[Plugin] RoundCorner - v3.3a - 18 Dec 18
Re: [Plugin] RoundCorner - v3.1a - 13 Nov 15
Postby fredo6 » Thu Mar 10, 2016 7:41 pm
numerobis wrote:I have two problems with the latest version (installed on SU2015 x64)
numerobis wrote:1. Round corner: The offset value is displayed but not recognized by the plugin if it is entered using the TAB-Key. I need to re-open the function to make it active. If i use the toolbar field it is working.
Thanks for signaling this bug. Easy to fix.
numerobis wrote:2. Bevel edges: There is a smoothing issue with beveled geometry. After beveling i always need to fix the smoothing.
What is the problem exactly? which edges are you referring to ?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby numerobis » Fri Mar 11, 2016 9:17 pm
fredo6 wrote:Thanks for signaling this bug. Easy to fix.
:thumb:
fredo6 wrote:What is the problem exactly? which edges are you referring to ?
The edges are showing up correctly (hard edges) but the shading is messed up in display and rendering.
I have to use the smoothing controls after the beveling and set it to hard egdes again to get this fixed.
numerobis
Postby fredo6 » Sat Mar 12, 2016 3:30 pm
numerobis wrote:The edges are showing up correctly (hard edges) but the shading is messed up in display and rendering.
What should I do then ?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby numerobis » Sat Mar 12, 2016 5:00 pm
I don't know. I can only say that there is something different to the normal hard edges. The shading is wrong (soft). And i think this problem is new. I never noticed this in older versions.
numerobis
Postby fredo6 » Sat Mar 12, 2016 7:20 pm
numerobis wrote:I don't know. I can only say that there is something different to the normal hard edges. The shading is wrong (soft). And i think this problem is new. I never noticed this in older versions.
Could it be related to "cast-shadow" ?
fredo6
PluginStore Author
PluginStore Author
Postby numerobis » Mon Mar 14, 2016 8:10 pm
Sorry, i don't understand. Which "cast-shadow"?
numerobis
Postby johnwmcc » Sat Mar 19, 2016 2:48 pm
I've just installed this plugin in SU 2016, on iMac 5K Retina running El Capitan (OS X v 10.11.3).
The dialogue box is incredibly small and hard to read on this high res-screen. Is there any way of making it bigger?
The overall height of your dialogue is only about 8mm, and the text less than 2mm high.
The screen shot (attached) seems to make it look a bit bigger, but in reality I need a magnifying glass to read it!
PS. Sorry again - I've only just seen earlier posts on this subject. Will see if the suggestions there help.
PPS. Checking the Retina box in the Default Parameters dialogue helps, but only enlarges the boxes and icons, not the text
Seems that there are general problems with very high res displays for SketchUp, not yet fully resolved, though there are partial workarounds.
johnwmcc
PluginStore Author
PluginStore Author
Postby mintra » Wed Mar 30, 2016 10:33 pm
This is a gem. Though I treated myself to a 5k mac and the button pallet is too small to read at 5k so I have to change the resolution of my mac to use this. Is their some setting for button pallet size?
mintra
Postby klarans » Sat Apr 02, 2016 11:02 am
Where do I find the download buttons for your plug-ins?
klarans
Postby Dave R » Mon Apr 04, 2016 3:45 pm
klarans wrote:Where do I find the download buttons for your plug-ins?
Look at the first post of the thread. The link is right out in plain sight.
Global Moderator
Postby rv1974 » Mon Apr 18, 2016 10:37 pm
Have anybody requested for filleting of not connected surfaces here? :fro:
rv1974
Postby delux3789 » Fri May 13, 2016 10:27 pm
Xcelente Graciassss
delux3789
Postby sus4 » Tue May 31, 2016 6:38 pm
Can future scrub mouse adjust scale ?
sus4
Postby IAN21 » Thu Jun 30, 2016 5:00 pm
how to download this plugin? i am just new here...
:ecstatic:
IAN21
Postby _reinhart » Fri Jul 01, 2016 3:42 am
I am trying to get Round Corner to work in SU2016. I keep getting the error message that tells me I need to have the LibFredo6 installed (see image), but I know that I have LibFredo6 installed because I am using other plugins that require it and they are working fine. Any suggestions would be great!
Thanks!
Chris
_reinhart
Postby Dave R » Mon Jul 04, 2016 11:05 am
Have you tried installing the latest version of LibFredo6? If you are running older versions of the other Fredo extensions, they might not require the newer revision of LibFredo6. Maybe you should also check to see if there are updates for those other extensions. If you are using the SCF Plugin Store, updating them should only take seconds.
Global Moderator
Postby chowette » Tue Jul 05, 2016 9:37 pm
I am having the same issue here.
It does work ok on my laptop with Win7 and SU2016 and only libfredo and round corner.
But on my linux box under wine with both libfredo and roundcorner, it does show the same error message as _reinhart asking for libfredo...
Is there a debug flag somewhere to get some details in the ruby console? Maybe something else i can try to give you a more detailed error report. As a software dev, I can help you debug this, but with some guidance because I am not familiar with ruby.
chowette
chowette
Postby fredo6 » Tue Jul 05, 2016 11:06 pm
chowette wrote:But on my linux box under wine with both libfredo and roundcorner, it does show the same error message as _reinhart asking for libfredo...
I think on Linux, the problem may come from the order of loading.
So the best is to delete the file Fredo6_Roundcorner.rb (and thus run without security mode).
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby chowette » Fri Jul 08, 2016 8:06 pm
Yes this is the problem, if I run
Code: Select all
load "Fredo6_Roundcorner.rb"
in the console, it runs ok.
that does nothing; eg. no error, but no plugins loaded either.
I have fixed it by requiring explicitly libFredo6 before using it.
here is my Fredo6_Roundcorner.rb
Code: Select all
=begin
# Copyright © 2015 Fredo6 - Designed and written August 2011 by Fredo6
# Permission to use this software for any purpose and without fee is hereby granted
# Distribution of this software for commercial purpose is subject to:
#  - the expressed, written consent of the author
#  - the inclusion of the present copyright notice in all copies.
# THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
# IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
# WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
# Description   :  Generic top loader for LibFredo6-compliant scripts.
# This file does checking on the environment for correct installation of LibFredo6 and the script itself
# The file is identical for all my plugins relying on LibFredo6
=end
require 'sketchup.rb'
require 'extensions.rb'
require 'Fredo6_!LibFredo6.rb'  # explicit call to fix loading order under wine on linux
module Fredo6
if defined?(LibFredo6.top_load)
   hsh_ext, plugin, ext = LibFredo6.top_load(__FILE__, true)
   if hsh_ext && plugin && !ext
      ext = SketchupExtension.new hsh_ext[:name], hsh_ext[:floader]
      ext.creator = hsh_ext[:creator]
      ext.description = hsh_ext[:description]
      ext.version = hsh_ext[:version]
      ext.copyright = hsh_ext[:copyright]
      status = Sketchup.register_extension ext, true
      plugin.load_finalize ext
else
   UI.messagebox "You must install LibFredo6 version 6.9 or higher to run #{File.basename(__FILE__, ".rb")}"
end   #module Fredo6
note sure if it is the right thing to do...
Chowette
chowette
Postby pmgbubolz » Wed Jul 13, 2016 2:23 pm
Plugin is extremely useful! But it would be even more powerful if allow different values for angles.
Any possibility to add this functionality?
pmgbubolz
Postby keyudits » Fri Aug 12, 2016 4:34 am
Im running into an issue where I am trying to smooth out the tops, corners and bottoms of an interior rectangle, (think, bathtub.) but when I execute it appears as though the program just fills in the interior space.
I have had good luck with interior and exterior corners, just not combining edges and corners..any suggestions?
keyudits
Postby Box » Fri Aug 12, 2016 9:42 am
Do you mean like this?
Round corner will often fill in faces and you just need to remove them.
Postby numerobis » Fri Aug 12, 2016 1:09 pm
Any chance to get this fixed? Here is an example how it looks like in SU. Just like smoothing >45° + hard edges.
The left cube is the direct result of the beveling. The right one is the same model with corrected normals (0°).
(The lighting is the same)
numerobis
Postby cowboyathome » Fri Aug 12, 2016 5:59 pm
Box wrote:Do you mean like this?
Fredo, is this an unavoidable side effect which can't be fixed?
cowboyathome
Postby keyudits » Fri Aug 12, 2016 7:04 pm
yes! didnt think to try that. I appreciate the speedy response.
keyudits
Postby whitelock » Fri Aug 26, 2016 10:54 am
Hi any ideas what combination of edge filters i need on round corner in order to just see the border lines. look at the image. On the left is how I would like to see it on the right is the best I can get and I end up having to do loads of clean up. any help greatly appreciated
whitelock
Postby Box » Fri Aug 26, 2016 12:41 pm
Could you attach that model so we can look at it, as I can't replicate your problem.
Postby deaneau » Sat Sep 03, 2016 6:06 pm
@whitelock
Try to select your lines and then use hide (from context-menu)
MADE, BORN AND LIVING IN BERLIN
Big Thank You to all Programmers
Some German words are so long that they have a perspective. M.Twain
deaneau
Re: [Plugin] RoundCorner - v3.1b - 04 Sep 16
Postby fredo6 » Sun Sep 04, 2016 2:02 pm
NEW RELEASE: RoundCorner v3.1b - 04 Sep 16
RoundCorner 3.1b is a maintenance release. It fixes a bug preventing to make a sphere and a dome from a cube, as shown in the video below.
See main post of this thread for Download.
Fredo
5
fredo6
PluginStore Author
PluginStore Author
Postby pep75 » Mon Sep 05, 2016 12:12 pm
Great Fredo!!! Thanks!
pep75
PreviousNext
Return to Plugins
Users browsing this forum: Google Bot, mehdi ta and 11 guests
