais for the French user manual.
  • Menus: by default, it is installed in Tools > Fredo6 Collection > RoundCorner
  • Icon toolbar: by Default ‘RoundCorner’. 3 icons are available, but you can configure which ones to display (menu Default Parameters…)
  • The plugin is free, for private and commercial usage. There is a donation menu however.
1) Download and Open the archive
2) Select All (Ctrl A)
3) Extract into the Sketchup Plugin Directory
4) Answer YES to overwrite all existing files if any
The footprint in the SU Plugin Directory must be:
On Mac the SU plugin directory should be:
Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins
CAUTION: NEVER rename or move files from their folders. If you are unsure of your unzip operation, do it in a neutral folder and check that you reconstruct the right footprint. Then transfer the folders and files to the SU Plugin Directory.
DOWNLOAD RoundCorner 2.3a – 26 May 11
RoundCorner 2.3a - 26 May 11.zip
IMPORTANT: Requires to download LibFredo6 3.7 or higher if not already installed
CONFLICTING PLUGINS: some plugins conflict with RoundCorner and some others of my scripts
  • Some versions of Podium
  • SunPosition
  • Matchbox
  • Select geometry (edges, faces) and click on one of the 3 icons. Edges are highlighted in Red and the offset borders in green. For convenience, you have several selection modes which can be activated via the buttons in the left part of the palette (or via Ctrl and Shift keys)
  • You can add / remove edges from the selection by clicking on a single edge, on a face (include all edges of the face) or double click (include all connected edges)
  • Adjust the Offset parameter by typing the new value in the VCB or clicking in the small field in the button palette. This will be reflected in the preview.
  • Adjust the number of segments for the rounding (default is 6). Click in the button palette or type a new value followed by ‘s’ in the VCB
  • You have other parameters which you modify. See documentation.
  • Click in the empty space or on the checkmark icon to generate the model
  • Note: you can save the parameters across Sketchup session by using the small icons with a disk and letter. See documentation
  • It is always a good idea to check the contextual menu to see available options
There is an excellent introduction to the tool written by Aidan Chopra: see http://sketchupdate.blogspot.com/2010/07/take-edge-off-roundcorners.html
CAUTION: Round Corner mode is very greedy in generation of faces and edges. For a standard cube (8 corners), with rounding made of 6 segments, you would generate a minimum of 8 x 36 + 12 x 6 = 360 new faces (possibly 680 when faces are not orthogonal and corners must be triangulated). In contrast, Sharp corner would only generate the rounding edges, with no corner, and create 12 x 6 = 60 new faces.
Note: there may be some limitations and issues for some complex geometric configurations.
RoundCorner 2.3a - 26 May 11: Fixes a problem of performance (slow navigation) which was reported by some Mac users.
RoundCorner 2.2c - 23 Feb 11: Fixes a small bug in 2.2b.
RoundCorner 2.2b - 23 Feb 11: Release without the traces that were in 2.2a.
RoundCorner 2.2a - 12 Jan 11: Technical release along with LibFredo6 3.6 and SU8. No functional changes, but it is advised to upgrade for support.
RoundCorner 2.1c - 11 Nov 09: Stable version
Fredo6
Top SketchUcator
Re: {Plugin] RoundCorner 2.0a - 9 Jul 09
Postby thomthom » Thu Jul 09, 2009 11:28 pm
:thumb: :berserk:
I can't wait to try out this new version.
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby dacad » Thu Jul 09, 2009 11:34 pm
Dear Fredo6:
this is getting to a point that it's getting hard to find new words to describe your work and what your doing for this comunity and sketchup itself...so i'll just have to say:
THIS IS UNBELIEVABLE!!! THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU, THANK YOU.
sorry for my lack of originality :)
I'm feeling bad for not helping you with nothing since your plugins more than once have helped finishing my (personal or professional) projects, and you never ask nothing in return for this plugins, so if you need any help in any project of yours, (modeling, texturing , rendering etc), some tips, tricks, toturials, info on software or whatever or even just a good discussion, anything that i can help just tell me. i would gladly help you
Sketchup should raise a statue to people like you or at least mentione guys like you for keeping sketchup alive and at leas just suport high poly since the plugins are getting more and more sofisticated (sorry my english) and the only things "pulling them down" it's sketchup itself with their own limits
After all the plugins you released, and all for free (are you nuts?!?!) i don't know what more to do or say to show how gratefull i am. Again: thank you :thumb:
David
dacad
Postby xrok1 » Thu Jul 09, 2009 11:40 pm
WOW!!
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby TIG » Thu Jul 09, 2009 11:46 pm
As always another tour de force...
The tools work very well... except the bevel/chamfer - which I suspect is the simplest of the three ? - which keeps bug-splatting me e.g. a 1m cube 100/150mm bevel to top or all edges... Sure it'll be a simple fix...
Global Moderator
SketchUp version: 8
License type: Pro
Postby utiler » Thu Jul 09, 2009 11:50 pm
Legend Fredo..... you don't know how much time you have saved me.... :sketchstatic: :sketchstatic:
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby ely862me » Thu Jul 09, 2009 11:58 pm
:shock:
Another masterpiece!!Works like a charm!
Thank you very much!
Elisei
Elisei (sketchupper)
____________________________________________________________
Come and See EliseiDesign
ely862me
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Coronel » Fri Jul 10, 2009 12:12 am
If you came to Spain you are invited to take a "sangria", wine or whatever at the named "best natural beach" of the world: Cies Islands.
Thank you very much
Coronel
Postby CadFather » Fri Jul 10, 2009 12:28 am
.....the Master!
..and that's how sketchup became open source
Thank You! :D
Quarr-IT - SketchUp Training from the Master.. . ;) .
CadFather
Name: Max Coppoletta
Postby utiler » Fri Jul 10, 2009 12:31 am
Coronel wrote:If you came to Spain you are invited to take a "sangria", wine or whatever at the named "best natural beach" of the world: Cies Islands.
Thank you very much
That goes for Queensland, Australia..... your more than welcome here Fredo; I'll look after you like a King!!!
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby EarthMover » Fri Jul 10, 2009 2:57 am
Looks stellar. Should help add a new level of realism to Sketchup Rendering. Nothing like a nice round corner to catch those specular highlights! :thumb:
Thank you kind sir!!
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
EarthMover
Top SketchUcator
Postby •BTM » Fri Jul 10, 2009 3:13 am
:sketchstatic: Amazing as usual!
•BTM
Postby su30 » Fri Jul 10, 2009 7:39 am
It's great!
Thank you Fredo!
I have to say your rich production and hardworking spirit affect me very much!
-best wish from beijing
su30
su30
Postby Pilou » Fri Jul 10, 2009 8:24 am
Rondement mené! :fro:
Bravo! :enlight:
Works fine in the V6
Bug Splatt in the V7 :o
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby chango70 » Fri Jul 10, 2009 9:13 am
That is brilliant! Thanks :fecstatic: :sketchstatic:
chango70
Postby Free Agent » Fri Jul 10, 2009 9:35 am
you are a genius FREDO sketchup would be a steaming pile of crap without you... amen
Free Agent
Postby TomDC » Fri Jul 10, 2009 9:53 am
Oooh ... Excellent ruby! Thanks!
Bill Maher on the French: "They invented sex during the day, lingerie and the tongue."
TomDC
Postby Fredo6 » Fri Jul 10, 2009 10:04 am
Pilou wrote:Bug Splatt in the V7 :o
Pilou,
Thanks. Could you be more explicit on the bug splat in v7. TIG has one too, but apparently only with Bevel.
Do you see the Progress bar and then get a bugsplat, or does it happen right away when you execute?
Fredo
Fredo6
Top SketchUcator
Re: [Plugin] RoundCorner 2.0a - 9 Jul 09
Postby TIG » Fri Jul 10, 2009 10:33 am
Note: my bugsplats are with v7 and using bevel only, it does work perhaps 10% of tries, rest it splats immediately ! :?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Fri Jul 10, 2009 10:37 am
As soon as I press enter for apply! Splafffffffffffff :o
works one time and the second splafff :D
with the 3 tools!
so yet very instable (for me) ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby Fredo6 » Fri Jul 10, 2009 11:10 am
TIG, Pilou,
Does it happen with complex shapes, meaning those where the operation would take several seconds.
I never got any Splat in my environments, so it is difficult for me to reproduce. But it maybe related to the way I make the operation interruptible. I guess that because you probably have fast machines, something happens in the first milliseconds of the operation.
It may be specific to SU7, because precisely SU7 blocks the GUI while creating geometry.
Fredo
Fredo6
Top SketchUcator
Postby massimo » Fri Jul 10, 2009 11:22 am
Thank you so much Fredo. I had a quick test in SU 6 and it works very well.
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Postby TIG » Fri Jul 10, 2009 11:47 am
Fredo6 wrote:TIG, Pilou,
Fredo
My splats occur with a very simple 1m cube with 100mm bevel, to top face or multi-edges. it usually splats, but when it works it's done almost instantaneously ! The other 2 types of rounding work fine - never splatted yet !!!
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Fri Jul 10, 2009 11:51 am
Could it be that it bugsplats as it tried to create faces too small?
TIG: If you make a 10m cube and use 1000mm bevel, does it work then?
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Fri Jul 10, 2009 12:04 pm
thomthom wrote:Could it be that it bugsplats as it tried to create faces too small?
Good thinking - although you might think that a simple bevel, with no small faces, would not respond to this (unlike the rounding options that cause NO splats at the 1m/100m size)... BUT I scaled it up x10 [10m cube 1m bevel] AND the bevel works fine for almost all of the time - after many tests I did eot one non-repeatable splat...
Seems there's something in that idea ?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Fri Jul 10, 2009 12:21 pm
ah yes that was that! Scale was 1 /100 too little! :enlight:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby Fredo6 » Fri Jul 10, 2009 1:02 pm
Only relevant for bugsplats issues
I still don't understand what is the exact problem. I tried under SU7 with a cube of 10 meters dimensions and a 1 mm bevel, and it works without any splat (though you hardly see the bevel).
In any case, as the origin might be subtle, I have equipped the processing methods with a file trace (file FredoTraceRoundCorner.txt in the Sketchup Plugins directory). You just drop the attached file in the ROUNDCORNDER_Dir_20 folder.
If you are able to reproduce a bugsplat, could you please send me the text file.
Fredo
[Edit 11 Jul 09] Attachment removed. Fix in release 2.0b
Fredo6
Top SketchUcator
Postby DIEGO-RODRIGUEZ » Fri Jul 10, 2009 1:10 pm
Fredo , thank you very much for this tools.
I tested in sketchup 7pro and Sketchup 6pro, and it works perfect.
Using Windows XP SP3 in Spanish.
If you need any proof of plugins, in particular, just tell me.
Tip>
Can upload a file with different geometries, to test your plugins?
To verify any type of error
DIEGO-RODRIGUEZ
Banned
Postby Free Agent » Fri Jul 10, 2009 1:24 pm
all works fine here, i tried it on a 20mm box with a 1mm bevel and that works perfect. SU7
however with that special command bar that appears when i hover the mouse over any button there the cursor prompt say invalid ???
Free Agent
Postby Pilou » Fri Jul 10, 2009 2:14 pm
Yep with little measures that splatting soon as Enter!
Beginning to see the time scroll barr... then plaffffffffff! :D
Something like these measures for first tool!
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Next
Return to Plugins
Users browsing this forum: bugmenot123, Daniel S, Hutton, kooops, meocram, mrsam_007 and 13 guests
