[Plugin] RoundCorner - v3.3a - 18 Dec 18
Re: [Plugin] RoundCorner - v3.2e - 12 Oct 17
Postby Einstein » Sun Mar 18, 2018 7:09 pm
Hi!
I cannot get to a certain softening result exampled in the manual. Both Borders and Corners are sharp edges there, only Inner Edges are soft and smooth. In my case, Corners are also soft and smooth even though I didn't check them as soft and smooth.
Einstein
Postby fredo6 » Sun Mar 18, 2018 10:13 pm
Einstein wrote:Hi!
Thanks for signaling. Strange that nobody did before, because it is likely dated 207, when SU2017 introduced a change of the API (related to IDs and Explode Group) that screwed up a lot of plugins.
I fixed it in v3.2f.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] RoundCorner - v3.2f - 18 Mar 18
Postby fredo6 » Sun Mar 18, 2018 10:15 pm
NEW RELEASE: RoundCorner v3.2f - 18 Mar 18
RoundCorner 3.2f is a maintenance release. It fixes an old problem for SU2017 and SU2018 related to the configuration of edge properties.
Home Page of RoundCorner for information and Download.
Main post of this thread.
fredo6
PluginStore Author
PluginStore Author
Postby Einstein » Mon Mar 19, 2018 10:35 am
Thanks for the fix!
I was also wondering if Round Corner could work woth groups and compos (not only loose geometry), so that we don't have to open a group to chamfer its edges. It would make work much faster with e.g. multiple boxes at once.
Einstein
Postby fredo6 » Mon Mar 19, 2018 2:37 pm
Einstein wrote:I was also wondering if Round Corner could work woth groups and compos (not only loose geometry), so that we don't have to open a group to chamfer its edges. It would make work much faster with e.g. multiple boxes at once.
Not planned with RoundCorner unfortunately.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby lema » Thu Mar 29, 2018 10:03 am
such a rounding is possible? (right 2 pictures)
lema
Postby fredo6 » Thu Mar 29, 2018 10:11 pm
Correct. RoundCorner can only perform symmetrical rounding.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby alexanor » Sun Apr 01, 2018 8:03 pm
Hello everybody!
I support lema. Too often this feature is missing.
There is also a need to build such corners.
I understand that this operation can be done using the Curviloft plug-in, but still, it would be easier and faster.
Thank you very much Fredo6 for his work !!!
alexanor
Re: [Plugin] RoundCorner - v3.2g - 01 Apr 18
Postby dnassif » Sat Jun 16, 2018 7:20 am
hi
I have make 17 and have downloaded fred 06 and round corner but I am having issues with getting into sketch up need advice place. I have enabled both in sketch up but it doesn't show in tools what do I need to do?
dnassif
Premium Member
Premium Member
Postby fredo6 » Sat Jun 16, 2018 3:42 pm
dnassif wrote:hi
How did you install the plugins?
- Sketchup Extension manager, after downloading the RBZ files?
- or Sketchucation PluginStore tool?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby uwesketch » Thu Jul 26, 2018 8:54 pm
Rounding an edge excluding the corners generates the arc as connected segments, not a curve/arc.
is it possible that along edges an arc/curve is generated?
That would help a lot in technical drawings where I need to know the radius of the rounding arc.
The corners are generated perfectly.
uwesketch
Postby fredo6 » Sat Aug 11, 2018 11:06 pm
uwesketch wrote:Hi
This is actually not so easy, because Arc / Curve is a transient property (think of an Arc when deformed by non-uniform scaling).
There are plugins to retrieve the center of an arc, as far I as remember.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby SEANHOLMES » Tue Sep 11, 2018 3:52 pm
I am having this new error can anyone help me out its not allowing me to continue use of this product.
SEANHOLMES
Postby TIG » Wed Sep 12, 2018 11:32 am
Why not follow the instructions in the message and get the newest version of LibFredo ?
It's available from the PluginStore, just like the related extensions which use that Lib...
Your version is very out of date !
After installing the Lib restart SketchUp to ensure everything gets synced...
Global Moderator
Postby josegara » Fri Sep 14, 2018 7:32 pm
You are god my friend. A brutal tool
josegara
Postby josegara » Fri Sep 14, 2018 7:33 pm
Sketchup owes you
josegara
Postby ITman496 » Sat Oct 13, 2018 6:15 am
Hello, I've been a loyal user of this tool for a very long time, great work!
I've been trying for a long time to get it to sort of.. maintain a radius when rounding a corner. For example, I'm trying to set up a part and calculate pocket cuts of a CNC machine's endmill, when it can't accurately do an interior corner because of the size of the endmill. When I round with say a 1/8" radius, it seems to do a non-circular rounding when doing anything other then 90 degrees. Is there a solution for this? Doing it manually sucks =)
Here is a picture for an example. I want the right's inner bends, but the plugin instead gives me what's on the left.
ITman496
Postby Dave R » Sat Oct 13, 2018 1:51 pm
I've never noticed that but you're right.
ITman496 wrote:Is there a solution for this? Doing it manually sucks =)
At least for now you could use TIG's 2D Fillet from his 2D Tools set.
Global Moderator
Postby fredo6 » Sat Oct 13, 2018 5:29 pm
ITman496 made a very relevant observation.
Indeed this concerns borders where the edge angle is different from 90 degrees.
In RoundCorner and FredoCorner, the offset is measured perpendicularly to the borders, along their faces.
As a result, the rounding is not a circle, but it is scaled to be tangent at faces. All pictures below generated with an ofset of 1.5 m and a Circle profile.
However, there is another possibility, which is to make the rounding so that it matches a circle with a radius equal to the offset value
This is a matter of choice indeed, so it has to be an option, which I am implementing in FredoCorner.
Below are the same solid rounded with the two options
As far as I remember, I discarded the radius mode because it gives border rounding which are visually non uniform. But, the option is valid geometrically, especially if it is to generate the shape for 3D Printing.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Dave R » Sat Oct 13, 2018 5:49 pm
Thank you for that explanation, Fredo. I'm happy to know it'll be a feature in FredoCorner.
Global Moderator
Postby fredo6 » Sat Oct 13, 2018 5:54 pm
Dave,
It should be possible in FredoCorner (but more complex in RoundCorner).
Again, the result is visually different
fredo6
PluginStore Author
PluginStore Author
Postby ITman496 » Sat Oct 13, 2018 7:43 pm
Thank you so much Fredo! My years of suffering are over!
I can't wait for the update to fredocorner!
And Dave, I will try 2D tools. Thank you!
ITman496
Postby fredo6 » Sun Oct 14, 2018 1:56 pm
ITman496 wrote:Thank you so much Fredo! My years of suffering are over!
I'll publish it later today.
here is the video
fredo6
PluginStore Author
PluginStore Author
Postby Dave R » Sun Oct 14, 2018 2:12 pm
Wow! Very good.Thank you!
Global Moderator
Re: [Plugin] RoundCorner - v3.3a - 18 Dec 18
Postby fredo6 » Tue Dec 18, 2018 10:45 pm
NEW RELEASE: RoundCorner v3.3a - 18 Dec 18
Requirement: LibFredo6 v8.7a or above
RoundCorner 3.3a is a maintenance release.
fredo6
PluginStore Author
PluginStore Author
Postby oyercab » Thu Dec 27, 2018 6:02 pm
Hello,
About two weeks ago I received an error message about RoundCorner when starting Sketchup 2018 Pro. I didn't save the message, and don't know exactly what it said, but RoundCorner was no longer available. I'm on macOS High Sierra (can't upgrade any higher). I updated Fredo6 to the latest version, restarted Sketchup, and then updated RoundCorner and restarted. The toolbar appears, but is completely unresponsive. I also tried installing FredoCorner. Its toolbar has never appeared, but I can put the icons in my main toolbar. It is also unresponsive.
In the "Fredo6 Collection" under Tools both RoundCorner and FredoCorner are showing, along with their menus, but I can't do anything with them. I've been using RoundCorner for years, and can barely function without it (many thanks, Fredo). Please, somebody help!
(I did install through Extension Manager in Sketchup).
Thank you, and hope everybody had a Merry Christmas.
oyercab
Postby fredo6 » Fri Dec 28, 2018 8:30 am
@oyercab
You seem to use Sketchup 8. Can you confirm?
Can you open the Ruby Console, and check for error message when you launch RoundCorner.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby oyercab » Fri Dec 28, 2018 2:46 pm
fredo6 wrote:@oyercab
Fredo
Hello Fredo, I use SU2018 Pro. I did open Ruby Console, and the LibFredo6 plugin seems to be the problem. I installed the latest version through Extension Manager and followed instructions carefully, closing and re-starting Sketchup before installing RoundCorner. I then closed and re-started before installing FredoCorner. As I said, the toolbars and icons are there, but they don't do anything.
This problem started suddenly, after I had been away from the computer for a week. When I launched SketchUp, the error message about RoundCorner was on the screen, and its toolbar had disappeared. I'm going to try deleting and re-installing LibFredo6 again, but have already done that several times. Can I post the Ruby Console info here if I have no luck?
oyercab
Postby fredo6 » Fri Dec 28, 2018 3:26 pm
oyercab wrote:
fredo6 wrote:I did open Ruby Console, and the LibFredo6 plugin seems to be the problem.
Could you copy - paste the errors you see in the Ruby console.
fredo6
PluginStore Author
PluginStore Author
Postby oyercab » Fri Dec 28, 2018 3:33 pm
Error: #<Errno::ENOENT: No such file or directory @ rb_sysopen - /Users/21imac/Library/Application Support/.LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
/users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in `initialize'
/users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in `open'
/users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:144:in `write_to_file'
/users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6registry.rbe:127:in `store'
/users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1278:in `usage_use'
/users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1266:in `command_invoke'
/users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1249:in `block (2 levels) in build_config_commands'
/users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1348:in `call'
/users/21imac/library/application support/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1348:in `block in add_command'
SketchUp:1:in `call'
oyercab
PreviousNext
Return to Plugins
Users browsing this forum: Ani1234, bvcero, francesko, imagination, knihus, Mher777, pwaffle, serlue and 26 guests
