[Plugin] FredoGuides - v2.1a - 04 Aug 21
Postby fredo6 » Mon Dec 23, 2019 2:03 pm
The information on FredoGuides is maintained on the Plugin Home Page of FredoGuides. This is also where you can download the RBZ file.
REQUIREMENTS:
  • LibFredo6: v11.0 or above
  • Usage: Free for the time being
  • Expiration on: 31 Dec 2021
TO NEWCOMERS: If you land on this page and are unfamiliar with how to install Sketchup Extensions such as LibFredo6 or how to register on Sketchucation, please watch this video or refer to the Plugin page of LibFredo6.
FredoGuides is a new extension dealing with Sketchup Guides (also called Construction lines and points).
Version 1.5 includes the following features:
  • Guide Protection: Mark guides to prevent their deletion by the 'Delete Guides' command of Sketchup.
  • Toggle Visibility: Toggle visibility of all guides in the model. This setting can be saved by Scene.
  • Guide Color: Assign a color to guide lines and guide points. This setting can be saved by Scene.
Credit: all toolbar icons and button images by JClements
NO user manual for the time being. Have a look at the video and Quick Start section at the plugin page.
1) Guides Protection
A quick introduction to the Protection of Guides
2) Guides Visibility and Color
...and how to assign them to scenes.
9
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoGuides - v1.1a - 23 Dec 19
Postby sitthikorn » Tue Dec 24, 2019 5:51 pm
Hi, Fredo Thank you for your create this extension.
I would like to feedback for FreoGuides like this...
when I make a marking guide inside the component and click protect it then I save component and reload it places to the model. The Protection can not protect the guide when I click delete guides (Edit>delete guides). That I think it should protect the guide in components after save as together.
Thank you
Sitthikorn N.
sitthikorn
Postby fredo6 » Tue Dec 24, 2019 7:47 pm
sitthikorn wrote:when I make a marking guide inside the component and click protect it then I save component and reload it places to the model. The Protection can not protect the guide when I click delete guides (Edit>delete guides). That I think it should protect the guide in components after save as together.
Not very clear to me. Could you post the model so that I understand.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoGuides - v1.1b - 25 Dec 19
Postby fredo6 » Wed Dec 25, 2019 8:01 pm
NEW RELEASE: FredoGuides v1.1b - 25 Dec 19
Requirement: LibFredo6 9.5
FredoGuides v1.1b fixes a serious bug preventing to protect guides if done right after opening Sketchup. So it is advised to migrate to this version
Home Page of FredoGuides[/color][/b] for information and Download.
Main post of this FredoGuides thread.
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoGuides - v1.1c - 25 Dec 19
Postby fredo6 » Wed Dec 25, 2019 11:09 pm
NEW RELEASE: FredoGuides v1.1c - 25 Dec 19
FredoGuides v1.1c fixes another serious bug preventing to protect guides if done right after opening a Sketchup file containing protected guidelines. So it is advised to migrate to this version
fredo6
PluginStore Author
PluginStore Author
Postby nini007 » Sat Dec 28, 2019 10:08 pm
Bonjour Fredo,
Ce plugin est formidable et d'une utilité primordiale à couplé avec celui de D. Bur "Projections".
Je n'arrive pas à changer la couleur des guides, est-ce un bogue ?!?
Ce qui serait utile c'est de pouvoir mettre certain guide dans un groupe ou composant et pouvoir changer la couleur des guides uniquement ceux qui sont dans un groupe ou composant et pouvoir avoir plusieurs couleurs selon l'importance du guide.
Bravo pour tous ses plugins qui simplifient la vie, vos plugins sont incontournables.
Meilleures salutations
nini007
Postby fredo6 » Sun Dec 29, 2019 3:27 pm
nini007 wrote:Ce qui serait utile c'est de pouvoir mettre certain guide dans un groupe ou composant et pouvoir changer la couleur des guides uniquement ceux qui sont dans un groupe ou composant et pouvoir avoir plusieurs couleurs selon l'importance du guide.
Unfortunately, Sketchup does only support a SINGLE color for ALL guides...
fredo6
PluginStore Author
PluginStore Author
Postby Oxer » Sun Jan 05, 2020 6:25 pm
Hi and Happy New Year!!
The Spanish Language file:
FredoGuides_ES.lang.zip
http://www.oxervision.blogspot.com/
Oxer
Postby fredo6 » Sun Jan 05, 2020 7:24 pm
Oxer wrote:The Spanish Language file
Many thanks. I integrate in the next version.
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoGuides - v1.1d - 05 Jan 20
Postby fredo6 » Sun Jan 05, 2020 7:48 pm
NEW RELEASE: FredoGuides v1.1d - 05 Jan 20
FredoGuides v1.1d includes the Spanish translation by Oxer.
fredo6
PluginStore Author
PluginStore Author
Postby ken » Wed Jan 22, 2020 3:18 am
Fredo
When ever I right click on any object, I get the attached error message.
Thank you Fredo, the new install solved the problem.
ken
Premium Member
Premium Member
Postby Dave R » Wed Jan 22, 2020 5:08 am
I'm getting the same message Ken shows. I made sure that I have the latest versions of both FredoGuides and LibFredo6 but I still get it.
Global Moderator
Postby adorian » Wed Jan 22, 2020 6:03 am
HELP Fredo, whenever I click the right mouse I get this window; and uninstall the plugin but keeps coming.
I tried everything, including installing the new library but the window keeps coming!
adorian
Re: [Plugin] FredoGuides - v1.1e - 22 Jan 20
Postby fredo6 » Wed Jan 22, 2020 8:14 am
NEW RELEASE: FredoGuides v1.1e - 22 Jan 20
FredoGuides v1.1e extends the validity.
fredo6
PluginStore Author
PluginStore Author
Postby Didier Bur » Wed Jan 22, 2020 9:16 am
Thanks Fredo, Problem solved.
P.S.: pourquoi faire des extensions gratuites qui expirent à une date donnée ?
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby fredo6 » Wed Jan 22, 2020 10:17 am
Didier Bur wrote:P.S.: pourquoi faire des extensions gratuites qui expirent à une date donnée ?
Precisely, these extensions may become paid in the future... It's a minor inconvenience, since they are free today. Also, a good way to keep the installed base on recent versions of the script.
fredo6
PluginStore Author
PluginStore Author
Postby JClements » Wed Jan 22, 2020 11:30 am
Before I updated I had the same issue.
I installed the update via the SketchUcation extension. However, I had to close SU and reopen it before the update would work.
JClements
Premium Member
Premium Member
Postby fredo6 » Wed Jan 22, 2020 11:42 am
JClements wrote:Before I updated I had the same issue.
This is true for most plugins, because a ne version may have to update the menu and also the part that loads when Sketchup starts.
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoGuides - v1.2a - 22 Jan 20
Postby fredo6 » Wed Jan 22, 2020 10:08 pm
NEW RELEASE: FredoGuides v1.2a - 22 Jan 20
FredoGuides v1.2a fixes bugs and includes adjustments for performance in contextual menu.
Home Page of FredoGuides for information and Download.
fredo6
PluginStore Author
PluginStore Author
Postby penumbra » Thu Feb 13, 2020 5:05 am
I am experiencing a strange behaviour with the plugin. it appears to make copies of the protected guides every time i use the "delete all guides" command. There are thousands of copies of the Fredoguides in the outliner appear. i'll [ost the file later.
penumbra
Postby fredo6 » Thu Feb 13, 2020 7:44 pm
penumbra wrote:I am experiencing a strange behaviour with the plugin. it appears to make copies of the protected guides every time i use the "delete all guides" command. There are thousands of copies of the Fredoguides in the outliner appear. i'll [ost the file later.
If you can reproduce it, I'll be interested in the file.
Also, if you can leave the Ruby console opened when deleting guides...
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoGuides - v1.3a - 21 May 20
Postby fredo6 » Thu May 21, 2020 8:56 am
NEW RELEASE: FredoGuides v1.3a - 21 May 20
Requirement: LibFredo6 9.5k
FredoGuides v1.3a extends the validity.
fredo6
PluginStore Author
PluginStore Author
Postby zivotinja » Fri May 22, 2020 5:06 pm
I have uninstalled fredoguides since it is causing a problem with the operation - you need to upgrade fredo guide since the license has expired (???!) However the error still appears. And I have checked the plugin folder it is not there. However, the icon bar appears in the SK2019. What to do??
Thank you
zivotinja
Postby fredo6 » Fri May 22, 2020 5:13 pm
zivotinja wrote:I have uninstalled fredoguides since it is causing a problem with the operation - you need to upgrade fredo guide since the license has expired (???!) However the error still appears. And I have checked the plugin folder it is not there. However, the icon bar appears in the SK2019. What to do??
To uninstall, please delete both the Fredo6_FredoGuides.rb file and the Fredo6_FredoGuides subfolder.
Did you try however to upgrade to the new version?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby zivotinja » Fri May 22, 2020 5:22 pm
So all elements are removed from the plugins folder. However the toolbar still shows. ??! :puke: :o
zivotinja
Postby zivotinja » Fri May 22, 2020 5:34 pm
FYI
zivotinja
Postby zivotinja » Fri May 22, 2020 5:36 pm
I have uninstalled and restarted. However, the toolbar and error message still appear
zivotinja
Postby zivotinja » Fri May 22, 2020 5:54 pm
Error Message. I cannot use right mouse button any more
zivotinja
Postby fredo6 » Fri May 22, 2020 6:11 pm
Since you restarted Sketchup, there must be another place where Sketchup take FredoGuides from.
Otherwise, it would be magic....
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] FredoGuides - v1.4a - 25 May 20
Postby fredo6 » Mon May 25, 2020 11:20 am
NEW RELEASE: FredoGuides v1.4a - 25 May 20
Requirements
  • LibFredo6: v10.5a
FredoGuides v1.4a is a maintenance release for bug fixing and cosmetic adjustments for Mac
fredo6
PluginStore Author
PluginStore Author
Next
Return to Plugins
Users browsing this forum: EmpowerCB, metehanbaytore, traxs_01 and 13 guests
